i have successfully flashed a CC2531 stick, with the firmware which is mentioned here:
When i install the Zigbee-Binding, i see that the binding is installed. But i guess under Configuration->Bindings i should see the CC2531 with the Address and so one … ?? But i see just the installed Binding.
In the console i can see that the CC2531 is identified by the system:
with ls -l /dev/ttyACM0
i see
/dev/ttyACM0
why is the CC2531 not recognised by the Binding?
In the openhab.log is nothing concerning zigbee. I have activated the zigbee loging, like mentioned in the documentation.
Check if java knows about serial device (do a ps and see if -Dgnu.io.rxtx.SerialPorts=… contains /dev/ttyACM0).
It’s usually injected by setting EXTRA_JAVA_OPTS= in /etc/default/openhab2, not sure if that applies to your Mint setup.
Also may need to delete the contents of /var/lib/openhab2/cache and /var/lib/openhab2/tmp. Not sure the this is the correct path to your Miint cache and tmp files, check the doc’s to verify. Then restart openhab.
do you mean with “device” the Zigbee-master-Stick or the Zigbee-slaves??
I thought, when i have the stick pluged in and install the binding, i can use the Zigbee-master-stick without configuration? And i just have to connect the slaves to the master-stick?
Did i have to configure the Zigbee-Stick manualy??
No. The system needs to somehow know that you have a CC2531, what port, speed, etc it is on, chant ZigBee channel, PAN, EPAN, key… This information needs to be provided once you add the coordinator.
A good source of information is the documentation -:
Yes. As per the documentation at the link above -:
Coordinators need to be installed manually and the serial port and baud rate must be set. These are set to match the configuration that the dongle is in.
