Zigbee2MQTT installation fails / ConBee II adapter not found
a Pi4 with 4GB is not really low memory. I would definitely recommend the 64bit version. There is a nasty delay (about 12sec) that it takes for each rule (JavaScript, blockly) to load in the 32 bit version.
You can read the background here:
Besides that there should be no udev-bug in the 64bit-system, so the whole problem should be gone
