Hi everybody,
Is there a way to get a network map on the zigbee binding that is similar to the z-wave binding?
I mean this map:
which can be found here:
Thank you,
Ramon
Hi everybody,
I mean this map:
Thank you,
Ramon
I don’t think the OH UI implements the Zigbee map. I did have an implementation in OH2, but OH3 uses a different UI.
ah I see, would be nice if it could be implemented in OH3 as well, to see if my zigbee network is robust or not. If it could be ported I would appreciate it. If not, then i guess i just have to manually inspect the restAPI. Not sure if actually making something similar is a lot of work as i guess it needs similar data.
Thx
