Thanks Chris,
I have enabled debugging per the ZigBee binding doc, I restated all the bundles that had ZigBee in their names and pushed the button on the device every few seconds for a couple minutes. I checked to see if anything changed, and saved the log and network.xml. There are 3 of them in the Zigbee folder, 2 are really small, I’ve uploaded the biggest, and most recently updated to Dropbox, along with the log file. Before posting, I just rechecked the Things page, and their status is “UNINITIALIZED - HANDLER_INITIALIZING_ERROR” and looking at each device, it still doesn’t have humidity as a channel.
I upgraded the binding and libraries, but when the binding was starting I got an error that the serial port was already in use. Restarting the binding didn’t help, but restarting OH got it running. I’ve never seen this before after an update… maybe just my setup or a one time glitch. We’ll see next time I update.
As for the libraries, everything appears to be functioning so far!
Thanks @5iver. The serial port issue shouldn’t be related to the changes, so I’m gonna put it down to a one off (even if it happens again ).
Let me know if you notice any difference (better or worse) - even if it’s just a feeling…
The serial issue is repeatable.
I also had garbage jars come down… but maybe a build was running.
Strange - looking at the list of changes in the binding, nothing should impact the serial port -:
What was the previous version you were using?
I just recently posted the versions here…
It will be interesting if others see this, or if it is just my setup. I had been using a compiled version of nrjavaserial to get around lock issues, but took that out about a month ago, IIRC. And I thought I’d upgraded a few times since then. I have some more investigation to do… actually, this will be a good one for my wife to look at!
Hello Chris,
no the dimmer isn’t working with the zigbee binding, here is a log.
|18:11:44.<small>810</small>|38703|[<small>RX 84 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18577)|
|18:11:44.<small>820</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18578)|
|18:11:46.<small>829</small>|38703|[<small>RX 87 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18588)|
|18:11:46.<small>853</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18589)|
|18:11:47.<small>614</small>|38703|[<small>TX 9E ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18590)|
|18:11:49.<small>867</small>|38703|[<small>RX 8E ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18603)|
|18:11:49.<small>893</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18604)|
|18:11:51.<small>858</small>|38703|[<small>RX 91 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18610)|
|18:11:51.<small>878</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18611)|
|18:11:52.<small>256</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe72cf68:D0CF5EFFFE72CF68_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18621)|
|18:11:54.<small>822</small>|38703|[<small>RX 98 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18637)|
|18:11:54.<small>835</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18638)|
|18:11:55.<small>614</small>|38703|[<small>TIMEOUT 9E ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18639)|
|18:11:55.<small>630</small>|38703|[<small>TX A2 ReadAttributesCommand cluster=LEVEL_CONTROL **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18640)|
|18:11:56.<small>862</small>|38703|[<small>RX 9B ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18648)|
|18:11:56.<small>892</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18649)|
|18:11:59.<small>891</small>|38703|[<small>RX A2 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18657)|
|18:11:59.<small>925</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18658)|
|18:12:01.<small>868</small>|38703|[<small>RX A5 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18666)|
|18:12:01.<small>894</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18667)|
|18:12:03.<small>162</small>||[<small>COMMAND RECEIVED zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 28 [PercentType]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18672)|
|18:12:03.<small>182</small>|38703|[<small>TX A5 MoveToLevelWithOnOffCommand **level** =71 **transitionTime** =10</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18673)|
|18:12:04.<small>699</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffeb92eb9:000B57FFFEB92EB9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18692)|
|18:12:04.<small>991</small>|38703|[<small>RX AC ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18697)|
|18:12:05.<small>005</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18699)|
|18:12:06.<small>889</small>|38703|[<small>RX AF ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18713)|
|18:12:06.<small>917</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18714)|
|18:12:09.<small>870</small>|38703|[<small>RX B6 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18722)|
|18:12:09.<small>886</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18723)|
|18:12:10.<small>394</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe320172:90FD9FFFFE320172_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18733)|
|18:12:11.<small>182</small>|38703|[<small>TIMEOUT A5 MoveToLevelWithOnOffCommand **level** =71 **transitionTime** =10</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18743)|
|18:12:11.<small>833</small>|38703|[<small>RX B9 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18749)|
|18:12:11.<small>850</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18751)|
|18:12:14.<small>630</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffed5da47:000B57FFFED5DA47_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18768)|
