Good to know, thanks.
I have OH 2.3 running on X86 computer with MINT 18.
The zigbee Binding is: binding-zigbee - 2.3.0
Is OH 2.4 an unstable version?
and how do you stop the binding?
Just uninstall and then reinstall? Or…??
log into the karaf console: openhab-cli console (in my case of a normal linux apt install) from there you can do ‘bundle:list | grep -i zig’ to get the zigbee bundle ids. next just run ‘bundle:restart id’ where id is the number obtained from the bundle list command.
It depends on what the meaning of “unstable” is. I’ve been running the 2.4.0-SNAPSHOT series for some time now with only a few problems along the way. Right now 2.4.0-S1445 has been very solid with the bindings and rules I have. If you’re leery of the 2.4.0-SNAPSHOTS, you may want to consider one of the milestone releases. I haven’t tried installing a 2.4.0 milestone release myself, so someone else will have to make a recommendation for a specific milestone release.
As for stopping the binding, I stop and uninstall the Zigbe Binding bundle using the karaf console:
openhab> bundle:list | grep -i zigbee
204 │ Active │ 80 │ 1.1.2 │ com.zsmartsystems.zigbee
205 │ Active │ 80 │ 1.1.2 │ com.zsmartsystems.zigbee.dongle.cc2531
206 │ Active │ 80 │ 1.1.2 │ com.zsmartsystems.zigbee.dongle.ember
207 │ Active │ 80 │ 1.1.2 │ com.zsmartsystems.zigbee.dongle.telegesis
208 │ Active │ 80 │ 1.1.2 │ com.zsmartsystems.zigbee.dongle.xbee
261 │ Active │ 80 │ 2.4.0.201811281515 │ ZigBee Binding
262 │ Active │ 80 │ 2.4.0.201811281515 │ ZigBee CC2531 Binding
263 │ Active │ 80 │ 2.4.0.201811281515 │ ZigBee Ember Binding
264 │ Active │ 80 │ 2.4.0.201811281515 │ ZigBee Telegesis Binding
265 │ Active │ 80 │ 2.4.0.201811281515 │ ZigBee XBee Binding
openhab> bundle:stop 261
openhab> bundle:uninstall 261
As root, stop openhab (SSH session on my RPi 3B:
sudo systemctl stop openhab2
Then install the newer version of openHAB that you have decided on, after which you should clear the contents of openHAB’s cache and tmp directories. On openHABian:
sudo rm -rf /var/lib/openhab2/{cache,tmp}/*
Beware if you use the Z-Wave binding, there are major changes when going from pre-2.4.0 to 2.4.0 releases. Search this forum for more information.
Good luck!
Technically, yes, it is termed unstable…
However, what is the difference? The release versions are simply the “unstable” version with a different name. One day in time, the unstable version gets a new name, and everyone thinks it is magically bug free
Thats the days bugs are discovered
the difference is, to know which repositorie i have to install
It depends on what system you are running as to exactly how to update it.
I was just pointing out that people seem to think that the “stable” version is magically bug free but the reality is there is no long period of testing to turn an “unstable” version into a “stable” version. Therefore, IMHO there is little difference in using the stable or unstable.
no problem , i guess i know how to update
Point noticed.
My main concern for updates is, wether it´s backward compatible, and what I might need to change (how much work to do to things noone thought of). Openhab isn´t just a one simple package. It influence lots of stuff.
I dont expect see a full detailed list of all changes which will influence my specific system. But because of that, I know there is a risc, that when I do update, I may find myself dealing with and trying to fix things noone thought of, tried or discovered yet. It becomes kinda like the quote: “Dont try fix whats already working” dilemma.
Right now this is what keeping me from updating my main system. Only one good solution: Backup´s
I’m not sure if the issue regarding handling of the OnOff command on a dimmer Item has been addressed already. In the latest snapshot the behaviour is at least different. If I now switch on a lamp which was switched off at 50% level. It initially switches on at the previous leve, but after that directly setting the level to 100% again:
This is a separate issue that I’ve created a PR for already.
