autodiscovery on MQTT binding started to somehow work, including all the items. Very nice.
The problem is discovered Things names, instead of “Garage Temperature” it is “Garage Temperature (Sensor, Sensor, Sensor, Sensor, Sensor, Sensor, Sensor)” for Aquara Temperature sensor. Follows the same theme for Ikea products, and also others.
Would be grateful for any hints.
My setup is: Debian, latest zigbee2mqtt on docker with homeassistant integration enabled, mosquitto mqtt, Openhab 3.2.0M4.
Thanks in advance
