So I have a raspberry pi with openhabian installed.
I have a ZigBee USB Stick (Bitronvideo ZigBee, an EMBER coordinator).
Without any use of MQTT, I was able to add 2 devices to the ZigBee controler, using the ZigBee Binding (an IKEA bulb and a SMARTTHINGS motion sensor) and operate them (I was able to detect both with the ZigBee controller binding).
However, a third device (Xiaomi Aqara Human Motion Sensor), I can add it with the ZigBee binding, I see 4 channels, but the available channels aren’t anything that I need. There’s battery voltage, luminance, etc, but not the most important one: Motion detection (the reason I got this device).
According to this page, section DEVICES, it is supposed to work:
Questions:
Is this where MQTT comes into play?
Does the hardware need to be added directly to the ZigBee controller first? Or do I need to remove from ZigBee , prepare all mqtt and once properly configured, let mqtt detect the device? In other words, when adding the device to the system, is this a ZigBee thing or a MQTT thing?
In openhabian-config I have the option to install Mosquitto broker, but I get a warning saying that (I don’t know the exact wording)
“since openhab 2.5M1, MQTT is already in the system, Mosquitto it will use the same ports and may lead to conflicts”
Should I install this anyway? I was trying with the built in Moquette
MQTT also works for zwave devices? I ask this because I have one zwave device that has exactly the same problem: I successfuly add it but all I get are useless channels (a door sensor without the on/off channel or open/close switch channel).
When I say that I was able to add 2 devices to the zigbee controller I meant via zigbee binding. Those two devices work flawlessly without any MQTT envolved.
Just the 3rd device has issues, I see 4 channels, but none of them is the “motion sensor” or “presence detector” and I can’t use it in rules. There’s “luminance”, there’s “low voltage”, there’s “tampering” and one other that I don’t remember.
After several try / error attempts I was able to get everything working.
No need for MQTT.
Regarding that specific device (xiaomi aqara human motion sensor) you have to use the ILLUMINANCE channel (there’s a variance in the number value whenever motion is detected).
