ZigBee network map when using only the ZigBee Binding
thanks @ndasyras for the reply. I tested it with latest modification from @abol3z
Below you can find my modified version to make it work with openHAB 3.x (which by default requires the use of an authentication token with REST API). As such I’ve replaced wget with curl (and added 3 variables to set the openHAB host, port and APIToken).
One question: Any idea when and how often the binding updates the routes and neighbor info?
#/bin/bash
openHABHost="192.168.XXX.XXX"
openHABPort="8080"
APIToken="qbmkfBVCTc2VL6g4-1kM1chuD5vZNDd38w....."
dir=$(mktemp -d)
#dir=.
curl -s -X GET "http://$openHABHost:$openHABPort/rest/things" -H "accept: application/json" -H "Authorization: Bearer $APIToken" -o $dir/things.json
# Replace with the "strict" version if it's too dense.
#echo "digraph G {" >> $dir/network.dot
echo "strict digraph G {" >> $dir/network.dot
echo "edge [decorate=true]" >> $dir/network.dot
echo "node [shape=box]" >> $dir/network.dot
echo "0 [label=<0<br/>COORDINATOR> color=blue]" >> $dir/network.dot
jq -r '.[] |
  select(.thingTypeUID | startswith("zigbee:")) |
  .properties.zigbee_networkaddress + " " +
    "label=<" +
    .properties.modelId + "<br/>" +
    .properties.zigbee_networkaddress + "<br/>" +
    (.properties.zigbee_macaddress // .configuration.zigbee_macaddress) + "<br/>" +
    .properties.zigbee_logicaltype + "<br/>" +
    .label + "<br/>" +
    .location +
    "color=" +
    if .statusInfo.status == "ONLINE" then "green"
    elif .statusInfo.status == "OFFLINE" then "orange"
    elif .statusInfo.status == "UNKNOWN" then "red"
    else "black" end +
' $dir/things.json >> $dir/network.dot
nodes=$(jq -r '.[] |
  select(.properties.zigbee_networkaddress != null) |
' $dir/things.json)
for node in ${nodes}; do
  jq -r --arg node $node '.[] |
    select(.properties.zigbee_networkaddress == $node) |
    select(.properties.zigbee_routes != "[]" and .properties.zigbee_routes != null) |
  ' $dir/things.json |
    $node + " -> " +
    if .destination != .next_hop then .next_hop + " -> " else "" end +
    .destination +
    "color=" +
    if .state == "ACTIVE" then "green"
    elif .state == "DISCOVERY_UNDERWAY" then "orange"
    elif .state == "DISCOVERY_FAILED" then "red"
    elif .state == "INACTIVE" then "blue"
    else "yellow" end + " " +
  ' >> $dir/network.dot
    select(.properties.zigbee_neighbors != "[]" and .properties.zigbee_neighbors != null) |
    $node + " -> " + .address + " " +
      "fontcolor=" +
      if .joining == "ENABLED" then "green"
      elif .joining == "DISABLED" then "black"
      elif .joining == "UNKNOWN" then "red"
      else "blue" end + " " +
      "label=<" +
      .lqi + "/" + .depth +
done
echo "label=\"`date +%Y-%m-%d\ %H:%M`\";" >> $dir/network.dot
echo "}" >> $dir/network.dot
# draw graph using dot or circo
/usr/bin/circo -Tpng $dir/network.dot -o ./zigbee_network.png
dot -Tpng $dir/network.dot -o ./zigbee_network.png
rm -rf $dir
In 2.5.8 zigbee Thing information seems to be updated once per day. Check in openhab events log for a line like this: “Thing ‘zigbee:coordinator_xxx’ has been updated.”
I think in OH3 it’s even possible to configure this update. I will try now with 5min (just for testing)
Same for me. Only with a update of 5 minutes, I get the data between the zigbee things. Otherwise not. Is it a bad thing for battery live to set this to 5 minutes permanently?
Hi Folks,
based on the scripts and ideas of this thread, I’ve created a completely new script that is not affected by the problems described here (like update cycle, etc.). My approach also gets rid of the problem with some coordinators that are not showing the neighbor data.
My new script does not use the REST Api, but instead uses the built-in zigbee commands in the openhab console. The script is written in python and only needs standard plugins that should be available everywhere.
Cons: As the script accesses the console several times for 1 complete run, it takes some seconds to complete, depending on the number of nodes in the network. In my case it takes about 20s.
