Hello together
I need your support. I am disillusioned.
Some time ago, my system was still running without problems. But suddenly it only causes problems.
At the start zigbee2MQTT crashed.
Zigbee2MQTT:info 2021-09-28 07:30:03: Logging to console and directory: ‘/opt/zigbee2mqtt/data/log/2021-09-28.07-30-02’ filename: log.txt
Zigbee2MQTT:info 2021-09-28 07:30:04: Starting Zigbee2MQTT version 1.21.1 (commit #4a51e0c0)
Zigbee2MQTT:info 2021-09-28 07:30:04: Starting zigbee-herdsman (0.13.138)
Zigbee2MQTT:error 2021-09-28 07:30:24: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-09-28 07:30:24: Failed to start zigbee
Zigbee2MQTT:error 2021-09-28 07:30:24: Check Frequently asked questions | zigbee2mqtt.io for possible solutions
Zigbee2MQTT:error 2021-09-28 07:30:24: Exiting…
Zigbee2MQTT:error 2021-09-28 07:30:24: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:102:27)
at Controller.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)
at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.js:66:27)
at Controller.start (/opt/zigbee2mqtt/lib/controller.js:110:27)
at start (/opt/zigbee2mqtt/index.js:95:5)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.21.1 start: node index.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.21.1 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/openhabian/.npm/_logs/2021-09-28T05_30_24_553Z-debug.log
Can someone help me?
