- Platform information:
- Hardware: Raspberry Pi 3b
- OS: raspbian
- openHAB version: 2.4 Stable Docker:latest
- CC2531 Zigbee stick
openhab writes Debug Log for the zigbee binding
11:32:39.131 [DEBUG] [531.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=15, apiId=24 01, data=FE 0F 24 01 D1 DD 0B 01 00 03 5E 30 1F 05 00 5E 00 01 00 04, checksum=04, error=false)
11:32:39.261 [DEBUG] [531.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
11:32:39.545 [DEBUG] [531.network.impl.CommandInterfaceImpl] - <-- AF_DATA_CONFIRM (FE 03 44 80 00 01 5E 98)
11:32:39.552 [DEBUG] [531.network.impl.CommandInterfaceImpl] - Received Async Cmd: AF_DATA_CONFIRM(Endpoint=1, Status=SUCCESS(0), TransID=94)
11:32:39.557 [DEBUG] [531.network.impl.CommandInterfaceImpl] - <-- AF_INCOMING_MSG (FE 1C 44 81 00 00 00 03 D1 DD 0B 01 00 00 00 9D D2 D5 00 00 08 18 5E 01 01 00 00 20 63 D1 DD 1D 5A)
11:32:39.561 [DEBUG] [531.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=28, apiId=44 81, data=FE 1C 44 81 00 00 00 03 D1 DD 0B 01 00 00 00 9D D2 D5 00 00 08 18 5E 01 01 00 00 20 63 D1 DD 1D 5A, c
there is no debug log enabled
openhab> log:list
Logger │ Level
ROOT │ WARN
com.zsmartsystems.zigbee │ WARN
javax.jmdns │ ERROR
org.apache.karaf.jaas.modules.audit │ INFO
org.apache.karaf.kar.internal.KarServiceImpl │ ERROR
org.apache.karaf.shell.support │ OFF
org.apache.sshd │ ERROR
org.eclipse.smarthome │ INFO
org.jupnp │ ERROR
org.openhab │ INFO
org.openhab.binding.heos │ WARN
org.ops4j.pax.url.mvn.internal.AetherBasedResolver │ ERROR
org.ops4j.pax.web.pax-web-runtime │ OFF
smarthome.event │ WARN
smarthome.event.InboxUpdatedEvent │ ERROR
smarthome.event.ItemAddedEvent │ ERROR
smarthome.event.ItemRemovedEvent │ ERROR
smarthome.event.ItemStateEvent │ ERROR
smarthome.event.ThingAddedEvent │ ERROR
smarthome.event.ThingRemovedEvent │ ERROR
smarthome.event.ThingStatusInfoEvent │ ERROR
Disable with log:set not working
240 │ Active │ 80 │ 1.13.0 │ openHAB Weather Binding
241 │ Active │ 80 │ 2.4.0 │ ZigBee Binding
242 │ Active │ 80 │ 2.4.0 │ ZigBee CC2531 Binding
243 │ Active │ 80 │ 2.4.0 │ ZigBee Ember Binding
244 │ Active │ 80 │ 2.4.0 │ ZigBee Telegesis Binding
245 │ Active │ 80 │ 2.4.0 │ ZigBee XBee Binding
246 │ Active │ 80 │ 2.4.0 │ openHAB 1.x Compatibility Layer
247 │ Active │ 80 │ 1.13.0 │ openHAB CalDav Calendar
248 │ Active │ 80 │ 2.4.0 │ Hue Emulation Service
249 │ Active │ 80 │ 2.4.0 │ openHAB Cloud Connector Bundle
250 │ Active │ 80 │ 1.13.0 │ openHAB MQTT Transport Bundle
251 │ Active │ 80 │ 1.13.0 │ openHAB InfluxDB Persistence bundle
252 │ Active │ 80 │ 1.13.0 │ openHAB MapDB Persistence Bundle
253 │ Active │ 80 │ 1.13.0 │ openHAB RRD4j Persistence Bundle
254 │ Resolved │ 75 │ 2.4.0 │ openHAB Basic UI Fragment, Hosts: 227
255 │ Active │ 80 │ 2.4.0 │ HABPanel User Interface
256 │ Resolved │ 75 │ 2.4.0 │ openHAB Paper UI Theme Fragment, Hosts: 228
openhab> log:set WARN 241
Any ideas how can i disable the logging?
Thanks!
