I am trying to install the Zigbee binding, but it does not exist in the list of available bindings in Docker 3.2.M5 image. Is it in another place or does it have to be installed some other way?
It should exist - note that I think it is called “OpenHAB ZigBee binding” - so you need to look under O, not Z.
it is there… I`m using this image.
But it is a little bit buggy with some lightbulbs as reported here: https://github.com/openhab/org.openhab.binding.zigbee/issues/717
This has been fixed.
Thanks Chris,
I found it and am trying it now.
Ron
where can I get the last build with the fix?
https://ci.openhab.org/job/openHAB-Zigbee/
But please check openHAB-Zigbee Changes [Jenkins] … #717 seems to be missing.
