Currently I am trying to connect my hue bulbs to openhab by using cc2531 usb dongle as a coordinator.
After the successful installation of openhab stable version on the raspberry pi, I flash the CC2531ZNP-Pro-Secure_Standard.hex to
the cc2531 with flash programmer. Then I installed the Zigbee addon through paper UI, and added cc2531 coordinator
to thing list. The problem is I can not discover any device on paper UI. From monitoring the Sniffer program, the hue bulbs seems to send out beacon request.
I am new to openhab, can someone please help me with this issue? Here is the deug log:
2017-07-25 17:15:35.280 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_cc2531:6c91b58b].
2017-07-25 17:15:35.284 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 11.0
2017-07-25 17:15:35.287 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID -2.0
2017-07-25 17:15:35.294 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 00124B000E0D7EFC
2017-07-25 17:15:35.300 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key 4F 04 E8 F7 67 E2 17 9F 5A 56 7D 51 3E 65 C3 15
2017-07-25 17:15:35.302 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key String 4F 04 E8 F7 67 E2 17 9F 5A 56 7D 51 3E 65 C3 15
2017-07-25 17:15:35.304 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key array [79, 4, 232, 247, 103, 226, 23, 159, 90, 86, 125, 81, 62, 101, 195, 21]
2017-07-25 17:15:35.305 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key final array [79, 4, 232, 247, 103, 226, 23, 159, 90, 86, 125, 81, 62, 101, 195, 21]
2017-07-25 17:15:35.363 [DEBUG] [ndler.ZigBeeCoordinatorCC2531Handler] - ZigBee Coordinator ZNP opening Port:'/dev/ttyACM0' PAN:fffffffe, Channel:11
2017-07-25 17:15:35.371 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2017-07-25 17:15:36.374 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2017-07-25 17:15:36.375 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2017-07-25 17:15:36.388 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Creating ZigBee discovery service for zigbee:coordinator_cc2531:6c91b58b
2017-07-25 17:15:36.390 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Activating ZigBee discovery service for zigbee:coordinator_cc2531:6c91b58b
2017-07-25 17:15:36.404 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=888, service.bundleid=185, service.scope=singleton} - org.openhab.binding.zigbee
2017-07-25 17:15:36.470 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialise [79, 4, 232, 247, 103, 226, 23, 159, 90, 86, 125, 81, 62, 101, 195, 21]
2017-07-25 17:15:36.472 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - CC2531 transport initialize
2017-07-25 17:15:36.480 [DEBUG] [ndler.ZigBeeCoordinatorCC2531Handler] - Opening ZigBee CC2531 serial port
2017-07-25 17:15:36.482 [DEBUG] [ndler.ZigBeeCoordinatorCC2531Handler] - Connecting to serial port [/dev/ttyACM0]
2017-07-25 17:15:36.615 [INFO ] [ndler.ZigBeeCoordinatorCC2531Handler] - Serial port [/dev/ttyACM0] is initialized.
