Thank you Wiese, doing it in the correct order is the first step. I just did as you describe (bulb is just a few cm from the USB-device. I blinked six time and got a confirmation blink, turned off the bulb for a few seconds, turned it back on and started a search for devices on the zigbee binding under inbox) but unfortunately nothing was found!
The sequence showed up in the logg as:
2019-02-20 09:39:39.372 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:+N=COO,11,-07,B759,C94BE0E458776313
2019-02-20 09:39:39.373 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:39.373 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisDisplayNetworkInformationCommand [device=COO, channel=11, power=-7, panId=46937, epanId=C94BE0E458776313, status=SUCCESS]
2019-02-20 09:39:39.941 [DEBUG] [p.discovery.ZigBeeDiscoveryExtension] - DISCOVERY Extension: Starting mesh update
2019-02-20 09:39:39.942 [DEBUG] [p.discovery.ZigBeeDiscoveryExtension] - DISCOVERY Extension: Starting mesh update for 000D6F000AEC3BEB
2019-02-20 09:39:39.942 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: Update mesh
2019-02-20 09:39:39.943 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: scheduled [ROUTES, NEIGHBORS]
2019-02-20 09:39:39.937 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_telegesis:0000000C
2019-02-20 09:39:39.946 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Permit join to 65532/0 for 60 seconds.
2019-02-20 09:39:39.948 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0/0 -> 65532/0, cluster=0036, TID=2B, permitDuration=60, tcSignificance=true]
2019-02-20 09:39:39.949 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=65532/0, profile=0000, cluster=54, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=43, payload=00 3C 01]
2019-02-20 09:39:39.950 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendMulticastCommand [radius=31, address=65532, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01]
2019-02-20 09:39:39.951 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:39.951 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendMulticastCommand [radius=31, address=65532, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01]
2019-02-20 09:39:39.953 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDMCASTB:03,1F,FFFC,00,00,0000,0036
2019-02-20 09:39:39.954 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0/0 -> 0/0, cluster=0036, TID=2C, permitDuration=60, tcSignificance=true]
2019-02-20 09:39:39.954 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=54, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=44, payload=00 3C 01]
2019-02-20 09:39:39.955 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01, messageId=null]
2019-02-20 09:39:39.956 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:40.080 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:40.081 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendMulticastCommand [radius=31, address=65532, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01, status=SUCCESS]
2019-02-20 09:39:40.081 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01, messageId=null]
2019-02-20 09:39:40.082 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDUCASTB:03,0000,00,00,0000,0036
2019-02-20 09:39:40.241 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:SEQ:36
2019-02-20 09:39:40.242 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:40.242 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=54, messageData=00 3C 01, messageId=54, status=SUCCESS]
2019-02-20 09:39:40.243 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:0000,0000,00,00,8036,02:,00,FF
2019-02-20 09:39:40.243 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ieeeAddress=null, networkAddress=0, profileId=0, destinationEp=0, sourceEp=0, clusterId=32822, messageData=00 00, rssi=0, lqi=255]
2019-02-20 09:39:40.244 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32822, addressMode=null, radius=0, apsSecurity=false, apsCounter=0, payload=00 00]
2019-02-20 09:39:40.245 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningResponse [0/0 -> 0/0, cluster=8036, TID=NULL, status=SUCCESS]
2019-02-20 09:39:40.246 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:ACK:36
2019-02-20 09:39:40.247 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisAckMessageEvent [messageId=54]
2019-02-20 09:39:40.247 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Unhandled Telegesis Frame: TelegesisAckMessageEvent [messageId=54]
2019-02-20 09:39:40.724 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: running
2019-02-20 09:39:40.725 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=2D, startIndex=0]
2019-02-20 09:39:40.727 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=50, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=45, payload=00 00]
2019-02-20 09:39:40.727 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 00, messageId=null]
2019-02-20 09:39:40.727 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:40.728 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 00, messageId=null]
2019-02-20 09:39:40.729 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDUCASTB:02,0000,00,00,0000,0032
2019-02-20 09:39:40.928 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:SEQ:38
2019-02-20 09:39:40.929 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:40.929 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 00, messageId=56, status=SUCCESS]
2019-02-20 09:39:40.930 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:0000,0000,00,00,8032,50:@9,00,FF
2019-02-20 09:39:40.931 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ieeeAddress=null, networkAddress=0, profileId=0, destinationEp=0, sourceEp=0, clusterId=32818, messageData=00 00 40 00 0F 00 00 39 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00, rssi=0, lqi=255]
2019-02-20 09:39:40.932 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32818, addressMode=null, radius=0, apsSecurity=false, apsCounter=0, payload=00 00 40 00 0F 00 00 39 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00]