|18:12:14.<small>931</small>|38703|[<small>RX C0 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18774)|
|18:12:14.<small>959</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18775)|
|18:12:15.<small>331</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_colortemperature 50</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18789)|
|18:12:15.<small>671</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18798)|
|18:12:16.<small>549</small>||[<small>COMMAND RECEIVED zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 0 [PercentType]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18808)|
|18:12:16.<small>564</small>|38703|[<small>TX OffCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18809)|
|18:12:16.<small>918</small>|38703|[<small>RX C3 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18816)|
|18:12:16.<small>945</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18817)|
|18:12:19.<small>671</small>|38703|[<small>RX C9 QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18829)|
|18:12:19.<small>819</small>|38703|[<small>RX CB ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18832)|
|18:12:19.<small>832</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18833)|
|18:12:21.<small>873</small>|38703|[<small>RX CE ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18838)|
|18:12:21.<small>898</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18839)|
|18:12:24.<small>564</small>|38703|[<small>TIMEOUT OffCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18847)|
|18:12:24.<small>851</small>|38703|[<small>RX D5 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18850)|
|18:12:24.<small>878</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18851)|
|18:12:26.<small>852</small>|38703|[<small>RX D8 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18857)|
|18:12:26.<small>864</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18858)|
|18:12:30.<small>027</small>|38703|[<small>RX DF ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18865)|
|18:12:30.<small>035</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18866)|
|18:12:31.<small>811</small>|38703|[<small>RX E2 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18873)|
|18:12:31.<small>820</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18874)|
|18:12:34.<small>831</small>|38703|[<small>RX E9 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18886)|
|18:12:34.<small>854</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18887)|
|18:12:36.<small>838</small>|38703|[<small>RX EC ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18892)|
|18:12:36.<small>857</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18893)|
|18:12:37.<small>765</small>|38703|[<small>RX EE QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18899)|
|18:12:37.<small>818</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe0f19b7:90FD9FFFFE0F19B7_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18906)|
|18:12:38.<small>356</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffeb35f9b:D0CF5EFFFEB35F9B_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18923)|
|18:12:39.<small>883</small>|38703|[<small>RX F4 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18937)|
|18:12:39.<small>896</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18939)|
|18:12:41.<small>874</small>|38703|[<small>RX F7 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18953)|
|18:12:41.<small>883</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18954)|
|18:12:44.<small>869</small>|38703|[<small>RX FE ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18967)|
|18:12:44.<small>893</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18969)|
|18:12:46.<small>898</small>|38703|[<small>RX 01 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18978)|
|18:12:46.<small>917</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18979)|
|18:12:49.<small>841</small>|38703|[<small>RX 08 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18991)|
|18:12:49.<small>858</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18992)|
|18:12:51.<small>828</small>|38703|[<small>RX 0B ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18998)|
|18:12:51.<small>841</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-18999)|
|18:12:53.<small>413</small>|38703|[<small>TX C2 ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19003)|
|18:12:54.<small>869</small>|38703|[<small>RX 12 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19013)|
|18:12:54.<small>883</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19014)|
|18:12:55.<small>654</small>|38703|[<small>RX 13 QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19017)|
|18:12:56.<small>174</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe72cf68:D0CF5EFFFE72CF68_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19027)|
|18:12:56.<small>827</small>|38703|[<small>RX 16 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19037)|
|18:12:56.<small>841</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19038)|
|18:12:59.<small>826</small>|38703|[<small>RX 1D ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19048)|
|18:12:59.<small>843</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19049)|
|18:13:01.<small>413</small>|38703|[<small>TIMEOUT C2 ReadAttributesCommand cluster=ON_OFF **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19052)|
|18:13:01.<small>418</small>|38703|[<small>TX C6 ReadAttributesCommand cluster=LEVEL_CONTROL **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19053)|
|18:13:01.<small>819</small>|38703|[<small>RX 20 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19060)|
|18:13:01.<small>827</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19061)|
|18:13:04.<small>914</small>|38703|[<small>RX 27 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19076)|
