ZigBee Binding: regularly issues with failure logs
Hi there,
I got, after every boot, regular repeating issues with the zigbee binding. The strange thing is, every zigbee device works properly, meaning I can change/ switch the status of the devices normaly. So there seems to be no known problem, but the logs are full of these errors…
These errors appear regularly after every reboot:
2019-04-22 07:45:21.951 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolParseException: Packet checksum failed
	at com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolPacketStream.parsePacket(ZToolPacketStream.java:140) [319:com.zsmartsystems.zigbee.dongle.cc2531:1.1.6]
	at com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolPacketParser.run(ZToolPacketParser.java:107) [319:com.zsmartsystems.zigbee.dongle.cc2531:1.1.6]
2019-04-22 07:45:31.574 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
2019-04-22 07:46:08.506 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
2019-04-22 07:46:12.229 [ERROR] [converter.ZigBeeConverterSwitchOnoff] - 000B57FFFEE7ED91: Error 0xffff setting client binding
2019-04-22 07:46:24.021 [ERROR] [nverter.ZigBeeConverterGenericButton] - 0017880104EF21B1: Error 0xffff setting client binding for cluster 6
2019-04-22 07:46:34.166 [ERROR] [nverter.ZigBeeConverterGenericButton] - 0017880104EF21B1: Error 0xffff setting client binding for cluster 6
2019-04-22 07:46:44.309 [ERROR] [nverter.ZigBeeConverterGenericButton] - 0017880104EF21B1: Error 0xffff setting client binding for cluster 8
2019-04-22 07:46:46.141 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 90FD9FFFFE04BDB6: Starting ZigBee device discovery
2019-04-22 07:46:53.388 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
2019-04-22 07:46:54.567 [ERROR] [nverter.ZigBeeConverterGenericButton] - 0017880104EF21B1: Error 0xffff setting client binding for cluster 8
2019-04-22 07:46:54.782 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
2019-04-22 07:44:34.251 [ERROR] [org.openhab.binding.zigbee          ] - bundle org.openhab.binding.zigbee:2.5.0.201903030031 (316)BundleComponentActivator : Unexpected failure enabling component holder org.openhab.binding.zigbee.internal.converter.warningdevice.DynamicWarningCommandDescriptionProvider
java.lang.NoClassDefFoundError: org/eclipse/smarthome/core/thing/type/DynamicCommandDescriptionProvider
	at java.lang.ClassLoader.defineClass1(Native Method) ~[?:?]
	at java.lang.ClassLoader.defineClass(ClassLoader.java:763) ~[?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:276) ~[?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:655) ~[?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578) ~[?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) ~[?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) ~[?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:984) ~[39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1011) ~[39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899) ~[39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:139) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) [?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:548) [?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:449) [?:?]
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468) [?:?]
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529) [?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) [?:?]
	at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:430) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) [?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) [?:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) [?:?]
	at java.lang.Class.getDeclaredConstructors0(Native Method) ~[?:?]
	at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671) [?:?]
	at java.lang.Class.getConstructors(Class.java:1651) [?:?]
	at org.apache.felix.scr.impl.inject.ComponentConstructor.<init>(ComponentConstructor.java:94) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.inject.ComponentMethodsImpl.initComponentMethods(ComponentMethodsImpl.java:106) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:993) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1011) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
	at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1613) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.core.thing.type.DynamicCommandDescriptionProvider cannot be found by org.openhab.binding.zigbee_2.5.0.201903030031
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433) ~[?:?]
	... 97 more
2019-04-22 07:44:34.915 [ERROR] [org.openhab.binding.zigbee          ] - FrameworkEvent ERROR - org.openhab.binding.zigbee
org.osgi.framework.ServiceException: Exception in org.apache.felix.scr.impl.manager.SingleComponentManager.getService()
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:222) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) ~[?:?]
	at com.eclipsesource.jaxrs.publisher.internal.Activator.openAllServiceTracker(Activator.java:91) ~[?:?]
	at com.eclipsesource.jaxrs.publisher.internal.Activator.start(Activator.java:55) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) ~[?:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:581) ~[?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
Caused by: java.lang.NoClassDefFoundError: org/eclipse/smarthome/core/thing/type/DynamicCommandDescriptionProvider
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:984) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1011) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
	... 30 more
	... 30 more
@chris have you had seen these errors before?
The checksum error is seen occasionally, but I’ve not seen the one relating to class definitions. This sort of error normally comes up when there is something inconsistent in the configuration - eg you may be running a binding that is looking for services in the core that don’t exist. I’m not sure exactly what is happening here, but that’s the common cause of this sort of error.
