- Platform information:
- Hardware: Pi 4
- OS: Openhabian
- Java Runtime Environment: Java 17
- openHAB version: 4.2.2
- Issue of the topic: I’ve purchased a number of these: Oz Smart Things DL41-03-10-R-ZB control via MQTT | Zigbee2MQTT and can control them via zigbee2mqqt. I have other zigbee devices (switches and sensors) that are all working fine.
- I need to expose these to Google Home so they can be voice controlled.
- I can configure a ‘Generic MQTT Thing’ to get the relevant channels, and create items from these, but I’m having trouble with the colour channel, and working out which item to tag as ga.
- I have scrapped everything, and am hoping for a kind soul to walk me through setting this up
I have Ikea color lamps with the same description in z2m.
My working thing code tab is:
- id: color_rgb
channelTypeUID: mqtt:color
label: Farbe
configuration:
retained: false
postCommand: false
formatBeforePublish: '{"color":{"r":%1$d,"g":%2$d,"b":%3$d}}'
commandTopic: zigbee2mqtt/IkeaColorlampe/set
colorMode: RGB
stateTopic: zigbee2mqtt/IkeaColorlampe/get
off: "0"
on: "1"
Link to a color item it should work.
With Google home I can’t help you.
Greets.
PS Maybe the stateTopic is wrong. I change the color only with openhab… So I don’t need the stateTopic part.
the .../get
topic is to request a specific state, so this topic is most likely not to be correct at all.
MQTT Explorer should show the correct stateTopic (payload should be json with complete state).
I would expect something like
{"state":"ON","brightness":100,{"color":{"x":0.123,"y":0.123}}}
(be aware of x/y value instead of rgb). If that’s correct, then the configuration should be something like this:
- id: color_rgb
label: Farbe
configuration:
retained: false
postCommand: false
formatBeforePublish: '{"color":{"x":%1$d,"y":%2$d},"brightness":%3$d}'
colorMode: XYY
transformationPattern: JS:|in=JSON.parse(input); in.color.x+','+in.color.y+','+in.brightness;
on: ON
off: OFF
Thanks, still banging my head against a wall, but the effort is appreciated.
Thanks for the help. The status topic looks like this:
"brightness": 10,
"color": {
"x": 0.1355,
"y": 0.0399
"color_mode": "xy",
"color_power_on_behavior": null,
"color_temp": 500,
"do_not_disturb": false,
"linkquality": 131,
"state": "ON"
My thing now looks like this:
UID: mqtt:topic:c0a82307a5:af6ca82f6a
label: OzLight1
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:c0a82307a5
channels:
- id: OzLight1_Colour
label: Colour
description: Test Colour Channel
configuration:
retained: false
postCommand: false
commandTopic: zigbee2mqtt/OzLight1/set
colorMode: XYY
transformationPattern: JS:|in=JSON.parse()input; in.color.x+','+in.color.y+','+in.brightness;
stateTopic: zigbee2mqtt/OzLight1
off: OFF
on: ON
And attached a Color item to it, but changing the sliders doesn’t change the light, but it does send MQTT : In MQTT Explorer I see messages published to zigbee2mqtt/OzLight1/set but just 3 numbers (0.359299,0.336995,24.00). I’m thinking that the formatBeforePublish isn’t working?
Some progress!
formatBeforePublish: '{"color":{"x":%1$f,"y":%2$f},"brightness":%3$f}'
works, but brightness goes from 0 - 100, where the light expects 0-254
That’s a bit tricky… but no real problem
- id: color_rgb
label: Farbe
configuration:
retained: false
postCommand: false
colorMode: XYY
transformationPatternOut: JS:|in=input.split(",");'{"color":{"x":'+in[0]+',"y":'+in[1]+'},"brightness":'+(in[2]*2.55)+'}';
transformationPattern: JS:|in=JSON.parse(input); in.color.x+','+in.color.y+','+in.brightness/2.55;
on: ON
off: OFF
Please be aware that I changed from formatBeforePublish
to transformationPatternOut
and also changed transformationPattern
slightly, as there was a typo (I changed my posting above)
I did not test
Thanks, wiil try it when I get the chance
Sadly didn’t work. Back to banging my head!