This the output, that comes out on my zigbee network (Engine “neato”):
Engine “dot”:
Here is the script source:
#!/usr/bin/env python3
#import json # Only for debugging purposes
import re
import subprocess
import graphviz
from datetime import datetime
import os
output_filename = 'zigbee_map'
output_dir = '/etc/openhab/html/'
output_format = 'svg' #png, svg, dot
output_node_shape = 'box' # box, ellipse, circle, diamond, house, hexagon, octagon
output_line_shape = 'curved' # none, line, polyline, curved, ortho, spline
output_engine = 'neato' # dot, fdp, neato, circo
pwd = "Enter your console password here"   # -------------------- Change before usage! ----------------
zigbee_data = [];
cmd_basic = ["openhab-cli","console", "-p", pwd]
cmd_nodes = cmd_basic + ["zigbee", "nodes"]
cmd_neighbor = cmd_basic + ["zigbee", "neighbors"]
cmd_list_things = cmd_basic + ["things", "list"]
cmd_show_thing = cmd_basic + ["things", "show"]
# Zigbee properties
NETWORK_ADDR_SOURCE='network'
NETWORK_ADDR='network address'
MODEL = 'model'
IEEE_ADDR = 'ieee address'
LOGICAL_TYPE='logical type'
STATE = 'state'
LQI = 'lqi'
DEVICE_TYPE = 'device type'
RELATIONSHIP = 'relationship'
RELATIONSHIP_PARENT = 'parent'
RELATIONSHIP_SIBLING = 'sibling'
# Thing properties
LABEL = 'label'
STATUS = 'status'
ZB_NETWORK_ADDR = 'zigbee_networkaddress'
def export(filename, content):
    file = open(filename, 'w')
    file.write(content)
    file.close()
    return
def parse_nodes(raw_data):
    result_data =[];
    columns = []
    i = 0
    for line in raw_data.splitlines():
        if not line[0:8] == '        ':
            line = line.strip()                     # remove leading/trailing white spaces
            line = re.sub(r'\s\s+',r'\t', line)     # Replace multiple whitespaces by a tab as separator
            if line:
                if i == 0:
                    columns = re.sub(NETWORK_ADDR_SOURCE, NETWORK_ADDR, line.strip().lower()).split('\t')
                    if len(columns)>3:
                        i = i + 1
                else:
                    d = {}                          # dictionary to store file data (each line)
                    data = [item.strip() for item in line.split('\t')]
                    for index, elem in enumerate(data):
                        d[columns[index]] = data[index]
                    result_data.append(d)           # append dictionary to list
    return result_data
def parse_neighbor(raw_data):
    result_data = []
    columns = [];
    i = 0
        if i == 0:
            columns = line.lower().split('\t')
            if len(columns)>3:
                i = i + 1
        else:
    return result_data
def get_nodes_raw_data():
    try:
        proc = subprocess.run(cmd_nodes, capture_output=True)
        nodes_raw_data = subprocess.check_output(cmd_nodes,stderr=subprocess.STDOUT).decode('utf-8')
        print("Nodes:\n" + nodes_raw_data)
    except subprocess.CalledProcessError as e:
        raise RuntimeError("command '{}' return with error (code {}): {}\nerror: {}".format(e.cmd, e.returncode, e.output, e.stderr))
    return nodes_raw_data
def get_neighbor_raw_data(network_ID):
    try:
        neighbors_raw_data = subprocess.check_output(cmd_neighbor+[network_ID], stderr=subprocess.STDOUT).decode('utf-8')
        #export('tmp/neighbor' + network_ID + '.txt',neighbors_raw_data)
    return neighbors_raw_data
def get_thing_raw_data(uid):
    try:
        thing_raw_data = subprocess.check_output(cmd_show_thing + [uid], stderr=subprocess.STDOUT).decode('utf-8')
        #export('tmp/things.txt',thing_raw_data)
    return thing_raw_data
def get_thingUIDs_raw_data():
    try:
        thingUIDs_raw_data = subprocess.check_output(cmd_list_things, stderr=subprocess.STDOUT).decode('utf-8')
        #export('tmp/things.txt',thingUIDs_raw_data)
    return thingUIDs_raw_data
def get_thingUIDs(raw_data):
    thingUIDs = []
        if line.startswith('zigbee:coordinator') or line.startswith('zigbee:device'):
            thingUIDs.append(line.partition(' ')[0])
    return thingUIDs
def get_thing_information(thingUIDs):
    things = {}
    for thingUID in thingUIDs:
        print('Trying to get thing data for device: ' + thingUID)
        raw_data = get_thing_raw_data(thingUID)
        thing = {} # dictionary to store properties
            elements = line.partition(':')
            key = elements[0].strip().lower()
            value = elements[2].strip()
            if (not key == '') and not key in thing:
                thing[key] = value
        if not ZB_NETWORK_ADDR in thing:
            thing[ZB_NETWORK_ADDR] = '0'    # Must be the coordinator
        things[thing[ZB_NETWORK_ADDR]] = thing
    return things
#                   Main
print('Retrieving and parsing all Zigbee nodes..')
