Sure look forward to hear your experiences…
Do you happen to know which version you´ve got? I think Bruce mentioned something about an older and a new one. I have yet to understand their differences.
I have an “old” one that I bought a year or so back, and I have a new one that arrived 20 minutes ago. I think on the Ikea website it did have a “new” icon next to the motion sensor so I guess this might be a new model.
I’ve not opened the box yet so have not tried to compare them in any way.
I just did a fast google search and found two different versions.
First one, which I believe is the “old” one is this:
Second one, (which is simular to the one I have and can´t be included correctly in my system):
Now go play with yours
Well… Unfortunalty things didnt work anyway. But whats very frustrating is, that this time its the Hue motion sensor which stopped responding aproximately 20 minutes after the restart. Usually this device use to continue to work most. And 25 minutes after restart, the Osram plus went offline
You are of course right that it is not explicitly the Zigbee binding. Exactly the same errors occur, and Hue / Tradfri are known to use the same Zigbee standard. With openhab 2.4.0 everything runs normally, with 2.5.0 (new and freshly installed) the errors mentioned occur. Isn’t it possible that it’s not just a binding related problem?
If you want I delete my post and open 2 of the same with the differences Tradfri Binding and Hue Binding.
Wait for the updated binding before pursuing that path.
But I don’t think it can be linked. The bindings provide an abstraction between OH and ZigBee and there is nothing that is common at the ZigBee level from a binding perspective as they all use their own hubs so will handle errors etc differently.
The only common area could be in your house. If you are seeing problems on all these systems, then maybe there is interference etc.
You might as well leave the post above, otherwise this discussion becomes a bit strange if people look at i tater, but if there are problems in the other bindings, then you probably should raise them separately.
Quick question, did you install the network binding?
It looks like this binding is making communication very slow. (Version 2.5.0 only, not 2.4.0)
When I delete my network.things file, Zigbee works without delay.
I use the network binding and OH 2.5 Release. Except for my common problems, I dont experience Zigbee beeing slower than usual.
Ok, maybe it’s just certain combinations or a missing package e.g. arping
I’m still testing that.
In any case, I can determine in my system as soon as I upload my network.things files, there is a delay of 5-10 seconds in the Zigbee communication.
I’ve been having the same issues with Zigbee devices acting very slowly. Sometimes it takes upwards of 30 seconds before a command is registered on the bulb. I am using an Osram Smart+ bulb (listed as LEDVANCE) with color temp and dimmer. I have also move to Openhabian on my Pi 4, and am using the regular Zigbee binding. Finally, I am trying the snapshot build as well. Using an xbee usb dongle.
30 seconds seems to be the longest wait, sometimes it’s instantaneous. Also, if I do multiple commands they all go into effect after that 30 seconds has lapsed. (dim and change the color temp, for example). I read somewhere that if the initial command is not registered it would wait 30 seconds and poll again. (to be honest I’m not sure the exact details but this is what it seems to be doing).
I don’t have a lot of experience with Openhab yet, so direction would be very helpful. I’m only playing right now so I am willing to try anything.
