Platform information:
Ubuntu Server 16.04.7
Mosquitto ver. 2.0.7
openHAB 2 ver. 2.5.5
zigbee2mqtt ver. 1.17.1
Hardware:
Sonoff CC2531 USB stick coordinator zStack 1.2, rev. 20180507, channel: 11
MiJia door sensor MCCGQ01LM
/*************************** mijia.things ****************************/
Bridge mqtt:broker:644a0a87 [ host="localhost", secure=true, username="openhab", password="12345" ]
Thing topic MijiaDoorSensor "MiJia door contact sensor" @ "Hall"
{ Channels:
Type contact : status "status" [ stateTopic = "zigbee2mqtt/mijiacontactsensor/contact", on="false", off="true" ]
Type number : voltage "voltage" [ stateTopic = "zigbee2mqtt/mijiacontactsensor/voltage" ]
Type number : battery "battery" [ stateTopic = "zigbee2mqtt/mijiacontactsensor/battery" ]
Type number : linkquality "linkquality" [ stateTopic = "zigbee2mqtt/mijiacontactsensor/linkquality" ]
Type datetime : last_change "last change" [ stateTopic = "zigbee2mqtt/mijiacontactsensor/last_seen" ]
/******************* mijia.items ****************************/
Contact door_window_sensor_isOpen "open status" <door> {channel="mqtt:topic:644a0a87:MijiaDoorSensor:status"}
Number door_window_sensor_VOLTAGE "voltage [%d mV]" {channel="mqtt:topic:644a0a87:MijiaDoorSensor:voltage"}
Number door_window_sensor_BATTERY "battery [%1.0f %%]" <battery> {channel="mqtt:topic:644a0a87:MijiaDoorSensor:battery"}
Number door_window_sensor_LINKQUALITY "link qualitiy [%d]" <qualityofservice> {channel="mqtt:topic:644a0a87:MijiaDoorSensor:linkquality"}
DateTime door_window_sensor_last_change "last change [%1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS]" <calendar> {channel="mqtt:topic:644a0a87:MijiaDoorSensor:last_change"}
configuration.yaml
homeassistant: false
mqtt:
base_topic: zigbee2mqtt
password: 12345
server: 'mqtt://127.0.0.1:1883'
user: openhab
permit_join: false
serial:
disable_led: true
port: /dev/ttyACM0
devices:
'0x00158d00027cff67':
friendly_name: mijiacontactsensor
retain: false
advanced:
last_seen: ISO_8601_local
experimental:
output: attribute
#\n\nadvanced:\n network_key: GENERATE
/etc/systemd/system/zigbee2mqtt.service
[Unit]
Description=zigbee2mqtt
After=network.target
[Service]
ExecStart=/usr/bin/npm start
WorkingDirectory=/opt/zigbee2mqtt
StandardOutput=inherit
StandardError=inherit
Restart=always
User=openhab
[Install]
WantedBy=multi-user.target
What am I missing? Every hour I see a new meaning in the interface. Nobody opens the door. I open and then close the door and everything is correctly displayed in the openHAB, but exactly one hour later there is a change in the time. I left the terminal open and this comes from the broker. retain: false or retain: true - no difference.
Thanks in advance for the help.