2019-02-20 09:39:40.933 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=0, routingTableList=[RoutingTable [destinationAddress=0, status=DISCOVERY_UNDERWAY, memoryConstrained=true, manyToOne=true, routeRecordRequired=true, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]
2019-02-20 09:39:40.934 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:ACK:38
2019-02-20 09:39:40.935 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisAckMessageEvent [messageId=56]
2019-02-20 09:39:40.935 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Unhandled Telegesis Frame: TelegesisAckMessageEvent [messageId=56]
2019-02-20 09:39:40.938 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction complete: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=2D, startIndex=0]
2019-02-20 09:39:40.954 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementRoutingRequest returned CommandResult [SUCCESS, ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=0, routingTableList=[RoutingTable [destinationAddress=0, status=DISCOVERY_UNDERWAY, memoryConstrained=true, manyToOne=true, routeRecordRequired=true, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]]
2019-02-20 09:39:40.955 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=2E, startIndex=15]
2019-02-20 09:39:40.958 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=50, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=46, payload=00 0F]
2019-02-20 09:39:40.958 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 0F, messageId=null]
2019-02-20 09:39:40.959 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:40.960 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 0F, messageId=null]
2019-02-20 09:39:40.962 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDUCASTB:02,0000,00,00,0000,0032
2019-02-20 09:39:41.238 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:SEQ:3A
2019-02-20 09:39:41.239 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:41.239 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 0F, messageId=58, status=SUCCESS]
2019-02-20 09:39:41.240 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:0000,0000,00,00,8032,50:@,00,FF
2019-02-20 09:39:41.241 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ieeeAddress=null, networkAddress=0, profileId=0, destinationEp=0, sourceEp=0, clusterId=32818, messageData=00 00 40 0F 0F 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00, rssi=0, lqi=255]
2019-02-20 09:39:41.242 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32818, addressMode=null, radius=0, apsSecurity=false, apsCounter=0, payload=00 00 40 0F 0F 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00]
2019-02-20 09:39:41.242 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=15, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]
2019-02-20 09:39:41.244 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction complete: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=2E, startIndex=15]
2019-02-20 09:39:41.245 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementRoutingRequest returned CommandResult [SUCCESS, ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=15, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]]
2019-02-20 09:39:41.246 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=2F, startIndex=30]
2019-02-20 09:39:41.246 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=50, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=47, payload=00 1E]
2019-02-20 09:39:41.246 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 1E, messageId=null]
2019-02-20 09:39:41.246 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:41.247 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 1E, messageId=null]
2019-02-20 09:39:41.249 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDUCASTB:02,0000,00,00,0000,0032
2019-02-20 09:39:41.249 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:ACK:3A
2019-02-20 09:39:41.249 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisAckMessageEvent [messageId=58]
2019-02-20 09:39:41.250 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Unhandled Telegesis Frame: TelegesisAckMessageEvent [messageId=58]
2019-02-20 09:39:41.447 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:SEQ:3C
2019-02-20 09:39:41.448 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:41.448 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 1E, messageId=60, status=SUCCESS]
2019-02-20 09:39:41.450 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:0000,0000,00,00,8032,50:@,00,FF
2019-02-20 09:39:41.451 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ieeeAddress=null, networkAddress=0, profileId=0, destinationEp=0, sourceEp=0, clusterId=32818, messageData=00 00 40 1E 0F 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00, rssi=0, lqi=255]
2019-02-20 09:39:41.452 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32818, addressMode=null, radius=0, apsSecurity=false, apsCounter=0, payload=00 00 40 1E 0F 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00]
2019-02-20 09:39:41.452 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=30, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]
2019-02-20 09:39:41.453 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:ACK:3C
2019-02-20 09:39:41.454 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisAckMessageEvent [messageId=60]
2019-02-20 09:39:41.454 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Unhandled Telegesis Frame: TelegesisAckMessageEvent [messageId=60]
2019-02-20 09:39:41.456 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction complete: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=2F, startIndex=30]
2019-02-20 09:39:41.457 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementRoutingRequest returned CommandResult [SUCCESS, ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=30, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]]