2017-07-25 17:15:36.642 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> SYS_RESET (Packet: subsystem=null, length=1, apiId=41 00, data=FE 01 41 00 01 41, checksum=41, error=false)
2017-07-25 17:15:37.254 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.51.247:8080
2017-07-25 17:15:37.259 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.51.247:8443
2017-07-25 17:15:37.732 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- SYS_RESET_RESPONSE (FE 06 41 80 00 02 00 02 06 03 C2)
2017-07-25 17:15:37.737 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=6, apiId=41 80, data=FE 06 41 80 00 02 00 02 06 03 C2, checksum=C2, error=false
2017-07-25 17:15:37.742 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> SYS_VERSION (Packet: subsystem=null, length=0, apiId=21 02, data=FE 00 21 02 23, checksum=23, error=false)
2017-07-25 17:15:37.754 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- SYS_VERSION_RESPONSE (FE 05 61 02 02 00 02 06 03 63)
2017-07-25 17:15:37.760 [DEBUG] [etwork.impl.ZigBeeNetworkManagerImpl] - CC2531 version is Software=2.6 Product=0 Hardware=3 Transport=2
2017-07-25 17:15:37.763 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - initResponse is JOINED
2017-07-25 17:15:37.766 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - initializeNetwork is false
2017-07-25 17:15:37.769 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 05 24, checksum=24, error=false)
2017-07-25 17:15:37.779 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZB_GET_DEVICE_INFO_RSP (FE 09 66 06 05 0B 00 00 00 00 00 00 00 67)
2017-07-25 17:15:37.781 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 06 27, checksum=27, error=false)
2017-07-25 17:15:37.790 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZB_GET_DEVICE_INFO_RSP (FE 09 66 06 06 10 CF 00 00 00 00 00 00 B0)
2017-07-25 17:15:37.793 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 07 26, checksum=26, error=false)
2017-07-25 17:15:37.803 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZB_GET_DEVICE_INFO_RSP (FE 09 66 06 07 FC 7E 0D 0E 00 4B 12 00 B6)
2017-07-25 17:15:37.805 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - CC2531 transport startup
2017-07-25 17:15:37.807 [DEBUG] [etwork.impl.ZigBeeNetworkManagerImpl] - Creating network as Coordinator
2017-07-25 17:15:37.808 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZDO_MSG_CB_REGISTER (Packet: subsystem=null, length=2, apiId=25 3E, data=FE 02 25 3E FF FF 19, checksum=19, error=false)
2017-07-25 17:15:37.819 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZDO_MSG_CB_REGISTER_SRSP (FE 01 65 3E 00 5A)
2017-07-25 17:15:37.824 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZB_WRITE_CONFIGURATION (Packet: subsystem=null, length=3, apiId=26 05, data=FE 03 26 05 8F 01 01 AF, checksum=AF, error=false)
2017-07-25 17:15:37.841 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZB_WRITE_CONFIGURATION_RSP (FE 01 66 05 00 62)
2017-07-25 17:15:37.843 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZDO_STARTUP_FROM_APP (Packet: subsystem=null, length=2, apiId=25 40, data=FE 02 25 40 00 00 67, checksum=67, error=false)
2017-07-25 17:15:38.211 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-07-25 17:15:38.374 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-07-25 17:15:38.578 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-07-25 17:15:38.643 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZDO_STARTUP_FROM_APP_SRSP (FE 01 65 40 00 24)
2017-07-25 17:15:38.648 [INFO ] [etwork.impl.ZigBeeNetworkManagerImpl] - Initialized ZigBee network with existing network state.
2017-07-25 17:15:38.658 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZDO_STATE_CHANGE_IND (FE 01 45 C0 09 8D)
2017-07-25 17:15:38.659 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: ZDO_STATE_CHANGE_IND{State=DEV_COORD_STARTED}
2017-07-25 17:15:38.662 [DEBUG] [etwork.impl.ZigBeeNetworkManagerImpl] - Started as ZigBee Coordinator
2017-07-25 17:15:38.667 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - Unhandled ZToolPacket type 0x45c0
2017-07-25 17:15:38.706 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_REGISTER (Packet: subsystem=null, length=9, apiId=24 00, data=FE 09 24 00 01 04 01 00 00 00 00 00 00 29, checksum=29, error=false)
2017-07-25 17:15:38.723 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_REGISTER_SRSP (FE 01 64 00 00 65)