UPDATE:
I am starting to figure things out with Openhab. For example, I was able to get logs. I don’t know what I’m looking at but here they are. It seems to me that the command to the bulb is being sent but immediately goes into a transaction queue vs going directly to the light. Maybe this is correct? Have a look and let me know what you think:
2020-05-27 17:52:49.198 [ome.event.ItemCommandEvent] - Item 'LEDVANCEA19TW10Year_ColorTemperature' received command 1
2020-05-27 17:52:49.235 [nt.ItemStatePredictedEvent] - LEDVANCEA19TW10Year_ColorTemperature predicted to become 1
2020-05-27 17:52:49.257 [vent.ItemStateChangedEvent] - LEDVANCEA19TW10Year_ColorTemperature changed from 84 to 1
2020-05-27 17:52:49.267 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: Added transaction to queue, len=3, transaction=ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=0, state=WAITING, sendCnt=0, command=MoveToColorTemperatureCommand [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=--, colorTemperature=154, transitionTime=10]]
2020-05-27 17:52:49.271 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/1: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=103006, state=WAITING, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=54, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:49.274 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-05-27 17:52:49.276 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=54, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:52:49.278 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=84, commandId=11]
2020-05-27 17:52:49.280 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=ED83/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=14, rssi=--, lqi=--, payload=10 54 0B 0A 00]
2020-05-27 17:52:49.282 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 54 0B 0A 00]
2020-05-27 17:52:49.285 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=41, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 54 0B 0A 00]
2020-05-27 17:52:49.287 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=41, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 54 0B 0A 00]
2020-05-27 17:52:49.289 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 19 11 29 F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 00 00 10 54 0B 0A 00 94
2020-05-27 17:52:49.319 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/1: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=106328, state=WAITING, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=53, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:49.320 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2020-05-27 17:52:49.322 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=53, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:52:49.324 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=83, commandId=11]
2020-05-27 17:52:49.325 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=ED83/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=15, rssi=--, lqi=--, payload=10 53 0B 0A 00]
2020-05-27 17:52:49.327 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 53 0B 0A 00]
2020-05-27 17:52:49.330 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=42, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 53 0B 0A 00]
2020-05-27 17:52:49.417 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 29 ED 83 00 00 00 DB
2020-05-27 17:52:49.418 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=41, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:52:49.419 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=42, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 53 0B 0A 00]
2020-05-27 17:52:49.422 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 19 11 2A F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 00 00 10 53 0B 0A 00 94
2020-05-27 17:52:49.566 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 2A ED 83 00 00 00 DA
2020-05-27 17:52:49.567 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=42, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:52:59.277 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=113012, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=54, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:59.279 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2020-05-27 17:52:59.280 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete FAILED 1
2020-05-27 17:52:59.282 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete exceeded retries 2
2020-05-27 17:52:59.285 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction terminated: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=113020, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=54, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:59.288 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/1: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10021, state=WAITING, sendCnt=0, command=MoveToColorTemperatureCommand [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=A5, colorTemperature=154, transitionTime=10]]
2020-05-27 17:52:59.291 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2020-05-27 17:52:59.294 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: MoveToColorTemperatureCommand [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=A5, colorTemperature=154, transitionTime=10]
2020-05-27 17:52:59.297 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=165, commandId=10]
2020-05-27 17:52:59.300 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=ED83/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=16, rssi=--, lqi=--, payload=01 A5 0A 9A 00 0A 00]
2020-05-27 17:52:59.304 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=01 A5 0A 9A 00 0A 00]
2020-05-27 17:52:59.307 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=43, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=01 A5 0A 9A 00 0A 00]
2020-05-27 17:52:59.311 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=43, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=01 A5 0A 9A 00 0A 00]
2020-05-27 17:52:59.319 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 1B 11 2B F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 00 00 01 A5 0A 9A 00 0A 00 B7
2020-05-27 17:52:59.323 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=116331, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=53, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:59.325 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2020-05-27 17:52:59.327 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete FAILED 1
