I am using @chris’s ZigBee binding; my items (coordinator & dimmable light) were discovered by the binding, and now I want to create items for the dimmable light. Unfortunately I cannot find any resources on the binding/channel syntax, other than @Mariusm’s yet unanswered question here. I also did a forum search but that didn’t turn up much either.
I tried a lot of different nomenclatures, but none of them worked for my devices. Perhaps someone can help me figure this out. My devices are the following:
Thanks for the pointer. The only thing I need to know now is what I need to put before/after the switch_onoff port of of my item’s channel configuration. Based on my things’ names, could you please give me a concrete example?
I tend to do all my configuration through the UI, so I’m not 100% sure. But, the format should be <binding>:<bridge>:<device>:<channel>. So, I think zigbee:092b2034 covers the coordinator (coordinator being the bridge), and 8418260000021d73 is your device, so zigbee:092b2034:8418260000021d73:switch_onoff (I think!) should be the channel.
Thanks. I’ll try that as soon as I can.
Unfortunately a.t.m. I cannot get my Zigbee Things to progress beyond the “Initializing” state any more, after launching OH2, Once I have that figured out (there are no clues in the log, unfortunately) I’ll create some Items based on these Things