2017-07-25 17:15:38.725 [DEBUG] [e.dongle.cc2531.ZigBeeDongleTiCc2531] - Registered endpoint 1 with profile: 260
2017-07-25 17:15:38.727 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0: Scheduling node discovery
2017-07-25 17:15:38.748 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0: Starting node discovery
2017-07-25 17:15:38.748 [DEBUG] [ee.internal.ZigBeeNetworkMeshMonitor] - Starting mesh update task with interval of 60 seconds
2017-07-25 17:15:38.758 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 05 24, checksum=24, error=false)
2017-07-25 17:15:38.768 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZB_GET_DEVICE_INFO_RSP (FE 09 66 06 05 0B 06 00 FF FE 01 64 00 05)
2017-07-25 17:15:38.769 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 07 26, checksum=26, error=false)
2017-07-25 17:15:38.782 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: IeeeAddressRequest [0/0 -> 0/0, cluster=0001, TID=00, nwkAddrOfInterest=0, requestType=1, startIndex=0]
2017-07-25 17:15:38.787 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- ZB_GET_DEVICE_INFO_RSP (FE 09 66 06 07 FC 7E 0D 0E 00 4B 12 00 B6)
2017-07-25 17:15:38.790 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialise done....... 11 -12528 00124B000E0D7EFC
2017-07-25 17:15:38.896 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-07-25 17:15:38.939 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=15, apiId=24 01, data=FE 0F 24 01 00 00 00 00 01 00 00 30 1F 05 00 00 00 01 00 00, checksum=00, error=false)
2017-07-25 17:15:39.011 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:39.013 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 81 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 00 11)
2017-07-25 17:15:39.019 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 81, data=FE 0D 45 81 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 00 11, checksum=11, error=false
2017-07-25 17:15:39.228 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [0/0 -> 0/0, cluster=8001, TID=NULL, status=SUCCESS, ieeeAddrRemoteDev=00124B000E0D7EFC, nwkAddrRemoteDev=0, numAssocDev=0, startIndex=null, nwkAddrAssocDevList=[]]
2017-07-25 17:15:39.254 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0: Discovery request IEEE_ADDRESS successfull. Advanced to NODE_DESCRIPTOR.
2017-07-25 17:15:39.258 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: NodeDescriptorRequest [0/0 -> 0/0, cluster=0002, TID=01, nwkAddrOfInterest=0]
2017-07-25 17:15:39.269 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 15 45 FF 00 00 00 01 80 00 00 00 00 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 F6)
2017-07-25 17:15:39.269 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=13, apiId=24 01, data=FE 0D 24 01 00 00 00 00 02 00 01 30 1F 03 00 00 00 07, checksum=07, error=false)
2017-07-25 17:15:39.270 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=21, apiId=45 FF, data=FE 15 45 FF 00 00 00 01 80 00 00 00 00 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 F6, checksum=F6, error=false
2017-07-25 17:15:39.274 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [0/0 -> 0/0, cluster=8001, TID=NULL, status=SUCCESS, ieeeAddrRemoteDev=00124B000E0D7EFC, nwkAddrRemoteDev=0, numAssocDev=0, startIndex=null, nwkAddrAssocDevList=[]]
2017-07-25 17:15:39.323 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:39.326 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 12 45 82 00 00 00 00 00 00 40 8F 00 00 50 A0 00 01 00 A0 00 00 4B)
2017-07-25 17:15:39.328 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=18, apiId=45 82, data=FE 12 45 82 00 00 00 00 00 00 40 8F 00 00 50 A0 00 01 00 A0 00 00 4B, checksum=4B, error=false
2017-07-25 17:15:39.355 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: NodeDescriptorResponse [0/0 -> 0/0, cluster=8002, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, nodeDescriptor=NodeDescriptor [apsFlags=0, bufferSize=80, complexDescriptorAvailable=false, manufacturerCode=0, logicalType=COORDINATOR, serverCapabilities=[PRIMARY_TRUST_CENTER], incomingTransferSize=160, outgoingTransferSize=160, userDescriptorAvailable=false, frequencyBands=[FREQ_2400_MHZ], macCapabilities=[MAINS_POWER, RECEIVER_ON_WHEN_IDLE, ALTERNATIVE_PAN, FULL_FUNCTION_DEVICE], extendedEndpointListAvailable=false, extendedSimpleDescriptorListAvailable=false]]
2017-07-25 17:15:39.369 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0: Discovery request NODE_DESCRIPTOR successfull. Advanced to POWER_DESCRIPTOR.