2020-05-27 17:52:59.329 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete exceeded retries 2
2020-05-27 17:52:59.332 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction terminated: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=116340, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=53, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:59.480 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 17 91 F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 01 08 A5 0B 0A 00 F3
2020-05-27 17:52:59.483 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeReceivePacketExplicitEvent [ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, clusterId=768, profileId=260, receiveOptions=PACKET_ACKNOWLEDGED, data=08 A5 0B 0A 00]
2020-05-27 17:52:59.486 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=ED83/1, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=null, radius=0, apsSecurity=false, ackRequest=false, apsCounter=--, rssi=--, lqi=--, payload=08 A5 0B 0A 00]
2020-05-27 17:52:59.488 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=165, commandId=11]
2020-05-27 17:52:59.490 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: DefaultResponse [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=A5, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:52:59.492 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=A5, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:52:59.495 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=A5, commandIdentifier=10, statusCode=SUCCESS] ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10228, state=DISPATCHED, sendCnt=1, command=MoveToColorTemperatureCommand [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=A5, colorTemperature=154, transitionTime=10]]
2020-05-27 17:52:59.498 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 2B ED 83 00 00 00 D9
2020-05-27 17:52:59.498 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10231, state=COMPLETE, sendCnt=1, command=MoveToColorTemperatureCommand [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=A5, colorTemperature=154, transitionTime=10]]
2020-05-27 17:52:59.500 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=43, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:52:59.501 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-05-27 17:52:59.504 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete COMPLETE 0
2020-05-27 17:52:59.522 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 1A 91 F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 01 08 55 0A 07 00 21 71 01 B4
2020-05-27 17:52:59.525 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeReceivePacketExplicitEvent [ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, clusterId=768, profileId=260, receiveOptions=PACKET_ACKNOWLEDGED, data=08 55 0A 07 00 21 71 01]
2020-05-27 17:52:59.527 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=ED83/1, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=null, radius=0, apsSecurity=false, ackRequest=false, apsCounter=--, rssi=--, lqi=--, payload=08 55 0A 07 00 21 71 01]
2020-05-27 17:52:59.529 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=85, commandId=10]
2020-05-27 17:52:59.532 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=55, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, attributeValue=369]]]
2020-05-27 17:52:59.534 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReportAttributesCommand [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=55, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, attributeValue=369]]]
2020-05-27 17:52:59.538 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=0, state=WAITING, sendCnt=0, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:59.541 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/1: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=3, state=WAITING, sendCnt=0, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:52:59.543 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2020-05-27 17:52:59.549 [vent.ItemStateChangedEvent] - LEDVANCEA19TW10Year_ColorTemperature changed from 1 to 84
2020-05-27 17:52:59.546 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:52:59.556 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=85, commandId=11]
2020-05-27 17:52:59.559 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=ED83/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=17, rssi=--, lqi=--, payload=10 55 0B 0A 00]
2020-05-27 17:52:59.562 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 55 0B 0A 00]
2020-05-27 17:52:59.566 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=44, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 55 0B 0A 00]
2020-05-27 17:52:59.568 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=44, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 55 0B 0A 00]
2020-05-27 17:52:59.575 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 19 11 2C F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 00 00 10 55 0B 0A 00 90
2020-05-27 17:52:59.710 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 2C ED 83 00 00 00 D8
2020-05-27 17:52:59.711 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=44, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:53:01.674 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 1A 91 F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 01 08 56 0A 07 00 21 9A 00 8B
2020-05-27 17:53:01.677 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeReceivePacketExplicitEvent [ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, clusterId=768, profileId=260, receiveOptions=PACKET_ACKNOWLEDGED, data=08 56 0A 07 00 21 9A 00]
2020-05-27 17:53:01.679 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=ED83/1, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=null, radius=0, apsSecurity=false, ackRequest=false, apsCounter=--, rssi=--, lqi=--, payload=08 56 0A 07 00 21 9A 00]
2020-05-27 17:53:01.682 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=86, commandId=10]
2020-05-27 17:53:01.684 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=56, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, attributeValue=154]]]