|18:13:04.<small>940</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19078)|
|18:13:04.<small>996</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffeb92eb9:000B57FFFEB92EB9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19084)|
|18:13:06.<small>831</small>|38703|[<small>RX 2A ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19097)|
|18:13:06.<small>846</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19098)|
|18:13:09.<small>418</small>|38703|[<small>TIMEOUT C6 ReadAttributesCommand cluster=LEVEL_CONTROL **identifiers** =[0]</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19103)|
|18:13:09.<small>853</small>|38703|[<small>RX 31 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19106)|
|18:13:09.<small>871</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19107)|
|18:13:10.<small>970</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe320172:90FD9FFFFE320172_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19116)|
|18:13:11.<small>842</small>|38703|[<small>RX 34 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19134)|
|18:13:11.<small>859</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19135)|
|18:13:14.<small>827</small>|38703|[<small>RX 3B ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19143)|
|18:13:14.<small>845</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19144)|
|18:13:16.<small>477</small>||[<small>STATE UPDATE zigbee:device:05001B6B:000b57fffed5da47:000B57FFFED5DA47_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19155)|
|18:13:16.<small>975</small>|38703|[<small>RX 3E ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19170)|
|18:13:16.<small>991</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19172)|
|18:13:17.<small>624</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_colortemperature 50</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19181)|
|18:13:17.<small>924</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffe1fa5e9:D0CF5EFFFE1FA5E9_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19191)|
|18:13:19.<small>840</small>|38703|[<small>RX 45 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19205)|
|18:13:19.<small>865</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19206)|
|18:13:21.<small>822</small>|38703|[<small>RX 48 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19212)|
|18:13:21.<small>829</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19213)|
|18:13:24.<small>833</small>|38703|[<small>RX 4F ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19221)|
|18:13:24.<small>849</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19222)|
|18:13:26.<small>830</small>|38703|[<small>RX 52 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19228)|
|18:13:26.<small>844</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19229)|
|18:13:29.<small>854</small>|38703|[<small>RX 59 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19240)|
|18:13:29.<small>865</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19241)|
|18:13:31.<small>826</small>|38703|[<small>RX 5C ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19247)|
|18:13:31.<small>841</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19248)|
|18:13:34.<small>849</small>|38703|[<small>RX 63 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19263)|
|18:13:34.<small>872</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19264)|
|18:13:36.<small>830</small>|38703|[<small>RX 66 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19270)|
|18:13:36.<small>843</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19272)|
|18:13:39.<small>828</small>|38703|[<small>RX 6D ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19282)|
|18:13:39.<small>846</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19283)|
|18:13:41.<small>872</small>||[<small>STATE UPDATE zigbee:device:05001B6B:90fd9ffffe0f19b7:90FD9FFFFE0F19B7_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19295)|
|18:13:42.<small>145</small>|38703|[<small>RX 70 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19302)|
|18:13:42.<small>153</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19304)|
|18:13:42.<small>209</small>||[<small>STATE UPDATE zigbee:device:05001B6B:d0cf5efffeb35f9b:D0CF5EFFFEB35F9B_1_dimmer OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19313)|
|18:13:44.<small>659</small>|38703|[<small>RX 76 QueryNextImageCommand</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19335)|
|18:13:44.<small>830</small>|38703|[<small>RX 78 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19338)|
|18:13:44.<small>844</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19339)|
|18:13:46.<small>826</small>|38703|[<small>RX 7B ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19348)|
|18:13:46.<small>839</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19349)|
|18:13:49.<small>860</small>|38703|[<small>RX 82 ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19357)|
|18:13:49.<small>874</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19358)|
|18:13:51.<small>860</small>|38703|[<small>RX 85 ReportAttributesCommand cluster=LEVEL_CONTROL</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19365)|
|18:13:51.<small>873</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19366)|
|18:13:54.<small>843</small>|38703|[<small>RX 8C ReportAttributesCommand cluster=ON_OFF</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19375)|
|18:13:54.<small>863</small>||[<small>STATE UPDATE zigbee:device:05001B6B:00158d0002927954:00158D0002927954_1_dimmer 100</small>](https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer#info-19376)|
I’ve noticed the same too, but in my case it seems to only be one of my three color bulbs. The other two don’t have this issue for some reason.
