Takes a zigbee2mqtt
action from a dimmer switch and uses it to control lights.
Language: JavaScript
Dependencies:
MQTT
Changelog
Version 0.1
- initial release
Resources
uid: cossey:mqtt_dimmer_light
label: MQTT Dimmer/Switch Lighting Control
description:
configDescriptions:
- name: mqttTrigger1
label: MQTT Light Switch Trigger 1
description: Select the MQTT light switch triggers
type: TEXT
context: channel
filterCriteria:
- name: kind
value: TRIGGER
required: true
- name: mqttTrigger2
label: MQTT Light Switch Trigger 2
type: TEXT
context: channel
filterCriteria:
- name: kind
value: TRIGGER
required: false
defaultValue: ''
- name: lights
label: Lights
description: Select the Light items to affect
type: TEXT
context: item
filterCriteria:
- name: kind
value: Switch
- name: type
value: Switch
required: true
multiple: true
triggers:
- id: "1"
configuration:
channelUID: "{{mqttTrigger1}}"
type: core.ChannelEventTrigger
- id: "2"
configuration:
channelUID: "{{mqttTrigger2}}"
conditions: []
actions:
- inputs: {}
type: script.ScriptAction
configuration:
type: application/javascript
script: >-
var lights = {{lights}};
console.log(lights);
