I’m trying to get rid of the IKEA tradfri bridge since it frequently crashes and has huge lags when I’m trying to connect so it (via app or Google Home).
My Setup
- RPI 3B+
- OH 2.4.0
- CC2351
- Mosquito MQTT Broker
- Bulb: IKEA LED1732G11 - E27 1000 lumen, dimmable, white spectrum, opal white
Thing configuration
Thing mqtt:topic:tfb1ez2 "Hängelampe mitte" (mqtt:broker:zigbee2mqtt) @ "Esszimmer" {
Channels:
Type switch : switch "An/Aus" [
stateTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/state",
commandTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/set/state",
on="ON", off="OFF",
retained=true
Type dimmer : brightness "Helligkeit" [
stateTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/brightness",
commandTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/set/brightness_percent",
formatBeforePublish="%d",
min=0, max=255,
off="OFF", on="ON",
retained=true
Type dimmer : colortemp "Farbtemperatur" [
stateTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/color_temp",
commandTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/set/color_temp",
min=0, max=455,
retained=true
Type switch : availability "Availability" [
stateTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/availability",
off="offline", on="online",
retained=true
Type dimmer : linkquality "Verbindungsqualität" [
stateTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/linkquality",
min=0, max=255,
retained=true
Type datetime : lastseen "Zuletzt online" [stateTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/last_seen", retained=true]
Item configuration
Switch Light_GF_Dining_PendantLights_Center_Switch "An/Aus" <DimmableLight> (gFP_Lights) {channel="mqtt:topic:tfb1ez2:switch"}
Dimmer Light_GF_Dining_PendantLights_Center_Brightess "Helligkeit [%d %%]" <DimmableLight> (gFP_Lights) {channel="mqtt:topic:tfb1ez2:brightness"}
Dimmer Light_GF_Dining_PendantLights_Center_LightColor "Farbtemperatur [%d %%]" <ColorLight> (gFP_Lights) {channel="mqtt:topic:tfb1ez2:colortemp"}
DateTime Light_GF_Dining_PendantLights_Center_LastSeen "Zuletzt [%1$ta %1$td. %1$tb %1$tR]" <Time> (gFP_Lights) {channel="mqtt:topic:tfb1ez2:lastseen"}
Dimmer Light_GF_Dining_PendantLights_Center_LinkQuality "Signalstärke [%d %%]" <qualityofservice> (gFP_Lights) {channel="mqtt:topic:tfb1ez2:linkquality"}
Switch Light_GF_Dining_PendantLights_Center_Availability "Online" <switch> (gFP_Lights) {channel="mqtt:topic:tfb1ez2:availability"}
Problems
Controlling color temperature
I can’t properly control the color temperature. The bulb seems to have color-x
/color-y
, color_temp
and color_mode
to control the color temperature.
I tried color_mode
first. As a freshly reset lamp returns {"color_mode" : "2"}
, I tried setting:
mosquitto_pub -t 'zigbee2mqtt/bulbs/gf/livingroom/pendant1/set' -m '{"color_mode" : 1}'
But it yielded me the error:
zigbee2mqtt:error 2019-12-3 18:46:22 No converter available for ‘color_mode’ (1)
As I don’t know how to properly/valid set/control the color-x
/color-y
values, I tried color_temp
then and it seems to have a range from 0 to 455 (even though I find that range strange, so I might be wrong here). After the factory reset the bulb had a value of 370 and I didn’t notice a change in the color temperature when sending a value higher than 455 with mosquitto via:
mosquitto_pub -t 'zigbee2mqtt/bulbs/gf/livingroom/pendant1/set' -m '{"color_temp" : 455}'
While setting the color temperature seems to work via mosquitto_pub
it won’t work via the PaperUI. When I try to set the color temperature via the slider of the dimmer item, I get the warning:
[WARN ] [generic.internal.generic.ChannelState] - Command ‘370’ not supported by type ‘PercentageValue’: Value must be between 0 and 100
And the slider jumps from e.g. 90% back to ~20%. Accordingly a max value of 100 is applied and the light temperature is always some kind of cold white.
If I change the channel config in the thing configuration to use the following commandTopic
commandTopic="zigbee2mqtt/bulbs/gf/livingroom/pendant1/set/color_temp_percent",
Using the slider yields the warning:
[WARN ] [generic.internal.generic.ChannelState] - Command ‘500’ not supported by type ‘PercentageValue’: Value must be between 0 and 100
When I try to set 100% light temperature, which is very strange since the max
value is still 455. When I try to set 0%, the slider falls back to and sticks with ~35%.
Questions
- Does anyone have any idea how to properly control the color temperature?
- Does anyone know how to set/control
color_mode
orcolor-x/y
and what the difference is?
Side question:
The Dimmer
item for controlling the brightness
channel comes with a Off/On switch in the PaperUI (see screenshot). I can’t use it. When I click it, it yields the following error:
19:28:14.628 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.eclipse.smarthome.binding.mqtt.generic.internal.handler.GenericThingHandler@ad55c0’: null
java.lang.NumberFormatException: null
at java.math.BigDecimal.(BigDecimal.java:494) ~[?:?]
at java.math.BigDecimal.(BigDecimal.java:383) ~[?:?]
at java.math.BigDecimal.(BigDecimal.java:806) ~[?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.(DecimalType.java:57) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.library.types.PercentType.(PercentType.java:47) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.library.types.PercentType.valueOf(PercentType.java:63) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.binding.mqtt.generic.internal.values.PercentageValue.update(PercentageValue.java:87) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.generic.ChannelState.publishValue(ChannelState.java:302) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.handler.AbstractMQTTThingHandler.handleCommand(AbstractMQTTThingHandler.java:119) ~[?:?]
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy155.handleCommand(Unknown Source) [239:org.eclipse.smarthome.binding.mqtt.generic:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor63.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
- Why is that?
- How can I fix it?
Regards