Any messages in openhab.log?
Hmm, logging crashed 2 days ago - need to sort that out first! Frontail is showing blank lines popping up, but both openhab.log and events.log last entry was from 3rd Dec
when changing the colorpicker item:
2024-12-05 10:10:16.412 [ERROR] [javascript.transformation.|835486551] - Failed to execute script: SyntaxError: <eval>:1:0 Expected an operand but found in
<eval>:1:37 Expected an operand but found in
at org.graalvm.polyglot.Context.eval(Context.java:399)
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458)
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:426)
at java.scripting/javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:262)
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocableAndAutocloseable.eval(DelegatingScriptEngineWithInvocableAndAutocloseable.java:52)
... 29 more
2024-12-05 10:10:16.413 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JS-transformation failed: Failed to execute script.. Pattern: '|in=input.split(",");'{"color":{"x":'+in[0]+',"y":'+in[1]+'},"brightness":'+(in[2]*2.55)+'}';'. Value: '0.186793,0.272278,56.00'
2024-12-05 10:10:16.610 [ERROR] [javascript.transformation.|835486551] - Failed to execute script: SyntaxError: <eval>:1:0 Expected an operand but found in
... 29 more
2024-12-05 10:10:16.612 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JS-transformation failed: Failed to execute script.. Pattern: '|in=input.split(",");'{"color":{"x":'+in[0]+',"y":'+in[1]+'},"brightness":'+(in[2]*2.55)+'}';'. Value: '0.172284,0.261031,56.00'
2024-12-05 10:10:16.395 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'OzLight1_Colour' received command 198,61,56
2024-12-05 10:10:16.398 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'OzLight1_Colour' predicted to become 198,61,56
2024-12-05 10:10:16.399 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OzLight1_Colour' changed from 198,60,56 to 198,61,56
2024-12-05 10:10:16.593 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'OzLight1_Colour' received command 198,70,56
2024-12-05 10:10:16.595 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'OzLight1_Colour' predicted to become 198,70,56
2024-12-05 10:10:16.599 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OzLight1_Colour' changed from 198,61,56 to 198,70,56```
When changing via zigbee2mqtt:
2024-12-05 10:14:39.889 [ERROR] [avascript.transformation.|1011883812] - Failed to execute script: SyntaxError: <eval>:1:0 Expected an operand but found in
<eval>:1:22 Expected an operand but found in
... 31 more
2024-12-05 10:14:39.890 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JS-transformation failed: Failed to execute script.. Pattern: '|in=JSON.parse(input); in.color.x+','+in.color.y+','+in.brightness/2.55;'. Value: '{"brightness":142,"color":{"h":308,"hue":308,"s":100,"saturation":100,"x":0.4066,"y":0.1643},"color_mode":"xy","color_options":{"execute_if_off":false},"color_power_on_behavior":null,"color_temp":153,"do_not_disturb":false,"linkquality":116,"state":"ON"}'
2024-12-05 10:14:40.351 [ERROR] [avascript.transformation.|1011883812] - Failed to execute script: SyntaxError: <eval>:1:0 Expected an operand but found in
... 31 more
2024-12-05 10:14:40.352 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JS-transformation failed: Failed to execute script.. Pattern: '|in=JSON.parse(input); in.color.x+','+in.color.y+','+in.brightness/2.55;'. Value: '{"brightness":142,"color":{"h":308,"hue":308,"s":100,"saturation":100,"x":0.4066,"y":0.1643},"color_mode":"xy","color_options":{"execute_if_off":false},"color_power_on_behavior":null,"color_temp":153,"do_not_disturb":false,"linkquality":120,"state":"ON"}'
