OH2.1, zigbee binding 2.2.0.201706290942, HUSBZB-1 (Silicon Labs EM3581, EmberZNet Pro 5.4)
The Coordinator is stuck at Initializing:
2017-06-30 07:30:55.602 [zigbee ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee
2017-06-30 07:30:55.617 [zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.zigbee.internal.ZigBeeHandlerFactory, component.id=8, service.id=115, service.bundleid=220, service.scope=bundle} - org.openhab.binding.zigbee
2017-06-30 07:30:55.624 [zigbee ] - BundleEvent STARTING - org.openhab.binding.zigbee
2017-06-30 07:30:55.625 [zigbee ] - BundleEvent STARTED - org.openhab.binding.zigbee
2017-06-30 07:30:58.218 [zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.ConfigOptionProvider, org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={component.name=org.openhab.binding.zigbee.internal.ZigBeeConfigProvider, component.id=9, service.id=182, service.bundleid=220, service.scope=bundle} - org.openhab.binding.zigbee
2017-06-30 07:30:58.242 [zigbee ] - ServiceEvent REGISTERED - {org.openhab.binding.zigbee.internal.ZigBeeConfigProvider}={component.name=org.openhab.binding.zigbee.ConfigDescription, component.id=10, service.id=183, service.bundleid=220, service.scope=bundle} - org.openhab.binding.zigbee
2017-06-30 08:50:56.515 [ZigBeeHandlerFactory ] - Creating coordinator handler for org.eclipse.smarthome.core.thing.internal.BridgeImpl@b5982076
2017-06-30 08:50:56.566 [BeeCoordinatorEmberHandler] - Initializing ZigBee Ember serial bridge handler.
2017-06-30 08:50:56.566 [ZigBeeCoordinatorHandler ] - Initializing ZigBee network [zigbee:coordinator_ember:f8d7abbc].
2017-06-30 08:50:56.566 [ZigBeeCoordinatorHandler ] - Channel -1
2017-06-30 08:50:56.567 [ZigBeeCoordinatorHandler ] - PANID 0
2017-06-30 08:50:56.567 [ZigBeeCoordinatorHandler ] - EPANID 0000000000000000
2017-06-30 08:50:56.568 [ZigBeeCoordinatorHandler ] - Key 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2017-06-30 08:50:56.569 [ZigBeeCoordinatorHandler ] - Initialising network
2017-06-30 08:50:56.569 [ZigBeeCoordinatorHandler ] - Created random ZigBee PAN ID [8E9A].
2017-06-30 08:51:01.574 [ZigBeeCoordinatorHandler ] - Created random ZigBee extended PAN ID [7DAFAD7D5A1F3B92].
2017-06-30 08:51:01.653 [ZigBeeCoordinatorHandler ] - Key String 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2017-06-30 08:51:01.655 [ZigBeeCoordinatorHandler ] - Key array [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
2017-06-30 08:51:01.657 [ZigBeeCoordinatorHandler ] - Creating random ZigBee network key.
2017-06-30 08:51:01.739 [ZigBeeCoordinatorHandler ] - Created random ZigBee network key.
2017-06-30 08:51:01.744 [ZigBeeCoordinatorHandler ] - Key initialised String 36 1C C4 8A 1E 1E 27 7B EB FC 0A D9 96 B2 B6 AA
2017-06-30 08:51:01.745 [ZigBeeCoordinatorHandler ] - Key initialised array [54, 28, 196, 138, 30, 30, 39, 123, 235, 252, 10, 217, 150, 178, 182, 170]
2017-06-30 08:51:01.745 [ZigBeeCoordinatorHandler ] - Key final array [54, 28, 196, 138, 30, 30, 39, 123, 235, 252, 10, 217, 150, 178, 182, 170]
2017-06-30 08:51:01.764 [BeeCoordinatorEmberHandler] - ZigBee Coordinator Ember opening Port:'/dev/ttyUSB1' PAN:8e9a, EPAN:7DAFAD7D5A1F3B92, Channel:-1
2017-06-30 08:51:01.767 [ZigBeeCoordinatorHandler ] - Scheduling ZigBee start
2017-06-30 08:51:02.768 [ZigBeeCoordinatorHandler ] - ZigBee network starting
2017-06-30 08:51:02.769 [ZigBeeCoordinatorHandler ] - Initialising ZigBee coordinator
2017-06-30 08:51:02.770 [ZigBeeDiscoveryService ] - Creating ZigBee discovery service for zigbee:coordinator_ember:f8d7abbc
2017-06-30 08:51:02.771 [ZigBeeDiscoveryService ] - Activating ZigBee discovery service for zigbee:coordinator_ember:f8d7abbc
2017-06-30 08:51:02.774 [zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=447, service.bundleid=220, service.scope=singleton} - org.openhab.binding.zigbee
2017-06-30 08:51:02.802 [ZigBeeCoordinatorHandler ] - Key initialise [54, 28, 196, 138, 30, 30, 39, 123, 235, 252, 10, 217, 150, 178, 182, 170]
2017-06-30 08:51:02.803 [ZigBeeDongleEzsp ] - EZSP dongle initialize.
2017-06-30 08:51:02.805 [BeeCoordinatorEmberHandler] - Connecting to serial port [/dev/ttyUSB1]
2017-06-30 08:51:02.845 [BeeCoordinatorEmberHandler] - Serial port [/dev/ttyUSB1] is initialized.
2017-06-30 08:51:02.871 [AshFrameHandler ] - Trying to send when not connected.
And OH will crash hard when the binding is stopped (let me know if youāre interested in the core dump):
get_java_var: invalid file descriptor
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007ff7eb8f47d5, pid=2667, tid=0x00007ff7e530a700
# JRE version: OpenJDK Runtime Environment (8.0_131-b12) (build 1.8.0_131-b12)
# Java VM: OpenJDK 64-Bit Server VM (25.131-b12 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libNRJavaSerial.so+0x77d5] read_byte_array+0x55
# Core dump written. Default location: /opt/openhab2/userdata/core or core.2667
# An error report file with more information is saved as:
# /opt/openhab2/userdata/hs_err_pid2667.log
Compiled method (c2) 1696268 14685 s! 4 gnu.io.RXTXPort$SerialInputStream::read (98 bytes)
total in heap [0x00007ff83b1f2c10,0x00007ff83b1f3b38] = 3880
relocation [0x00007ff83b1f2d38,0x00007ff83b1f2dd8] = 160
main code [0x00007ff83b1f2de0,0x00007ff83b1f33c0] = 1504
stub code [0x00007ff83b1f33c0,0x00007ff83b1f3420] = 96
oops [0x00007ff83b1f3420,0x00007ff83b1f3428] = 8
metadata [0x00007ff83b1f3428,0x00007ff83b1f3498] = 112
scopes data [0x00007ff83b1f3498,0x00007ff83b1f38b0] = 1048
scopes pcs [0x00007ff83b1f38b0,0x00007ff83b1f3a60] = 432
dependencies [0x00007ff83b1f3a60,0x00007ff83b1f3a70] = 16
handler table [0x00007ff83b1f3a70,0x00007ff83b1f3ae8] = 120
nul chk table [0x00007ff83b1f3ae8,0x00007ff83b1f3b38] = 80
On a positive note, I transferred primary controller from a zstick to the zwave side (using OZW and Zensys), then transferred SIS/SUC, and everything seems good after changing the associations to the new controller!