zigbee_data = parse_nodes(get_nodes_raw_data())
print('Retrieving all Things..')
thingUIDs = get_thingUIDs(get_thingUIDs_raw_data())
things = get_thing_information(thingUIDs)
# for debugging purposes only:
#print(json.dumps(things, indent=4))
#for debugging purposes only:
#print(json.dumps(zigbee_data, indent=4))
dot = graphviz.Digraph(comment='Zigbee-Map', name='ZigBee-Map', engine=output_engine)
dot.format = output_format
for device in zigbee_data:
    network_ID = device[NETWORK_ADDR]
    caption=''
    if (MODEL in device):
        caption = device[MODEL] + "\n" + network_ID + "\n" + device[IEEE_ADDR] + "\n" + device[DEVICE_TYPE] + "\n" + things[network_ID][LABEL]
    else:
        caption = "\n" + network_ID + "\n" + device[IEEE_ADDR] + "\n" + things[network_ID][LABEL]
    boxcolor = 'darkgreen' if things[network_ID][STATUS] == 'ONLINE' else 'orange' if device[STATE]=='ONLINE' else 'red'
    dot.node(network_ID, caption, color=boxcolor)
    if (LOGICAL_TYPE in device) and ((device[LOGICAL_TYPE].lower()=="router") or (device[LOGICAL_TYPE].lower()=="coordinator")):
        print("Trying to find neighbors for Zigbee device with network Address: " + network_ID)
        neighbors = parse_neighbor(get_neighbor_raw_data(network_ID))
        print ('Found: {} neighbors'.format(len(neighbors)))
        device['Neighbors'] = neighbors
        for neighbor in neighbors:
            if (NETWORK_ADDR in neighbor):
                if neighbor[RELATIONSHIP].lower() == RELATIONSHIP_PARENT:
                    thickness = '2'
                elif neighbor[RELATIONSHIP].lower() == RELATIONSHIP_SIBLING:
                    thickness = '1'
                else:
                    thickness = '0.5'
                dot.node(neighbor[NETWORK_ADDR], shape=output_node_shape)
                dot.edge(network_ID, neighbor[NETWORK_ADDR], neighbor[LQI], color='red' if int(neighbor[LQI]) < 20 else 'black', penwidth=thickness)
dot.attr(label=datetime.now().strftime('%Y-%m-%d %H:%M:%S'), root="0", splines=output_line_shape, overlap="scale")
dot.render(output_dir + output_filename)
I schedule the script via the executer addon in openhab.
Feedback would be nice, maybe we can improve it even more.
Have fun!
Hi! Have u evolved the project at all for OH4; im on a RPI4 and am looking to understand my network better.
Yes, the script is running well on openHAB 4.1.1
many thanks for the script. I am a Python newbie. When I run the script on openhab 4.3, I get the following error message:
Traceback (most recent call last):
  File "/etc/openhab/scripts/zigbeenet.py", line 92, in get_nodes_raw_data
  File "/usr/lib/python3.9/subprocess.py", line 424, in check_output
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  File "/usr/lib/python3.9/subprocess.py", line 528, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['openhab-cli', 'console', '-p', 'openhabian', 'zigbee', 'nodes']' returned non-zero exit status 1.
During handling of the above exception, another exception occurred:
  File "/etc/openhab/scripts/zigbeenet.py", line 150, in <module>
  File "/etc/openhab/scripts/zigbeenet.py", line 95, in get_nodes_raw_data
RuntimeError: command '['openhab-cli', 'console', '-p', 'openhabian', 'zigbee', 'nodes']' return with error (code 1): b'\nSLF4J(W): No SLF4J providers were fo                 und.\nSLF4J(W): Defaulting to no-operation (NOP) logger implementation\nSLF4J(W): See https://www.slf4j.org/codes.html#noProviders for further details.\nSLF4J                 (W): Class path contains SLF4J bindings targeting slf4j-api versions 1.7.x or earlier.\nSLF4J(W): Ignoring binding found at [jar:file:/usr/share/openhab/runti                 me/system/org/apache/karaf/org.apache.karaf.client/4.4.6/org.apache.karaf.client-4.4.6.jar!/org/slf4j/impl/StaticLoggerBinder.class]\nSLF4J(W): See https://ww                 w.slf4j.org/codes.html#ignoredBindings for an explanation.\nNo more authentication methods available\n'
error: None
How can I solve this? Thanks in advance!