2024-12-05 10:14:40.378 [ERROR] [avascript.transformation.|1011883812] - Failed to execute script: SyntaxError: <eval>:1:0 Expected an operand but found in
... 31 more
2024-12-05 10:14:40.379 [WARN ] [t.generic.ChannelStateTransformation] - Executing the JS-transformation failed: Failed to execute script.. Pattern: '|in=JSON.parse(input); in.color.x+','+in.color.y+','+in.brightness/2.55;'. Value: '{"brightness":142,"color":{"h":308,"hue":308,"s":100,"saturation":100,"x":0.4066,"y":0.1643},"color_mode":"xy","color_options":{"execute_if_off":false},"color_power_on_behavior":null,"color_temp":153,"do_not_disturb":false,"linkquality":112,"state":"ON"}'
Current code for the Thing:
UID: mqtt:topic:c0a82307a5:b05828ee3b
label: OzLight1
configuration: {}
channels:
label: Colour
configuration:
postCommand: false
retained: false
colorMode: XYY
off: OFF
on: ON
- id: brightness
channelTypeUID: mqtt:dimmer
label: Brightness
description: ""
configuration:
commandTopic: zigbee2mqtt/OzLight1/set/brightness
min: 0
stateTopic: zigbee2mqtt/OzLight1/get
max: 254
Turns out, JS inline doesn’t like variables…
Please try
- JS:| '{"color":{"x":' + input.split(',')[0] + ',"y":' +
input.split(',')[1] + '},"brightness":' + (input.split(',')[2]*2.55) +
formatBeforePublish: "%s"
colorMode: XYY
- JS:| JSON.parse(input).color.x + ',' + JSON.parse(input).color.y + ','
+ JSON.parse(input).brightness/2.55;
Edit:
in
seems to be a key word in JS…
- JS:|data = input.split(','); '{"color":{"x":' + data[0] + ',"y":' +
data[1] + '},"brightness":' + (data[2]*2.55) + '}';
- JS:|data = JSON.parse(input); data.color.x + ',' + data.color.y + ','
+ data.brightness/2.55;
Woot! Thanks Udo, that did it
Now on with my journey of connecting it to Google Assistant!
Dammit spoke too soon. Is there a simple way to round the x,y values to 3 decimal places?
My guess: (myValue * 1000).intValue)/1000
could work.
Sadly not. breaking it down by parts:
(input.split(',')[0])*1000)
gives the expected result, but
((input.split(',')[0])*1000).intValue
is undefined. the MQTT formed is
{"color":{"x":undefined,"y":0.089357},"brightness":162.56}
I’m still not convinced that this is my current problem. The lights are supposed to enter color_temp mode automatically when set to an appropriate value, but that isn’t happening. Not sure if it isn’t close enough (due to no rounding), or if I have a problem with the color_temp channel. I’ll play around for a while & see where I get. Might spin up home assistant to control an identical light and see what’s different on the MQTT side.
Thanks for your help so far. If I ever get it working(!), I’ll put together a write up.
Another option:
Math.round(input.split(',')[0],3)
where 3 is the amount of decimal places to round to.
Ugh: chasing the wrong issue!
I spanup a Home Assistant instance to compare, used the existing Zigbee2MQTT instance. Connected an identical light and exposed it to Google (very simple: it just detected it automatically). In Google Home, put them in the same room and used the grouped controls to play around with them while I watched MQTT Explorer.
Changing to (non white) colours is fine, changing brightness is fine, but changing to a white colour (ie “Ivory” or “Ghost White” or “Cool White”) does not work for the OpenHab controlled light.
Changing from “Blue” to “Ivory” the Home Assistant controlled light gets:
{"state":"ON","color_temp":166}
The OpenHab controlled light gets:
{"color":{"x":0.332707,"y":0.344436},"brightness":254}
Which is not Ivory (or even close!)
I’m guessing I have an issue with the Google Assistant metadata
value: SpecialColorLight
colorUnit: mired
colorTemperatureRange: 130,500
roomHint: Lounge