2020-05-27 17:53:01.686 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReportAttributesCommand [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=56, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, attributeValue=154]]]
2020-05-27 17:53:01.690 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReportAttributesCommand [Color Control: ED83/1 -> 0000/1, cluster=0300, TID=56, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=7, attributeValue=154]]] ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=2152, state=DISPATCHED, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:01.694 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=0, state=WAITING, sendCnt=0, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:01.696 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/1: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=3, state=WAITING, sendCnt=0, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:01.699 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2020-05-27 17:53:01.705 [vent.ItemStateChangedEvent] - LEDVANCEA19TW10Year_ColorTemperature changed from 84 to 0
2020-05-27 17:53:01.704 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:53:01.712 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=86, commandId=11]
2020-05-27 17:53:01.715 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=ED83/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=18, rssi=--, lqi=--, payload=10 56 0B 0A 00]
2020-05-27 17:53:01.717 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 56 0B 0A 00]
2020-05-27 17:53:01.720 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=45, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 56 0B 0A 00]
2020-05-27 17:53:01.723 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=45, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 56 0B 0A 00]
2020-05-27 17:53:01.730 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 19 11 2D F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 00 00 10 56 0B 0A 00 8E
2020-05-27 17:53:01.855 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 2D ED 83 00 00 00 D7
2020-05-27 17:53:01.857 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=45, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:53:07.692 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 1B 91 F0 D1 B8 00 00 02 71 52 ED 83 00 00 00 06 00 00 02 05 FD FF 04 01 01 19 00 00 98
2020-05-27 17:53:07.694 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeReceivePacketExplicitEvent [ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=0, destinationEndpoint=0, clusterId=6, profileId=0, receiveOptions=PACKET_BROADCAST, data=05 FD FF 04 01 01 19 00 00]
2020-05-27 17:53:07.697 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=ED83/0, destinationAddress=0000/0, profile=0000, cluster=0006, addressMode=null, radius=0, apsSecurity=false, ackRequest=false, apsCounter=--, rssi=--, lqi=--, payload=05 FD FF 04 01 01 19 00 00]
2020-05-27 17:53:07.700 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: MatchDescriptorRequest [ED83/0 -> 0000/0, cluster=0006, TID=05, nwkAddrOfInterest=FFFD, profileId=0104, inClusterList=[25], outClusterList=[]]
2020-05-27 17:53:07.703 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: MatchDescriptorRequest [ED83/0 -> 0000/0, cluster=0006, TID=05, nwkAddrOfInterest=FFFD, profileId=0104, inClusterList=[25], outClusterList=[]]
2020-05-27 17:53:07.706 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: MatchDescriptorRequest [ED83/0 -> 0000/0, cluster=0006, TID=05, nwkAddrOfInterest=FFFD, profileId=0104, inClusterList=[25], outClusterList=[]] ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=8168, state=DISPATCHED, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:07.710 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: MatchDescriptorRequest [ED83/0 -> 0000/0, cluster=0006, TID=05, nwkAddrOfInterest=FFFD, profileId=0104, inClusterList=[25], outClusterList=[]] ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=6016, state=DISPATCHED, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:07.713 [DEBUG] [stems.zigbee.internal.ClusterMatcher] - 51145391B4ED9DF0: ClusterMatcher received request MatchDescriptorRequest [ED83/0 -> 0000/0, cluster=0006, TID=05, nwkAddrOfInterest=FFFD, profileId=0104, inClusterList=[25], outClusterList=[]]
2020-05-27 17:53:07.716 [DEBUG] [stems.zigbee.internal.ClusterMatcher] - 51145391B4ED9DF0: ClusterMatcher sending match MatchDescriptorResponse [null -> ED83/0, cluster=8006, TID=05, status=SUCCESS, nwkAddrOfInterest=0000, matchList=[1]]
2020-05-27 17:53:07.719 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=0, state=WAITING, sendCnt=0, command=MatchDescriptorResponse [0000/0 -> ED83/0, cluster=8006, TID=05, status=SUCCESS, nwkAddrOfInterest=0000, matchList=[1]]]
2020-05-27 17:53:09.546 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10009, state=FAILED, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:09.548 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2020-05-27 17:53:09.550 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete FAILED 1
2020-05-27 17:53:09.553 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: Added transaction to queue, len=2, transaction=ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10015, state=WAITING, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:09.555 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/1: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10018, state=WAITING, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:09.557 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2020-05-27 17:53:09.560 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:53:09.562 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=85, commandId=11]
2020-05-27 17:53:09.564 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=ED83/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=19, rssi=--, lqi=--, payload=10 55 0B 0A 00]
2020-05-27 17:53:09.567 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 55 0B 0A 00]
2020-05-27 17:53:09.569 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=46, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 55 0B 0A 00]
2020-05-27 17:53:09.572 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=46, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 55 0B 0A 00]
2020-05-27 17:53:09.579 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 19 11 2E F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 00 00 10 55 0B 0A 00 8E