2019-02-20 09:39:41.458 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=30, startIndex=45]
2019-02-20 09:39:41.458 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=50, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=48, payload=00 2D]
2019-02-20 09:39:41.458 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 2D, messageId=null]
2019-02-20 09:39:41.459 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:41.459 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 2D, messageId=null]
2019-02-20 09:39:41.460 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDUCASTB:02,0000,00,00,0000,0032
2019-02-20 09:39:41.659 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:SEQ:3E
2019-02-20 09:39:41.660 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:41.660 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 2D, messageId=62, status=SUCCESS]
2019-02-20 09:39:41.661 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:0000,0000,00,00,8032,50:@-,00,FF
2019-02-20 09:39:41.662 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ieeeAddress=null, networkAddress=0, profileId=0, destinationEp=0, sourceEp=0, clusterId=32818, messageData=00 00 40 2D 0F 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00, rssi=0, lqi=255]
2019-02-20 09:39:41.663 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32818, addressMode=null, radius=0, apsSecurity=false, apsCounter=0, payload=00 00 40 2D 0F 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00]
2019-02-20 09:39:41.663 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=45, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]
2019-02-20 09:39:41.665 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:ACK:3E
2019-02-20 09:39:41.665 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction complete: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=30, startIndex=45]
2019-02-20 09:39:41.666 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisAckMessageEvent [messageId=62]
2019-02-20 09:39:41.666 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementRoutingRequest returned CommandResult [SUCCESS, ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=45, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]]
2019-02-20 09:39:41.667 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=31, startIndex=60]
2019-02-20 09:39:41.668 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=50, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=49, payload=00 3C]
2019-02-20 09:39:41.668 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 3C, messageId=null]
2019-02-20 09:39:41.669 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:41.669 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Unhandled Telegesis Frame: TelegesisAckMessageEvent [messageId=62]
2019-02-20 09:39:41.669 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 3C, messageId=null]
2019-02-20 09:39:41.671 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDUCASTB:02,0000,00,00,0000,0032
2019-02-20 09:39:41.841 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:SEQ:40
2019-02-20 09:39:41.842 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:41.842 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=50, messageData=00 3C, messageId=64, status=SUCCESS]
2019-02-20 09:39:41.843 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:0000,0000,00,00,8032,19:@<,00,FF
2019-02-20 09:39:41.844 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ieeeAddress=null, networkAddress=0, profileId=0, destinationEp=0, sourceEp=0, clusterId=32818, messageData=00 00 40 3C 04 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00, rssi=0, lqi=255]
2019-02-20 09:39:41.844 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32818, addressMode=null, radius=0, apsSecurity=false, apsCounter=0, payload=00 00 40 3C 04 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00 00 00 03 00 00]
2019-02-20 09:39:41.845 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=60, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]
2019-02-20 09:39:41.846 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction complete: ManagementRoutingRequest [0/0 -> 0/0, cluster=0032, TID=31, startIndex=60]
2019-02-20 09:39:41.847 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:ACK:40
2019-02-20 09:39:41.848 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisAckMessageEvent [messageId=64]
2019-02-20 09:39:41.848 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Unhandled Telegesis Frame: TelegesisAckMessageEvent [messageId=64]
2019-02-20 09:39:41.848 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementRoutingRequest returned CommandResult [SUCCESS, ManagementRoutingResponse [0/0 -> 0/0, cluster=8032, TID=NULL, status=SUCCESS, routingTableEntries=64, startIndex=60, routingTableList=[RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]]]
2019-02-20 09:39:41.849 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementLqiRequest complete [2 routes]
2019-02-20 09:39:41.850 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 000D6F000AEC3BEB: Routing table NEW: [RoutingTable [destinationAddress=0, status=DISCOVERY_UNDERWAY, memoryConstrained=true, manyToOne=true, routeRecordRequired=true, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]
2019-02-20 09:39:41.850 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 000D6F000AEC3BEB: Routing table OLD: [RoutingTable [destinationAddress=0, status=DISCOVERY_UNDERWAY, memoryConstrained=true, manyToOne=true, routeRecordRequired=true, nextHopAddress=0], RoutingTable [destinationAddress=0, status=INACTIVE, memoryConstrained=false, manyToOne=false, routeRecordRequired=false, nextHopAddress=0]]
2019-02-20 09:39:41.851 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 000D6F000AEC3BEB: Routing table unchanged
2019-02-20 09:39:41.851 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: request ROUTES successful. Advanced to NEIGHBORS.
