Because of the broadcast issue (which may be a problem with Ember only) I initially had problems adding lots of devices at once. Once I changed the way the discovery worked to remove the broadcasts, I could add 10 bulbs at a time - basically just opening up join for 2 minutes and screwing the bulbs in to the holder as fast as I could . The bulbs came in packets of 10, hence why I was doing it like this, but it worked fine.
My only hesitation though is that this could be a problem that only appears with Ember, so I don’t want to say it will solve everyones discovery issues
I think currently we have 2 main problems:
1- the cc2531 capabilities and how its firmware is configured. This had nothing to do with binding AFAIK.
2- The binding implementation and how chatty it’s on the network. I agree with you about the discovery and I think it is much better than database approach, but I think it is important to make sure that it is optimized and no unnecessary discovery/communication is happening, which I think it’s what you plan on improving.
I want to make sure that I optimize problem 1 while waiting for problem 2 optimizations.
But what does this mean exactly? What do you suggest that can be reduced? Currently, the binding requests the device information when the device joins the network. If you have suggestions about anything that is not necessary, then please let me know. This binding, and the libraries are used in tens of thousands of applications.
I don’t think there are any unnecessary discovery communications taking place. We request the endpoints and the descriptors, and information about the device (model ID etc) so that it can be identified. In general, this should only happen when a device first joins the network and all of this I would consider necessary, but if you have a better idea then please say - I may well be wrong?
As above, if you think that some of this is unnecessary then Im very happy to discuss this.
No - the changes that I’m making will not change the way that discovery works. I expect that with the Ember NCP at least, it will help by reducing broadcasts which have limitations on the number that can be sent in an 8 second period (the limitation comes from ZigBee).
I didn’t dig into the code yet, but I found a closed pull request from @giuseppeiannello that mentioned eliminating unnecessary rediscovery that happened on starting a scan, and I think you left an open issue about this.
so far, even if the rediscovery still happens on starting a scan, I can add nodes to the network - I’m using the stock add-on, without my changes. but could be because of the custom firmware.
That is above how OH performs discovery - in theory it should not impact the network itself except in some circumstances such as rejoins (that should be very rare).
Possibly.
This is the binding code that you refer to - not the ZigBee code. The ZigBee code that performs the discovery is in a different library.
Maybe we are talking about different things. In general, I’m talking about how the ZigBee system performs a discovery - ie the network traffic that is gathered during discovery. Very little of this is done in the binding.
Then probably it’s the firmware limit. I should try the other firmwares that implement source routing and see if it can help me add more things and improves the performance.
Yes, I was able to add devices until I hit the ~35 mark, then things started to be different. I should try another firmware and see.
I just found out that the stick I am using has CC2538 + CC2592
Apparently it is more powerful than the cc2531 or cc2530, and it seems that it works with the same 1.2.2a firmware as any cc253x.
I think the modified firmwares should work without problems, unless they have memory specific configurations which I will need to update according to the cc2538 **fingers crossed**
I was wrong, it uses a different firmware, which means I had to apply the optimization to the cc2538 firmware manually.
The chip also supports a more powerful firmware (Z-Stack_3.0.x) which according to Koenkk’s version should handle 200/400 routes. Although I am not sure if it is compatible with the Zigbee binding (worth testing)
I think the modified firmwares should work without problems, unless they have memory specific configurations which I will need to update according to the cc2538 fingers crossed
CC2538 is a different compile-time target, so my custom firmware linked above will not work with it.
On the other hand, you will hardly need those customizations, with that hardware
BTW, I’m experiencing big problems with 2.5.7. had to rollback, the network is pretty unusable otherwise.
I thought that my hardware was good enough to handle ~40 nodes, but unfortunately, I couldn’t add devices after 35, and worse my network collapsed after 2 days and many nodes are offline/unresponsive without doing anything. I am on 2.5.7 as well.
I was looking for a source routing firmware hoping that it might improve things and all I can find is Koenkk’s version which is based on Z-Stack 3.0.x.
I also have a cc2530+RFX2401 or CC2530+CC2591 (I am not sure) dongle which is refusing to work with the binding and showing the message:
Dongle reset failed. Assuming bootloader is running and sending magic byte 0xef.
Attempt to get out from bootloader failed.
I tried default firmware, modified, and everything I can find and it is still not responding. Although it worked with zigbee2mqtt!
I’ve split my system into 2 different ZigBee dongles with ~15 nodes each, and I upgraded to the latest version of the system. Now everything is working smoothly .