2017-07-25 17:15:39.371 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 19 45 FF 00 00 00 02 80 00 00 00 00 00 00 00 00 40 8F 00 00 50 A0 00 01 00 A0 00 00 BF)
2017-07-25 17:15:39.390 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=25, apiId=45 FF, data=FE 19 45 FF 00 00 00 02 80 00 00 00 00 00 00 00 00 40 8F 00 00 50 A0 00 01 00 A0 00 00 BF, checksum=BF, error=false
2017-07-25 17:15:39.380 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: PowerDescriptorRequest [0/0 -> 0/0, cluster=0003, TID=02, nwkAddrOfInterest=0]
2017-07-25 17:15:39.394 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: NodeDescriptorResponse [0/0 -> 0/0, cluster=8002, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, nodeDescriptor=NodeDescriptor [apsFlags=0, bufferSize=80, complexDescriptorAvailable=false, manufacturerCode=0, logicalType=COORDINATOR, serverCapabilities=[PRIMARY_TRUST_CENTER], incomingTransferSize=160, outgoingTransferSize=160, userDescriptorAvailable=false, frequencyBands=[FREQ_2400_MHZ], macCapabilities=[MAINS_POWER, RECEIVER_ON_WHEN_IDLE, ALTERNATIVE_PAN, FULL_FUNCTION_DEVICE], extendedEndpointListAvailable=false, extendedSimpleDescriptorListAvailable=false]]
2017-07-25 17:15:39.394 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=13, apiId=24 01, data=FE 0D 24 01 00 00 00 00 03 00 02 30 1F 03 00 00 00 05, checksum=05, error=false)
2017-07-25 17:15:39.438 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:39.449 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 07 45 83 00 00 00 00 00 10 C1 10)
2017-07-25 17:15:39.450 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=7, apiId=45 83, data=FE 07 45 83 00 00 00 00 00 10 C1 10, checksum=10, error=false
2017-07-25 17:15:39.459 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: PowerDescriptorResponse [0/0 -> 0/0, cluster=8003, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, powerDescriptor=RECEIVER_ON_IDLE, [MAINS], MAINS, FULL]
2017-07-25 17:15:39.478 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0: Discovery request POWER_DESCRIPTOR successfull. Advanced to ACTIVE_ENDPOINTS.
2017-07-25 17:15:39.479 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0E 45 FF 00 00 00 03 80 00 00 00 00 00 00 00 10 C1 E6)
2017-07-25 17:15:39.480 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ActiveEndpointsRequest [0/0 -> 0/0, cluster=0005, TID=03, nwkAddrOfInterest=0]
2017-07-25 17:15:39.481 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=14, apiId=45 FF, data=FE 0E 45 FF 00 00 00 03 80 00 00 00 00 00 00 00 10 C1 E6, checksum=E6, error=false
2017-07-25 17:15:39.482 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=13, apiId=24 01, data=FE 0D 24 01 00 00 00 00 05 00 03 30 1F 03 00 00 00 02, checksum=02, error=false)
2017-07-25 17:15:39.483 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: PowerDescriptorResponse [0/0 -> 0/0, cluster=8003, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, powerDescriptor=RECEIVER_ON_IDLE, [MAINS], MAINS, FULL]
2017-07-25 17:15:39.505 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:39.510 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 07 45 85 00 00 00 00 00 01 01 C7)
2017-07-25 17:15:39.512 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=7, apiId=45 85, data=FE 07 45 85 00 00 00 00 00 01 01 C7, checksum=C7, error=false
2017-07-25 17:15:39.517 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ActiveEndpointsResponse [0/0 -> 0/0, cluster=8005, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, activeEpCnt=1, activeEpList=[1]]
2017-07-25 17:15:39.519 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0/1: Scheduling device discovery
2017-07-25 17:15:39.524 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0E 45 FF 00 00 00 05 80 00 00 00 00 00 00 00 01 01 31)
2017-07-25 17:15:39.525 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=14, apiId=45 FF, data=FE 0E 45 FF 00 00 00 05 80 00 00 00 00 00 00 00 01 01 31, checksum=31, error=false
2017-07-25 17:15:39.528 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ActiveEndpointsResponse [0/0 -> 0/0, cluster=8005, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, activeEpCnt=1, activeEpList=[1]]
2017-07-25 17:15:39.530 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0: Discovery request ACTIVE_ENDPOINTS successfull. Advanced to IEEE_ADDRESS.