2019-02-20 09:39:41.852 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: running
2019-02-20 09:39:41.853 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementLqiRequest [0/0 -> 0/0, cluster=0031, TID=32, startIndex=0]
2019-02-20 09:39:41.853 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=49, addressMode=DEVICE, radius=31, apsSecurity=false, apsCounter=50, payload=00 00]
2019-02-20 09:39:41.854 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Telegesis send: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=49, messageData=00 00, messageId=null]
2019-02-20 09:39:41.854 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:41.855 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=49, messageData=00 00, messageId=null]
2019-02-20 09:39:41.857 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+SENDUCASTB:02,0000,00,00,0000,0031
2019-02-20 09:39:42.017 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:SEQ:42
2019-02-20 09:39:42.017 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:OK
2019-02-20 09:39:42.018 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisSendUnicastCommand [address=0, sourceEp=0, destEp=0, profileId=0, clusterId=49, messageData=00 00, messageId=66, status=SUCCESS]
2019-02-20 09:39:42.019 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:0000,0000,00,00,8031,05:,00,FF
2019-02-20 09:39:42.019 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ieeeAddress=null, networkAddress=0, profileId=0, destinationEp=0, sourceEp=0, clusterId=32817, messageData=00 00 00 00 00, rssi=0, lqi=255]
2019-02-20 09:39:42.020 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=0/0, profile=0000, cluster=32817, addressMode=null, radius=0, apsSecurity=false, apsCounter=0, payload=00 00 00 00 00]
2019-02-20 09:39:42.020 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementLqiResponse [0/0 -> 0/0, cluster=8031, TID=NULL, status=SUCCESS, neighborTableEntries=0, startIndex=0, neighborTableList=[]]
2019-02-20 09:39:42.022 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction complete: ManagementLqiRequest [0/0 -> 0/0, cluster=0031, TID=32, startIndex=0]
2019-02-20 09:39:42.022 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:ACK:42
2019-02-20 09:39:42.022 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementLqiRequest response CommandResult [SUCCESS, ManagementLqiResponse [0/0 -> 0/0, cluster=8031, TID=NULL, status=SUCCESS, neighborTableEntries=0, startIndex=0, neighborTableList=[]]]
2019-02-20 09:39:42.023 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisAckMessageEvent [messageId=66]
2019-02-20 09:39:42.023 [DEBUG] [ngle.telegesis.ZigBeeDongleTelegesis] - Unhandled Telegesis Frame: TelegesisAckMessageEvent [messageId=66]
2019-02-20 09:39:42.023 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: ManagementLqiRequest complete [0 neighbors]
2019-02-20 09:39:42.024 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 000D6F000AEC3BEB: Neighbor table unchanged
2019-02-20 09:39:42.024 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: request NEIGHBORS successful. Advanced to null.
2019-02-20 09:39:42.025 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: running
2019-02-20 09:39:42.025 [DEBUG] [iscovery.ZigBeeNodeServiceDiscoverer] - 000D6F000AEC3BEB: Node SVC Discovery: complete
2019-02-20 09:39:42.026 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000AEC3BEB: Node 0 update
2019-02-20 09:39:42.034 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2019-02-20 09:39:42.040 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2019-02-20 09:39:43.023 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis queue: 1
2019-02-20 09:39:43.024 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis: TelegesisDisplayNetworkInformationCommand [device=null, channel=null, power=null, panId=null, epanId=null]
2019-02-20 09:39:43.024 [DEBUG] [gesis.internal.TelegesisFrameHandler] - TX Telegesis Data:AT+N?
Any thoughts?
Henrik