This is still being worked on, but UNDEF will be displayed in future when a color bulb is in CT mode.
Chris - if that is the case - how are we supposed to know if a bulb is on or not / get the brightness?
(my angle: I use a rule that auto adjusts CT throughout the day so I have daylight cool white during the day and then it shifts at night to warm white based on either the actual sunset or my alarm clock for the next day - whichever is earlier. Because of that I loop through and update the CT value for online bulbs only to save on network traffic/ If a bulb receives a change in CT i believe it powers up. My guess is that whenever offline I would still aways get a 0,0,0 from the color item? I think thats what I’ve noticed so at it least prevents me from sending the signal to offline bulbs still. My workaround has been to just send the CT whenever I get an UNDEF color item state)
You would need to look at the CT channel I guess. This will work the same - if the bulb is in Color mode then the CT channel will show UNDEF. This is what was implemented for the Hue binding so the Qivicon guys also make the change in the ZigBee binding.
CT is also a dimmer so it will also be able to show the on off state.
Ah ok - that makes sense then I guess… so when offline Color item should show 0,0,0 ? I am a bit confused as to how we can get any information out of the CT item though as the Dimmer is for the CT only showing warm(100) to cool(0) - where would the brightness or on/off info be stored in that item - would we just need to cast it to something to get that info?
No - I believe it would show UNDEF as it is undefined.
Good question - this is probably missing
Maybe it is worth discussing this further on the github issues -:
I don’t really think OH has a good concept for CT channels so maybe this requires more discussion in general.
Strangely, my bulbs (IKEA of Sweden TRADFRI bulb E26 CWS opal 600lm) don’t have a CT channel, only color so i’m not sure if they support CT. There also used to be a separate dimmer and switch channels but those went away with one of the binding updates.
Yes - that is correct. This was removed quite a long time ago. There will now only be a dimmer, and not a dimmer and a switch as it is not needed to have both (and against OH rules).
What about the CT channel though? I see reference above to a separate channel for that in which the CT channel would have a value when in temperature mode (setting the color channel to UNDEF) and when color is set, the CT channel is set to UNDEF - or am I misunderstanding? Just trying to wrap my head around under what circumstances my bulbs would be going into a CT mode when they only support Color and not Color Temperature from what I understand.
This is a separate channel - there will be two channels - color and color temperature. When in color mode, CT is set to UNDEF and vice versa.
I think your confusion lies in that the remaining dimmer and color channel that Chris is referring to is actually the CT channel dimmer.
The issue with this is that we lose all visibility into the brightness dimmer and therefore on/off state as well whenever we are in CT mode as Color channel goes undef and CT can only indicate color temperature
So that’s for a future binding version then? My confusion is that I only have a color channel and no other channels, yet my color channel is still going to UNDEF at times
Hi @chris,
Regarding this CT / Color topic, could you please have a look at Fix color control channel updates #386.
This might be addressing part of the CT vs non-CT issues on the Color channel.
This also fixes an issue from an old commit I saw while checking it (I can’t recall from whom) that replaced float point inequality comparisons on the channel with < .00001 or something like that, but the sign of the comparison was inverted, so it is hardly possible that the color channel was working propertly after that commit.
Pedro