2017-07-25 17:15:39.531 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0: Ending node discovery
2017-07-25 17:15:39.536 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - 0/1: Starting device discovery
2017-07-25 17:15:39.540 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: SimpleDescriptorRequest [0/0 -> 0/0, cluster=0004, TID=04, nwkAddrOfInterest=0, endpoint=1]
2017-07-25 17:15:39.543 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=14, apiId=24 01, data=FE 0E 24 01 00 00 00 00 04 00 04 30 1F 04 00 00 00 01 01, checksum=01, error=false)
2017-07-25 17:15:39.601 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:39.604 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0E 45 84 00 00 00 00 00 08 01 04 01 00 00 00 00 00 C3)
2017-07-25 17:15:39.605 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=14, apiId=45 84, data=FE 0E 45 84 00 00 00 00 00 08 01 04 01 00 00 00 00 00 C3, checksum=C3, error=false
2017-07-25 17:15:39.610 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: SimpleDescriptorResponse [0/0 -> 0/0, cluster=8004, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, length=8, simpleDescriptor=SimpleDescriptor [endpoint=1, profileId=260, deviceId=0, deviceVersion=0, inputClusterList=[], outputClusterList=[]]]
2017-07-25 17:15:39.617 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 15 45 FF 00 00 00 04 80 00 00 00 00 00 00 00 08 01 04 01 00 00 00 00 00 27)
2017-07-25 17:15:39.640 [DEBUG] [om.zsmartsystems.zigbee.ZigBeeDevice] - 0/1: Setting input clusters []
2017-07-25 17:15:39.641 [DEBUG] [om.zsmartsystems.zigbee.ZigBeeDevice] - 0/1: Setting output clusters []
2017-07-25 17:15:39.645 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=21, apiId=45 FF, data=FE 15 45 FF 00 00 00 04 80 00 00 00 00 00 00 00 08 01 04 01 00 00 00 00 00 27, checksum=27, error=false
2017-07-25 17:15:39.650 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 00124B000E0D7EFC: Node 0 is added to the network
2017-07-25 17:15:39.652 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: SimpleDescriptorResponse [0/0 -> 0/0, cluster=8004, TID=NULL, status=SUCCESS, nwkAddrOfInterest=0, length=8, simpleDescriptor=SimpleDescriptor [endpoint=1, profileId=260, deviceId=0, deviceVersion=0, inputClusterList=[], outputClusterList=[]]]
2017-07-25 17:15:39.654 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Node discovered: IEEE=00124B000E0D7EFC, NWK=0000, Type=COORDINATOR
2017-07-25 17:15:48.755 [DEBUG] [ee.internal.ZigBeeNetworkMeshMonitor] - 0: Starting mesh update
2017-07-25 17:15:48.757 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementLqiRequest [0/0 -> 0/0, cluster=0031, TID=05, startIndex=0]
2017-07-25 17:15:48.758 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=12, apiId=24 01, data=FE 0C 24 01 00 00 00 00 31 00 05 30 1F 02 00 00 30, checksum=30, error=false)
2017-07-25 17:15:48.782 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:48.788 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 06 45 B1 00 00 00 00 00 00 F2)
2017-07-25 17:15:48.790 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=6, apiId=45 B1, data=FE 06 45 B1 00 00 00 00 00 00 F2, checksum=F2, error=false
2017-07-25 17:15:48.795 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementLqiResponse [0/0 -> 0/0, cluster=8031, TID=NULL, status=SUCCESS, neighborTableEntries=0, startIndex=0, neighborTableListCount=0, neighborTableList=[]]
2017-07-25 17:15:48.800 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 FF 00 00 00 31 80 00 00 00 00 00 00 00 00 06)
2017-07-25 17:15:48.801 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 FF, data=FE 0D 45 FF 00 00 00 31 80 00 00 00 00 00 00 00 00 06, checksum=06, error=false
2017-07-25 17:15:48.803 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementLqiResponse [0/0 -> 0/0, cluster=8031, TID=NULL, status=SUCCESS, neighborTableEntries=0, startIndex=0, neighborTableListCount=0, neighborTableList=[]]
