I set up a Linear husbzb-1 last night here at home. I was able to move my Zwave Gen5 info over to the new Linear stick via the ‘shift’ techinque, but I can’t seem to get the Zigbee working correctly.
I installed the Zigbee binding, and added an Ember EM35x controller. I set the port /ttyUSB1 and the baud rate to 57600. This seems correct and the controller shows online, nice green checkmark in Habmin.
I then was able to actually link 2 bulbs to the controller, an GE Link bulb, and a Osram A19 RGB bulb. Both shows as unknown devices but did show as online with their channel info.
I add both lights to my items file as follows:
Color TestZigbee "Test Zigbee Light" { channel="zigbee:device:161a65d9f8a:7cb03eaa00b0013d:7CB03EAA00B0013D:3:color:color"}
Dimmer TestGeBulb "Test GE Light" { channel="zigbee:device:161a65d9f8a:7ce5240000046c31:7CE5240000046C31:1:switch:level"}
But I was then unable to control either light in a sitemap. I also tried them as …:color_color and …:switch_level but could not control them.
So I then deleted both devices within Habmin. But not when the Zigbee binding searches again it does not find either bulb? And both lights still appear linked to the controller and do not shows as unlinked when I turn them OFF and back ON.
I turned on debugging and this what I see in the log when trying to search
2018-02-18 12:17:04.922 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_ember:161a65d9f8a
2018-02-18 12:17:04.923 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Permit join to 65532/0 for 60 seconds.
2018-02-18 12:17:04.924 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0/0 -> 65532/0, cluster=0036, TID=0F, permitDuration=60, tcSignificance=true]
2018-02-18 12:17:04.924 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=65532/0, profile=0000, cluster=54, addressMode=DEVICE, radius=31, sequence=15, payload=00 3C 01]
2018-02-18 12:17:04.924 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EzspSendBroadcastRequest [destination=65532, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=15], radius=31, messageTag=15, messageContents=00 3C 01]
2018-02-18 12:17:04.925 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - TX EZSP queue: 1
2018-02-18 12:17:04.925 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - TX EZSP: EzspSendBroadcastRequest [destination=65532, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=15], radius=31, messageTag=15, messageContents=00 3C 01]
2018-02-18 12:17:04.926 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=7, ackNum=2, reTx=false, data=0F 00 36 FC FF 00 00 36 00 00 00 40 11 00 00 0F 1F 0F 03 00 3C 01]
2018-02-18 12:17:04.928 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0/0 -> 0/0, cluster=0036, TID=10, permitDuration=60, tcSignificance=true]
2018-02-18 12:17:04.928 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=54, addressMode=DEVICE, radius=31, sequence=16, payload=00 3C 01]
2018-02-18 12:17:04.930 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EzspSendUnicastRequest [type=EMBER_OUTGOING_DIRECT, indexOrDestination=0, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=16], messageTag=16, messageContents=00 3C 01]
2018-02-18 12:17:04.931 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - TX EZSP queue: 1
2018-02-18 12:17:04.931 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - Sent queue larger than window [1 > 1].
2018-02-18 12:17:05.042 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=2, ackNum=0, reTx=false, data=0F 80 36 00 EF]
2018-02-18 12:17:05.042 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - RX EZSP: EzspSendBroadcastResponse [status=EMBER_SUCCESS, sequence=239]
2018-02-18 12:17:05.043 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspSendBroadcastResponse [status=EMBER_SUCCESS, sequence=239]
2018-02-18 12:17:05.043 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspSendBroadcastResponse [status=EMBER_SUCCESS, sequence=239]
2018-02-18 12:17:05.043 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - TX EZSP: EzspSendUnicastRequest [type=EMBER_OUTGOING_DIRECT, indexOrDestination=0, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=16], messageTag=16, messageContents=00 3C 01]
2018-02-18 12:17:05.043 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=0, ackNum=3, reTx=false, data=10 00 34 00 00 00 00 00 36 00 00 00 40 11 00 00 10 10 03 00 3C 01]
2018-02-18 12:17:05.044 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=3, ackNum=0, reTx=false, data=0F 90 45 05 00 00 36 00 00 00 08 01 00 00 EF FF 00 00 00 FF FF 03 00 3C 01]
2018-02-18 12:17:05.044 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - RX EZSP: EzspIncomingMessageHandler [type=EMBER_INCOMING_BROADCAST_LOOPBACK, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=239], lastHopLqi=255, lastHopRssi=0, sender=0, bindingIndex=255, addressIndex=255, messageContents=00 3C 01]
2018-02-18 12:17:05.044 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspIncomingMessageHandler [type=EMBER_INCOMING_BROADCAST_LOOPBACK, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=239], lastHopLqi=255, lastHopRssi=0, sender=0, bindingIndex=255, addressIndex=255, messageContents=00 3C 01]
2018-02-18 12:17:05.044 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=54, addressMode=null, radius=0, sequence=15, payload=00 3C 01]
2018-02-18 12:17:05.045 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningRequest [0/0 -> 0/0, cluster=0036, TID=NULL, permitDuration=60, tcSignificance=true]
2018-02-18 12:17:05.045 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - Sent queue larger than window [1 > 1].
