It’s involved in the evening events (as a separate rule) by dimming it. I disabled all the fasadlampa-rules yesterday evening to see if they interfere with my other rules. We will see in 15min’s when the sun rises!
Now everything fires correctly!?! I will reenable the fasadlampa-rules and wait for tomorrow!
I forget - but something in the order of an hour or two.
Ok, this is very old - I would strongly recommend using a newer binding.
I installed the 2.4.0 from within paperUI. Am I out of date on the whole OH installation or is the latest binding only available from github?
Use this script to update to the latest binding with OH running. You may then need to delete & re-discover your device Things.
Unfortunately that script fails with a timeout after two minutes trying to “Back up and uninstall any unmanaged installs of Zigbee…” !
Where do I even find the latest build? I can find the source code on GitHub, but where is the .jar-file?
That can happen when OpenHAB is not running. The README
file has the manual instructions.
Unfortunately Openhab is running…
It looks like these paths in the script are invalid?
curl -s --connect-timeout 10 --max-time 60 -o "org.openhab.binding.zigbee.cc2531.jar" -L "https://ci.openhab.org/job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zigbee.cc2531/artifact/org.openhab.addons.bundles/org.openhab.binding.zigbee.cc2531/${OH_VERSION}-SNAPSHOT/org.openhab.binding.zigbee.cc2531-${OH_VERSION}-SNAPSHOT.jar"
curl -s --connect-timeout 10 --max-time 60 -o "org.openhab.binding.zigbee.ember.jar" -L "https://ci.openhab.org/job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zigbee.ember/artifact/org.openhab.addons.bundles/org.openhab.binding.zigbee.ember/${OH_VERSION}-SNAPSHOT/org.openhab.binding.zigbee.ember-${OH_VERSION}-SNAPSHOT.jar"
curl -s --connect-timeout 10 --max-time 60 -o "org.openhab.binding.zigbee.telegesis.jar" -L "https://ci.openhab.org/job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zigbee.telegesis/artifact/org.openhab.addons.bundles/org.openhab.binding.zigbee.telegesis/${OH_VERSION}-SNAPSHOT/org.openhab.binding.zigbee.telegesis-${OH_VERSION}-SNAPSHOT.jar"
curl -s --connect-timeout 10 --max-time 60 -o "org.openhab.binding.zigbee.xbee.jar" -L "https://ci.openhab.org/job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zigbee.xbee/artifact/org.openhab.addons.bundles/org.openhab.binding.zigbee.xbee/${OH_VERSION}-SNAPSHOT/org.openhab.binding.zigbee.xbee-${OH_VERSION}-SNAPSHOT.jar"
curl -s --connect-timeout 10 --max-time 60 -o "org.openhab.binding.zigbee.jar" -L "https://ci.openhab.org/job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zigbee/artifact/org.openhab.addons.bundles/org.openhab.binding.zigbee/${OH_VERSION}-SNAPSHOT/org.openhab.binding.zigbee-${OH_VERSION}-SNAPSHOT.jar"
Did the script work for you after the update? I hadn’t tested it yet with Zigbee.
Yes, so far so good! I had to uninstall the 2.4.0 version installed through paperUI first, or it failed again, but that’s probably mentioned somewhere in the above thread?
@5iver After adding the controller I got this sequence in the log, not sure if I need to worry?
2019-10-18 20:25:53.105 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/inbox/zigbee:coordinator_telegesis:0000000C/approve
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910171234
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910171234
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 15 more
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910171234
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[?:?]
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
... 15 more
Caused by: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910171234
at com.sun.proxy.$Proxy183.<clinit>(Unknown Source) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:?]
at java.lang.reflect.Proxy.newProxyInstance(Proxy.java:739) ~[?:?]
at org.eclipse.smarthome.core.internal.common.SafeCallerBuilderImpl.lambda$0(SafeCallerBuilderImpl.java:68) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.smarthome.core.internal.common.SafeCallerBuilderImpl.build(SafeCallerBuilderImpl.java:59) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.doInitializeHandler(ThingManagerImpl.java:770) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.initializeHandler(ThingManagerImpl.java:672) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.registerAndInitializeHandler(ThingManagerImpl.java:1074) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.thingAdded(ThingManagerImpl.java:457) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:209) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:129) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:154) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:56) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:74) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:78) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.add(AbstractManagedProvider.java:61) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.add(AbstractRegistry.java:322) ~[?:?]
at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.addThingSafely(PersistentInbox.java:599) ~[?:?]
at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.approve(PersistentInbox.java:172) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.discovery.InboxResource.approve(InboxResource.java:104) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[?:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[?:?]
... 15 more
Yep, looks broken to me… Any thoughts? Am I getting incompatible versions of the components or am I missing any file? I currently got the following in my /addons/:
drwxr-xr-x 1 openhab openhab 1.1K Oct 18 20:12 .
drwxr-xr-x 1 openhab openhab 212 Oct 10 22:36 ..
drwxr-xr-x 1 openhab openhab 36 Oct 18 20:10 archive
-rwxr-xr-x 1 openhab openhab 214K Oct 18 20:12 com.zsmartsystems.zigbee.dongle.cc2531.jar
-rwxr-xr-x 1 openhab openhab 484K Oct 18 20:12 com.zsmartsystems.zigbee.dongle.ember.jar
-rwxr-xr-x 1 openhab openhab 131K Oct 18 20:12 com.zsmartsystems.zigbee.dongle.telegesis.jar
-rwxr-xr-x 1 openhab openhab 127K Oct 18 20:12 com.zsmartsystems.zigbee.dongle.xbee.jar
-rwxr-xr-x 1 openhab openhab 1.4M Oct 18 20:12 com.zsmartsystems.zigbee.jar
drwxrwxrwx 1 openhab openhab 140 Oct 18 19:55 @eaDir
drwxr-xr-x 1 1026 users 40 Oct 18 19:55 openHAB-utils-master
-rwxr-xr-x 1 1026 users 12K Oct 18 19:54 openHAB-utils-master.zip
-rwxr-xr-x 1 openhab openhab 536K Oct 18 20:12 org.apache.servicemix.bundles.xstream-1.4.7_1.jar
-rwxr-xr-x 1 openhab openhab 11K Oct 18 20:12 org.openhab.binding.zigbee.cc2531.jar
-rwxr-xr-x 1 openhab openhab 20K Oct 18 20:12 org.openhab.binding.zigbee.ember.jar
-rwxr-xr-x 1 openhab openhab 264K Oct 18 20:12 org.openhab.binding.zigbee.jar
-rwxr-xr-x 1 openhab openhab 16K Oct 18 20:12 org.openhab.binding.zigbee.telegesis.jar
-rwxr-xr-x 1 openhab openhab 11K Oct 18 20:12 org.openhab.binding.zigbee.xbee.jar
-rwxr-xr-x 1 openhab openhab 2.9M Oct 18 20:10 org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
-rwxr-xr-x 1 1026 users 37K Oct 16 12:53 zzManualInstaller.sh
No, that sounds like another issue. I only had time to test with zwave, but I’ll take a look at zigbee. The script should remove any installed versions.
However, based on the errors you are getting, it is very possible that the latest version of the binding is no longer compatible with OH 2.4. @chris, is this already known?
It won’t hurt anything the way you have it, but just the script itself (not the zip or directory) should be in /addons/. In fact, since the script will update itself, you can just delete these.
It should be ok - I’m using it here on a 2.4 system. I’ve not tested it with a Telegesis coordinator, but that shouldnt be an issue.