2017-07-25 17:15:48.804 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: IeeeAddressRequest [0/0 -> 0/0, cluster=0001, TID=06, nwkAddrOfInterest=0, requestType=1, startIndex=0]
2017-07-25 17:15:48.807 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=15, apiId=24 01, data=FE 0F 24 01 00 00 00 00 01 00 06 30 1F 05 00 00 00 01 00 06, checksum=06, error=false)
2017-07-25 17:15:48.831 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:48.840 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 81 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 00 11)
2017-07-25 17:15:48.841 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 81, data=FE 0D 45 81 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 00 11, checksum=11, error=false
2017-07-25 17:15:48.843 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [0/0 -> 0/0, cluster=8001, TID=NULL, status=SUCCESS, ieeeAddrRemoteDev=00124B000E0D7EFC, nwkAddrRemoteDev=0, numAssocDev=0, startIndex=null, nwkAddrAssocDevList=[]]
2017-07-25 17:15:48.846 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=07, startIndex=0]
2017-07-25 17:15:48.847 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 15 45 FF 00 00 00 01 80 00 00 00 00 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 F6)
2017-07-25 17:15:48.848 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=12, apiId=24 01, data=FE 0C 24 01 00 00 00 00 32 00 07 30 1F 02 00 00 31, checksum=31, error=false)
2017-07-25 17:15:48.849 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=21, apiId=45 FF, data=FE 15 45 FF 00 00 00 01 80 00 00 00 00 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 F6, checksum=F6, error=false
2017-07-25 17:15:48.851 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [0/0 -> 0/0, cluster=8001, TID=NULL, status=SUCCESS, ieeeAddrRemoteDev=00124B000E0D7EFC, nwkAddrRemoteDev=0, numAssocDev=0, startIndex=null, nwkAddrAssocDevList=[]]
2017-07-25 17:15:48.868 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:15:48.880 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 06 45 B2 00 00 00 00 00 00 F1)
2017-07-25 17:15:48.883 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=6, apiId=45 B2, data=FE 06 45 B2 00 00 00 00 00 00 F1, checksum=F1, error=false
2017-07-25 17:15:48.889 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=0, startIndex=0, routingTableListCount=0, routingTableList=[]]
2017-07-25 17:15:48.895 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 FF 00 00 00 32 80 00 00 00 00 00 00 00 00 05)
2017-07-25 17:15:48.895 [DEBUG] [ee.internal.ZigBeeNetworkMeshMonitor] - 0: Ending mesh update
2017-07-25 17:15:48.918 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 FF, data=FE 0D 45 FF 00 00 00 32 80 00 00 00 00 00 00 00 00 05, checksum=05, error=false
2017-07-25 17:15:48.922 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=0, startIndex=0, routingTableListCount=0, routingTableList=[]]
2017-07-25 17:16:08.481 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_cc2531:6c91b58b
2017-07-25 17:16:08.494 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Permit join for 60 seconds.
2017-07-25 17:16:08.500 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0/0 -> 65532/0, cluster=0036, TID=08, permitDuration=60, tcSignificance=true]
2017-07-25 17:16:08.502 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=13, apiId=24 01, data=FE 0D 24 01 FC FF 00 00 36 00 08 30 1F 03 00 3C 01 04, checksum=04, error=false)
2017-07-25 17:16:08.526 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:16:48.752 [DEBUG] [ee.internal.ZigBeeNetworkMeshMonitor] - 0: Starting mesh update
2017-07-25 17:16:48.753 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementLqiRequest [0/0 -> 0/0, cluster=0031, TID=09, startIndex=0]
2017-07-25 17:16:48.755 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=12, apiId=24 01, data=FE 0C 24 01 00 00 00 00 31 00 09 30 1F 02 00 00 3C, checksum=3C, error=false)