2018-02-18 12:17:05.045 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=4]
2018-02-18 12:17:05.162 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameNak [ackNum=0]
2018-02-18 12:17:05.163 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=0, ackNum=4, reTx=true, data=10 00 34 00 00 00 00 00 36 00 00 00 40 11 00 00 10 10 03 00 3C 01]
2018-02-18 12:17:05.163 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - Sent queue larger than window [1 > 1].
2018-02-18 12:17:05.289 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameAck [ackNum=1]
2018-02-18 12:17:05.289 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=4, ackNum=1, reTx=false, data=10 80 34 00 F0]
2018-02-18 12:17:05.289 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - RX EZSP: EzspSendUnicastResponse [status=EMBER_SUCCESS, sequence=240]
2018-02-18 12:17:05.290 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspSendUnicastResponse [status=EMBER_SUCCESS, sequence=240]
2018-02-18 12:17:05.290 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspSendUnicastResponse [status=EMBER_SUCCESS, sequence=240]
2018-02-18 12:17:05.290 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=5]
2018-02-18 12:17:05.290 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=5, ackNum=1, reTx=false, data=10 90 45 00 00 00 36 00 00 00 40 01 00 00 F0 FF 00 00 00 FF FF 03 00 3C 01]
2018-02-18 12:17:05.291 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - RX EZSP: EzspIncomingMessageHandler [type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=240], lastHopLqi=255, lastHopRssi=0, sender=0, bindingIndex=255, addressIndex=255, messageContents=00 3C 01]
2018-02-18 12:17:05.291 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspIncomingMessageHandler [type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=240], lastHopLqi=255, lastHopRssi=0, sender=0, bindingIndex=255, addressIndex=255, messageContents=00 3C 01]
2018-02-18 12:17:05.291 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=54, addressMode=null, radius=0, sequence=16, payload=00 3C 01]
2018-02-18 12:17:05.292 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningRequest [0/0 -> 0/0, cluster=0036, TID=NULL, permitDuration=60, tcSignificance=true]
2018-02-18 12:17:05.292 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=6]
2018-02-18 12:17:05.292 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=6, ackNum=1, reTx=false, data=10 90 45 00 00 00 36 80 00 00 40 01 00 00 F1 FF 00 00 00 FF FF 02 00 00]
2018-02-18 12:17:05.293 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - RX EZSP: EzspIncomingMessageHandler [type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0, clusterId=32822, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=241], lastHopLqi=255, lastHopRssi=0, sender=0, bindingIndex=255, addressIndex=255, messageContents=00 00]
2018-02-18 12:17:05.293 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspIncomingMessageHandler [type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0, clusterId=32822, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=241], lastHopLqi=255, lastHopRssi=0, sender=0, bindingIndex=255, addressIndex=255, messageContents=00 00]
2018-02-18 12:17:05.293 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32822, addressMode=null, radius=0, sequence=16, payload=00 00]
2018-02-18 12:17:05.293 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningResponse [0/0 -> 0/0, cluster=8036, TID=NULL, status=SUCCESS]
2018-02-18 12:17:05.294 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=7]
2018-02-18 12:17:05.298 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=7, ackNum=1, reTx=false, data=10 90 3F 00 00 00 00 00 36 00 00 00 40 11 00 00 F0 10 00 00]
2018-02-18 12:17:05.299 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - RX EZSP: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=0, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=240], messageTag=16, status=EMBER_SUCCESS, messageContents=]
2018-02-18 12:17:05.299 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=0, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=240], messageTag=16, status=EMBER_SUCCESS, messageContents=]
2018-02-18 12:17:05.300 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspMessageSentHandler [type=EMBER_OUTGOING_DIRECT, indexOrDestination=0, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=240], messageTag=16, status=EMBER_SUCCESS, messageContents=]
2018-02-18 12:17:05.300 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=0]
2018-02-18 12:17:05.947 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=0, ackNum=1, reTx=false, data=10 90 3F 04 FC FF 00 00 36 00 00 00 08 01 00 00 EF 0F 00 00]
2018-02-18 12:17:05.947 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - RX EZSP: EzspMessageSentHandler [type=EMBER_OUTGOING_MULTICAST_WITH_ALIAS, indexOrDestination=65532, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=239], messageTag=15, status=EMBER_SUCCESS, messageContents=]
2018-02-18 12:17:05.948 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX: EzspMessageSentHandler [type=EMBER_OUTGOING_MULTICAST_WITH_ALIAS, indexOrDestination=65532, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=239], messageTag=15, status=EMBER_SUCCESS, messageContents=]
2018-02-18 12:17:05.948 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unhandled EZSP Frame: EzspMessageSentHandler [type=EMBER_OUTGOING_MULTICAST_WITH_ALIAS, indexOrDestination=65532, apsFrame=EmberApsFrame [profileId=0, clusterId=54, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=239], messageTag=15, status=EMBER_SUCCESS, messageContents=]
2018-02-18 12:17:05.948 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNu
Does anyone know of another software that you can access the zigbee controller and see what is on it? Should I attempt to reset the controller in Habmin and then reset the bulbs and try again?
