We can add this to the binding documentation, but clearly the designers of this stick clearly did not want people to use it outside of their software and it is not supported by many OS’s by default. Also, the VID, or at least the PID may change, so I think there is no 100% way to guarantee this.
Please feel free to create a PR to the docs though .
New in recent zigbee versions I’ve got a smart outlet that the active power channel is no longer updating. From the logs you can see everything come online - it says it initiates polling of the activepower channel/requests the data but I never see the data come back and the value stays null. This was working previously. Unfortnately I’m not exactly certain when it stopped working - I know it was possibly around the zigbee release where this device switched to exposing a dimmer channel rather than a switch channel. 286d97000100a0d1 is the id of the device in question - it is a Samjin outlet. (samsung smartthings outlet). Let me know if I can get you any other information.
As a side note I too am experiencing that error setting server binding mentioned above on two of my smart outlets and one switch controller - though each of these appear to operate correctly. I can try to get logs on that as well if more are needed.
Hi Chris - I’ve attached a copy of logs showing the failed server binding message.
Re the message above: I noticed that this stopped working on the 15th of this month via persistence database… that was shortly after I upgraded to M8 (did that a few hours prior to that) Anyway - do you think its possible its started detecting a different attribute type? I can try to look for old logs if you can give me a pointer to where all of the attributes are listed perhaps? Otherwise I’m really at a loss about this. Only other thing i can thing is perhaps an over the air update occurred on the device? Thanks for all of your help!
Without logs showing what was working, I don’t know. All I can say is that the converter hasn’t changed for 11 months. This is where the attribute is defined, so I think I can safely say that the binding isn’t any different in this respect.
I’d just need to see logs of what he binding was sending when polling (so 30 minutes of logs should do).
Chris - I’ve got some logs for you. I’ve got an extra telegesis coordinator laying around so I just did a quick fresh install of openhab 2.3.0 release and added the device. the link below will take you to the log file showing the active power channel working. Thanks so much!
Thanks. It looks to me like this is not a major issue. It looks like the bind is working ok, but the system is not properly correlating the response, so we are seeing this error. I will take a look at this, but I do see a positive response from the device.
These are the error messages in the log file after reboot:
2018-12-20 21:36:52.369 [ERROR] [org.apache.felix.scr ] - bundle org.apache.felix.scr:2.1.2 (39)Circular reference detected trying to get service {org.eclipse.smarthome.io.net.http.TrustManagerProvider}={service.id=124, service.bundleid=192, service.scope=bundle, component.name=org.openhab.binding.icloud.internal.to_be_moved.TrustManagerProviderImpl, component.id=15}
stack of references: ServiceReference: {org.eclipse.smarthome.io.net.http.TrustManagerProvider}={service.id=124, service.bundleid=192, service.scope=bundle, component.name=org.openhab.binding.icloud.internal.to_be_moved.TrustManagerProviderImpl, component.id=15}
ServiceReference: {org.eclipse.smarthome.io.net.http.HttpClientFactory, org.eclipse.smarthome.io.net.http.WebSocketFactory}={service.id=153, service.bundleid=118, service.scope=bundle, component.name=org.eclipse.smarthome.io.net.http.internal.WebClientFactoryImpl, component.id=43}
2018-12-20 21:37:52.025 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.thingUpdated()' on 'org.openhab.binding.zigbee.telegesis.handler.TelegesisHandler@466cc8': null
at com.zsmartsystems.zigbee.app.discovery.ZigBeeDiscoveryExtension.extensionShutdown(ZigBeeDiscoveryExtension.java:96) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.shutdown(ZigBeeNetworkManager.java:529) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.dispose(ZigBeeCoordinatorHandler.java:303) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:206) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.thingUpdated(ZigBeeCoordinatorHandler.java:315) ~[?:?]
at org.openhab.binding.zigbee.telegesis.handler.TelegesisHandler.thingUpdated(TelegesisHandler.java:86) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
2018-12-20 21:38:01.198 [ERROR] [ngle.telegesis.ZigBeeDongleTelegesis] - Unable to configure Telegesis dongle
Can you describe your problem - does anything work at all, or is it just that the switches don’t work?
This error is logged during the shutdown of the binding - it has already been fixed, but I’m not sure it should matter given it’s during the shutdown. You could try updating the libraries to 1.1.7 using @5ivers update script as it should stop this error.
