I have the same issue with the 1/7 binding and my husbzb-1. My zigbee devices stop responding after a few hours (ST plugs) . I just moved back to a PI3 and a fresh install of 2.2 release (with the 1/7 zigbee binding) and it still happens.
And it is pretty much what I was reporting here and seems similar to what weakfl and BClark have logged here.
Commands to lamps are not getting through, but I can still see lamps go offline when I remove power, and my Hue motion sensor keeps working perfectly. So Zigbee seems to be working for incoming status updates, but no commands seem to be getting out any more.
I am on the Husbzb, so is Mike_Bagdanoff, weakfl is using Telegesis, and ScottKinSF is using a TI dongle. I am running Windows 10, the others Raspi and maybe linux. So it is not dependent on hardware or OS. It seems to resolve for a while after restarting the binding and the java serial component. So something is amiss there, which causes messages not to get sent.
Thanks for the ST Motion sensors, I just bought 3 on my last visit to the US!
Sorry, but without looking at real data, you simply can not say they are the same. I can say 100% for sure that the issue reported by @scottk is totally different to what is reported by @weakfl which is an issue with the Telegesis driver, and is also different to the issue you have reported.
Or just maybe, as above, they are all totally different issues (this is the case). This is why I prefer people to report the problem they have, rather than just to say âI have the same problemâ - often issues are not the same even if outwardly they might look the same (in this case, the outward sign is just that devices stop workingâŠ).
That was my fault, sorry. I just saw a growing queue in @AFromDâs log an thought it must be the same issue.
On closer examination, the log messages are different:
Itâs not a problem - and I know itâs very easy to do . Itâs one of my little niggles when people send a âI have the same problemâ email, or âI changed X and it stopped everything workingâ (or that sort of thing) - often without any information to back up the issue.
Logs are my friend - they only supply the facts (even if not all of them sometimes)
Looking much more stable in my system now! Thanks! I have full control over all my bulbs for a few hours at a time now, after then itâs back to no response until I restart openHAB (I canât seem to reset the binding on itâs own as the Telegesis thing doesnât come back online). Will try to get some more logs for you when I can!
I fully reset my zigbee stick (husbzb-1) and re-paired my 3 ST outlets. I then was able to pair one of my ST motion sensors and one of my ST contact sensors. Everything seems to be working fine as of this moment but I have turned debug logging on and Iâll see if it all fails after a few hours then I can send the logs.
Some observations:
- The âContact Portal 1â channel of the ST Contact sensor is defined as a Switch and should probably be defined as a Contact
- The Temperature channels are hard-coded to celsius, so adding a configuration like zwave devices would be nice
- Motion Presence and Motion Intrusion are both switches, and half of my Zwave Motion sensors are Switches for the sensor_binary channel and half are Contacts so Iâm not sure which is right.
- Battery Level reports would be nice as well
Thanks for getting this working! I have a bunch of these sensors that are no longer a waste of money
Just got a Telegesis stick. When I add it as a thing it seems to initialize correctly but I see no output when trying to connect a zigbee device. Just a âstarting zigbee scanâ and nothing further.
2018-01-09 00:55:42.294 [DEBUG] [zigbee.internal.ZigBeeHandlerFactory] - Creating coordinator handler for org.eclipse.smarthome.core.thing.internal.BridgeImpl@6556d3c7
2018-01-09 00:55:42.299 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Creating ZigBee discovery service for zigbee:coordinator_telegesis:05be6620
2018-01-09 00:55:42.305 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Activating ZigBee discovery service for zigbee:coordinator_telegesis:05be6620
2018-01-09 00:55:42.317 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=406, service.bundleid=254, service.scope=singleton} - org.openhab.binding.zigbee
2018-01-09 00:55:42.338 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.firmware.FirmwareUpdateHandler}={service.id=407, service.bundleid=254, service.scope=singleton} - org.openhab.binding.zigbee
2018-01-09 00:55:42.441 [DEBUG] [er.ZigBeeCoordinatorTelegesisHandler] - Initializing ZigBee Telegesis serial bridge handler.
2018-01-09 00:55:42.444 [hingStatusInfoChangedEvent] - âzigbee:coordinator_telegesis:05be6620â changed from UNINITIALIZED to INITIALIZING
2018-01-09 00:55:42.446 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_telegesis:05be6620].
2018-01-09 00:55:42.450 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel -1
2018-01-09 00:55:42.454 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 0
2018-01-09 00:55:42.458 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 0000000000000000
2018-01-09 00:55:42.461 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key null
2018-01-09 00:55:42.465 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising network
2018-01-09 00:55:42.470 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Created random ZigBee PAN ID [F8CC].
2018-01-09 00:55:42.557 [me.event.ThingUpdatedEvent] - Thing âzigbee:coordinator_telegesis:05be6620â has been updated.
2018-01-09 00:55:42.559 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Created random ZigBee extended PAN ID [93636C7FAAFE233F].
2018-01-09 00:55:42.645 [me.event.ThingUpdatedEvent] - Thing âzigbee:coordinator_telegesis:05be6620â has been updated.
2018-01-09 00:55:44.528 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key String
2018-01-09 00:55:44.527 [me.event.ThingUpdatedEvent] - Thing âzigbee:coordinator_telegesis:05be6620â has been updated.