2017-07-25 17:16:48.773 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:16:48.779 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 06 45 B1 00 00 00 00 00 00 F2)
2017-07-25 17:16:48.780 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=6, apiId=45 B1, data=FE 06 45 B1 00 00 00 00 00 00 F2, checksum=F2, error=false
2017-07-25 17:16:48.782 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementLqiResponse [0/0 -> 0/0, cluster=8031, TID=NULL, status=SUCCESS, neighborTableEntries=0, startIndex=0, neighborTableListCount=0, neighborTableList=[]]
2017-07-25 17:16:48.787 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 FF 00 00 00 31 80 00 00 00 00 00 00 00 00 06)
2017-07-25 17:16:48.789 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 FF, data=FE 0D 45 FF 00 00 00 31 80 00 00 00 00 00 00 00 00 06, checksum=06, error=false
2017-07-25 17:16:48.790 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: IeeeAddressRequest [0/0 -> 0/0, cluster=0001, TID=0A, nwkAddrOfInterest=0, requestType=1, startIndex=0]
2017-07-25 17:16:48.790 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementLqiResponse [0/0 -> 0/0, cluster=8031, TID=NULL, status=SUCCESS, neighborTableEntries=0, startIndex=0, neighborTableListCount=0, neighborTableList=[]]
2017-07-25 17:16:48.791 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=15, apiId=24 01, data=FE 0F 24 01 00 00 00 00 01 00 0A 30 1F 05 00 00 00 01 00 0A, checksum=0A, error=false)
2017-07-25 17:16:48.825 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:16:48.832 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 81 00 FC 7E 0D 0E 00 4B 12 00 00 00 9F 00 8E)
2017-07-25 17:16:48.834 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 81, data=FE 0D 45 81 00 FC 7E 0D 0E 00 4B 12 00 00 00 9F 00 8E, checksum=8E, error=false
2017-07-25 17:16:48.835 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [0/0 -> 0/0, cluster=8001, TID=NULL, status=SUCCESS, ieeeAddrRemoteDev=00124B000E0D7EFC, nwkAddrRemoteDev=0, numAssocDev=0, startIndex=null, nwkAddrAssocDevList=[]]
2017-07-25 17:16:48.837 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=0B, startIndex=0]
2017-07-25 17:16:48.839 [DEBUG] [31.network.impl.CommandInterfaceImpl] - -> AF_DATA_REQUEST (Packet: subsystem=null, length=12, apiId=24 01, data=FE 0C 24 01 00 00 00 00 32 00 0B 30 1F 02 00 00 3D, checksum=3D, error=false)
2017-07-25 17:16:48.839 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 15 45 FF 00 00 00 01 80 00 00 00 00 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 F6)
2017-07-25 17:16:48.841 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=21, apiId=45 FF, data=FE 15 45 FF 00 00 00 01 80 00 00 00 00 00 FC 7E 0D 0E 00 4B 12 00 00 00 00 F6, checksum=F6, error=false
2017-07-25 17:16:48.843 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: IeeeAddressResponse [0/0 -> 0/0, cluster=8001, TID=NULL, status=SUCCESS, ieeeAddrRemoteDev=00124B000E0D7EFC, nwkAddrRemoteDev=0, numAssocDev=0, startIndex=null, nwkAddrAssocDevList=[]]
2017-07-25 17:16:48.858 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <- AF_DATA_SRSP (FE 01 64 01 00 64)
2017-07-25 17:16:48.865 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 06 45 B2 00 00 00 00 00 00 F1)
2017-07-25 17:16:48.867 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=6, apiId=45 B2, data=FE 06 45 B2 00 00 00 00 00 00 F1, checksum=F1, error=false
2017-07-25 17:16:48.869 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=0, startIndex=0, routingTableListCount=0, routingTableList=[]]
2017-07-25 17:16:48.873 [DEBUG] [ee.internal.ZigBeeNetworkMeshMonitor] - 0: Ending mesh update
2017-07-25 17:16:48.875 [DEBUG] [31.network.impl.CommandInterfaceImpl] - <-- ZToolPacket (FE 0D 45 FF 00 00 00 32 80 00 00 00 00 00 00 00 00 05)
2017-07-25 17:16:48.876 [DEBUG] [31.network.impl.CommandInterfaceImpl] - Received Async Cmd: Packet: subsystem=null, length=13, apiId=45 FF, data=FE 0D 45 FF 00 00 00 32 80 00 00 00 00 00 00 00 00 05, checksum=05, error=false