Hey Chris - I’ve just tried updating my zsmart to the newest libraries (i was on 1.1.4) and it seems any time I do 1.1.5 or above I have issues with the system. I can get my coordinator online but none of the devices come online. Debug just shows coordinator traffic and paperui says ‘node not found on network’ attached is a copy of the 1.1.5 error instance that spit out a very clear error message before dying. I’ve also included a screenshot of the binding/zsmartsystemversions that were running at the time. Let me know if there is something I need to do on my end to resolve this. Thank you!
openhab_1.1.5.log (151.8 KB)Yes, you will have problems if you do this as there are some changes to the API due to some refactoring.
See the following PR which will be merged once the TP is updated.
Since updating to M8 I’ve noticed difficulty with some bulbs and poor performance (very chatty zigbee network visible via debug) / If I add and remove a bulb it seems to revert back to the 0 is cool white 100 is warm. Does that update require me to remove/rejoin bulbs or are there any known performance issues. Everything does seem to ultimately work and I can try to get some logs later this weekend when i have a bit more time (for now i’ve reverted back to the 1.1.4 on m7)
It should be the same as before.
Color temperature was swapped around to be consistent with ESH definition. Also, the color temperature channel was changed as this is now defined as a system channel by ESH.
No. You might want to delete the thing and add it back so that it uses the new color temp channel.
Please don’t - M8 will become 2.4 in a few days time, and using a different version really isn’t going to solve any issues if there are any. Please try and work out what problems you have and report them.
I agree thank you - I just reverted since I didn’t have time to work on it further and needed it stable. I’ll give a try this weekend with deleting things and rejoining them and let you know if I have any issues.
A complete reinstallation of OH resolved my problems for some days - till yesterday: using XBee stick and ubuntu server 18.04.01 I cannot get this coordinator online anymore. Did another fresh install and here are the logs (trying different parameters)
Has anyone similar problems?
openhab> list |grep -i zig
200 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee
201 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
202 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
203 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
204 │ Active │ 80 │ 1.1.6 │ com.zsmartsystems.zigbee.dongl
211 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee Binding
212 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee CC2531 Binding
213 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee Ember Binding
214 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee Telegesis Binding
215 │ Active │ 80 │ 2.4.0.201812110506 │ ZigBee XBee Binding
openhab> log:tail
17:57:32.767 [INFO ] [rthome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
17:57:33.187 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.50.30:8080
17:57:33.188 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.50.30:8443
17:57:44.244 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘package-standard’ has been installed.
17:57:45.348 [INFO ] [mebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
17:57:45.380 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
17:57:45.513 [INFO ] [marthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
17:57:45.528 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-homebuilder’ has been installed.
17:57:45.532 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-basic’ has been installed.
17:57:45.533 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-habpanel’ has been installed.
17:57:45.533 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘ui-paper’ has been installed.
17:58:09.255 [INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘binding-zigbee’ has been installed.
17:59:04.902 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zigbee:coordinator_xbee:69e57f59’ changed from UNINITIALIZED to INITIALIZING
17:59:04.909 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:04.913 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:04.929 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:04.942 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zigbee:coordinator_xbee:69e57f59’ changed from INITIALIZING to UNKNOWN
17:59:11.038 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:24.038 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:24.078 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zigbee:coordinator_xbee:69e57f59/config’
at com.zsmartsystems.zigbee.app.discovery.ZigBeeDiscoveryExtension.extensionShutdown(ZigBeeDiscoveryExtension.java:96) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.shutdown(ZigBeeNetworkManager.java:529) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.dispose(ZigBeeCoordinatorHandler.java:303) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.handleConfigurationUpdate(ZigBeeCoordinatorHandler.java:554) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:91) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:438) [120:org.eclipse.smarthome.io.rest.core:0.10.0.201812091851]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
17:59:53.361 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
17:59:53.389 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zigbee:coordinator_xbee:69e57f59/config’
18:00:24.703 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zigbee:coordinator_xbee:69e57f59’ has been updated.
18:00:24.717 [ERROR] [est.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zigbee:coordinator_xbee:69e57f59/config’