2020-05-27 17:53:09.719 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 2E ED 83 00 00 00 D6
2020-05-27 17:53:09.721 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=46, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:53:11.704 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10010, state=FAILED, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:11.706 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2020-05-27 17:53:11.708 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete FAILED 1
2020-05-27 17:53:11.711 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: Added transaction to queue, len=2, transaction=ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10017, state=WAITING, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:11.715 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/1: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=10021, state=WAITING, sendCnt=1, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:11.716 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2020-05-27 17:53:11.720 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]
2020-05-27 17:53:11.722 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=86, commandId=11]
2020-05-27 17:53:11.726 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=ED83/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=1A, rssi=--, lqi=--, payload=10 56 0B 0A 00]
2020-05-27 17:53:11.728 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 56 0B 0A 00]
2020-05-27 17:53:11.732 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=47, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 56 0B 0A 00]
2020-05-27 17:53:11.734 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=47, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=1, destinationEndpoint=1, cluster=768, profileId=260, broadcastRadius=0, options=[], data=10 56 0B 0A 00]
2020-05-27 17:53:11.738 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 19 11 2F F0 D1 B8 00 00 02 71 52 ED 83 01 01 03 00 01 04 00 00 10 56 0B 0A 00 8C
2020-05-27 17:53:11.880 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 2F ED 83 00 00 00 D5
2020-05-27 17:53:11.881 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=47, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:53:19.560 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=20022, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:19.562 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2020-05-27 17:53:19.563 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete FAILED 1
2020-05-27 17:53:19.565 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete exceeded retries 2
2020-05-27 17:53:19.568 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction terminated: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=20030, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=55, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:19.570 [DEBUG] [transaction.ZigBeeTransactionManager] - ED83/0: Sending ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=11852, state=WAITING, sendCnt=0, command=MatchDescriptorResponse [0000/0 -> ED83/0, cluster=8006, TID=05, status=SUCCESS, nwkAddrOfInterest=0000, matchList=[1]]]
2020-05-27 17:53:19.572 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2020-05-27 17:53:19.574 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: MatchDescriptorResponse [0000/0 -> ED83/0, cluster=8006, TID=05, status=SUCCESS, nwkAddrOfInterest=0000, matchList=[1]]
2020-05-27 17:53:19.577 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=ED83/0, profile=0000, cluster=8006, addressMode=DEVICE, radius=31, apsSecurity=false, ackRequest=true, apsCounter=1B, rssi=--, lqi=--, payload=05 00 00 00 01 01]
2020-05-27 17:53:19.579 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=0, destinationEndpoint=0, cluster=32774, profileId=0, broadcastRadius=0, options=[], data=05 00 00 00 01 01]
2020-05-27 17:53:19.582 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=48, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=0, destinationEndpoint=0, cluster=32774, profileId=0, broadcastRadius=0, options=[], data=05 00 00 00 01 01]
2020-05-27 17:53:19.584 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=48, ieeeAddress=F0D1B80000027152, networkAddress=60803, sourceEndpoint=0, destinationEndpoint=0, cluster=32774, profileId=0, broadcastRadius=0, options=[], data=05 00 00 00 01 01]
2020-05-27 17:53:19.588 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 1A 11 30 F0 D1 B8 00 00 02 71 52 ED 83 00 00 80 06 00 00 00 00 05 00 00 00 01 01 83
2020-05-27 17:53:19.724 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B 30 ED 83 00 00 00 D4
2020-05-27 17:53:19.725 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=48, networkAddress=60803, transmitRetryCount=0, deliveryStatus=SUCCESS, discoveryStatus=NO_DISCOVERY_OVERHEAD]
2020-05-27 17:53:21.720 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=20026, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:21.722 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2020-05-27 17:53:21.724 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete FAILED 1
2020-05-27 17:53:21.726 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete exceeded retries 2
2020-05-27 17:53:21.729 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction terminated: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=20035, state=FAILED, sendCnt=2, command=DefaultResponse [Color Control: 0000/0 -> ED83/1, cluster=0300, TID=56, commandIdentifier=10, statusCode=SUCCESS]]
2020-05-27 17:53:29.575 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=21856, state=FAILED, sendCnt=1, command=MatchDescriptorResponse [0000/0 -> ED83/0, cluster=8006, TID=05, status=SUCCESS, nwkAddrOfInterest=0000, matchList=[1]]]
2020-05-27 17:53:29.577 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2020-05-27 17:53:29.579 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: transactionComplete FAILED 0
2020-05-27 17:53:29.581 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - F0D1B80000027152: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=F0D1B80000027152 queueTime=21862, state=WAITING, sendCnt=1, command=MatchDescriptorResponse [0000/0 -> ED83/0, cluster=8006, TID=05, status=SUCCESS, nwkAddrOfInterest=0000, matchList=[1]]]