I have found the solution. It was simply the use of an incorrect password. After I used the correct one the script works fine. Also on OH 4.3.
after some debugging i found a smal issue:
If you are using a special device like RWL021 then you might get sometimes the error message that a thing was not found. To fix this i did:
Modied this line:
into:
        if line.startswith('zigbee:coordinator') or line.startswith('zigbee:device') or line.startswith('zigbee:philips_rwl021'):
another thing i’ve adjusted:
if you are using docker you might also run the script outside of the container by installing “sshpass” like
apt-get install sshpass
and change
#cmd_basic = ["openhab-cli","console", "-p", pwd]
cmd_basic = ["sshpass","-p", pwd, "ssh", "openhab@localhost", "-p", "8101", "-q"]
Hi all,
now i just have the following issue:
the script runs unless this is displayed:
Trying to find neighbors for Zigbee device with network Address: 54752
Found: 27 neighbors
Trying to find neighbors for Zigbee device with network Address: 57383
Found: 27 neighbors
Trying to find neighbors for Zigbee device with network Address: 60740
Found: 28 neighbors
Trying to find neighbors for Zigbee device with network Address: 61538
Found: 21 neighbors
But then the “dot” process takes 100% CPU at the moment for 14 minutes.
Anyone has an idea why?
top - 11:10:18 up 16:07,  2 users,  load average: 1.01, 1.08, 0.91
Tasks: 186 total,   2 running, 184 sleeping,   0 stopped,   0 zombie
%Cpu(s): 26.5 us,  1.1 sy,  0.0 ni, 72.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   7821.9 total,   2851.0 free,   2052.0 used,   3024.9 buff/cache
MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5769.8 avail Mem
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
 294592 frsc      20   0  176040  16256  11008 R  99.7   0.2  14:07.48 dot
To ensure better performance than my Raspberry Pi, I downloaded the zigbee_map file and attempted to render it on my 11th Gen Core i7-11850H @ 2.50GHz with 16GB of RAM.
Result: After 6 hours, there was still no output.
Does it take this long in our setup as well?
I’ve attached the my file if someone wants to take a look
zigbee_map_anonymized_macs.txt (56.7 KB)
Hello friends,
Finally i got support from the graphviz team see here:
long story short:
creates the long rendering time. and can be replayed with
output_line_shape = 'true'
Now it renders within a minute.
Hi all, I wrote a small program for myself that visualizes a map of zigbee devices using vis.js. Maybe someone will find it useful. The program works locally using REST API therefore you will need a key. I will be glad to get feedback.
What is needed:
  1. Download the archive and extract the files into the \\YOUR_IP\openHAB-conf\html folder.
    You should get
\\YOUR_IP\openHAB-conf\html\zb-map\index.html
\\YOUR_IP\openHAB-conf\html\zb-map\zbmap.js
  1. Generate an API key in your OpenHAB settings
  2. Copy your UID in the thing section
  3. Paste the API key and UID of the coordinator into the zbmap.js file
  4. Navigate in your browser to https://YOUR_IP:8443/static/zb-map/
The map is interactive. Node positions are stored in the browser’s localstorage.
Routes are built from segments of different routers. Unfortunately my network is small and I can’t test building routes consisting of more than one hop
Hi, this sounds super cool. Thanks for your efforts already.
I’ve pasted the API key already and this one is working (no more auth required).
Now i get this error:
I’ve just installed it but get:
zbmap.js:329 SyntaxError: "undefined" is not valid JSON
    at JSON.parse (<anonymous>)
    at zbmap.js:103:10
    at Array.forEach (<anonymous>)
    at zbmap.js:101:53
(anonymous) @ zbmap.js:329
Promise.catch
(anonymous) @ zbmap.js:328
I have updated the archive, now this error should not occur
Hi, thanks a lot so far.No it already steps a bit forward.
zbmap.js:333 TypeError: Cannot set properties of undefined (setting 'hasNeighbors')
    at zbmap.js:222:59
    at zbmap.js:218:50
    at zbmap.js:215:53
(anonymous) @ zbmap.js:333
fixed
Thanks @aleksey.kurchavy ,
after some drag and drop it looks like that.
This looks really weird! There are no neighbors or routes in your network. Please look at the properties of your any router devices (are shown in yellow in the graph). Are they really empty?
Sorry, it’s working now.
Dont know why but it does.
Thank you very much for your support.
Is there something that i could analyze now with that chart? Like weak connections?