2018-01-09 00:55:44.533 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialised 380F0CF53891D68D96EE13CB7684133E
2018-01-09 00:55:44.539 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key final array 380F0CF53891D68D96EE13CB7684133E
2018-01-09 00:55:44.545 [DEBUG] [er.ZigBeeCoordinatorTelegesisHandler] - ZigBee Coordinator Telegesis opening Port:â/dev/ttyUSB1â PAN:f8cc, EPAN:93636C7FAAFE233F, Channel:-1
2018-01-09 00:55:44.555 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2018-01-09 00:55:44.567 [hingStatusInfoChangedEvent] - âzigbee:coordinator_telegesis:05be6620â changed from INITIALIZING to UNKNOWN
2018-01-09 00:55:44.577 [nt.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:coordinator_telegesis:05be6620 changed to UNKNOWN.
2018-01-09 00:55:45.558 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2018-01-09 00:55:45.562 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2018-01-09 00:55:45.567 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialise 380F0CF53891D68D96EE13CB7684133E
2018-01-09 00:55:45.576 [DEBUG] [ing.zigbee.internal.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB1] at 19200 baud, flow control FLOWCONTROL_OUT_NONE.
2018-01-09 00:55:45.593 [DEBUG] [ing.zigbee.internal.ZigBeeSerialPort] - Serial port [/dev/ttyUSB1] is initialized.
2018-01-09 00:55:46.651 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: done.
2018-01-09 00:55:46.654 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - initResponse is JOINED
2018-01-09 00:55:46.659 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - initializeNetwork is true
2018-01-09 00:55:48.219 [hingStatusInfoChangedEvent] - âzigbee:coordinator_telegesis:05be6620â changed from UNKNOWN to OFFLINE: zigbee.status.offline_startupfail
2018-01-09 00:55:51.415 [hingStatusInfoChangedEvent] - âzigbee:coordinator_telegesis:05be6620â changed from OFFLINE: zigbee.status.offline_startupfail to ONLINE
2018-01-09 00:55:53.239 [me.event.ThingUpdatedEvent] - Thing âzigbee:coordinator_telegesis:05be6620â has been updated.
2018-01-09 00:55:53.250 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: done.
2018-01-09 00:55:53.340 [me.event.ThingUpdatedEvent] - Thing âzigbee:coordinator_telegesis:05be6620â has been updated.
2018-01-09 00:58:40.430 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_telegesis:05be6620
Some Zigbee devices can be quite picky to connect. You usually have to reset them in some way, and make sure the scan is active before you actually do it. I have an osram socket that will only associate right when connecting it to power, and hue lamps that had been connected before need to be reset with the dimmer remote before they will connect with something else.
I reset my device (Lowes Iris motion sensor v2) and expected to see at least some output. Is there a way to enable deeper logging? I set org.openhab.bindings.zigbee to DEBUG but Iâm not sure what else to do.
But be prepared for massive amounts of data⊠and set them back to WARN when your done debugging.
This has a typo, so may explain not getting anything in the log.
Ah I didnât know to enable com.zsmartsystems.zigbee for debug logging. I already had the zigbee binding debug working. I get some more info now when starting discovery but no apparent communication with my device. I tried both the a SmartThings motion sensor and a Lowes Iris v2 motion sensor. The logging from discovery is always the same, apparently no communication. Both were fully reset when trying to pair. (I am on the 2.3 snapshot build btw)
018-01-09 16:25:35.961 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_telegesis:05be6620
2018-01-09 16:25:35.968 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Permit join to 65532/0 for 60 seconds.
2018-01-09 16:25:35.974 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0/0 -> 65532/0, cluster=0036, TID=73, permitDuration=60, tcSignificance=true]
2018-01-09 16:25:35.980 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=65532/0, profile=0000, cluster=54, addressMode=DEVICE, radius=31, sequence=115, payload=00 3C 01]
2018-01-09 16:25:35.986 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendMulticastCommand [radius=31, address=65532, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01]
2018-01-09 16:25:35.992 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1164
2018-01-09 16:25:35.998 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0/0 -> 0/0, cluster=0036, TID=74, permitDuration=60, tcSignificance=true]
2018-01-09 16:25:36.003 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=54, addressMode=DEVICE, radius=31, sequence=116, payload=00 3C 01]
2018-01-09 16:25:36.008 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01, messageId=null]
2018-01-09 16:25:36.012 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1165
Hi Chris,
Just wondering of there was any update on adding support to Conbee/Raspbee
BR
Sergi
@imagio please use code fences when pasting logs into the forum so they are readable.
No - typically if the join doesnât work, then there is no information coming from the stick, so there is simply nothing to log.
No - recently. Iâve been busy working on the other coordinators and general binding issues/improvements. If someone wants to look at it then please feel free
Thatâs unfortunate. I canât found any telegesis ETRX3 on sale. Only with a developer kit that costs more than 300âŹ. Unfortunately my programing skills are not really good and Java was one of my most hated languages. I always prefered assembler.
I think I will stay with the deconz softwware that at least works.
They are reasonably easily available in most countries (but not all). Where are you located?
Spain. I was searching telegesis etrx3 and only found the kit. Now Iâm searching for etrx3 usb and I have found more options.
Is this one working? ETRX357USB+8M
Yes - should be fine.
@chris Does that mean that my devices (Iris motion v2 and SmartThings motion) canât work with the telegesis stick or is more data about the devices needed to get them to communicate?
What do you mean specifically? I donât know quite what youâre referring to, but I think it should be fine. It certainly works fine with an ST motion sensor.
