I solved this via min/max-Definition in the channel-config.
Thing topic light_tradfri "light_tradfri" {
Channels:
Type switch : state "state" [ stateTopic = "zigbee2mqtt/light_tradfri/state", commandTopic = "zigbee2mqtt/light_tradfri/set/state", on = "ON", off = "OFF" ]
Type dimmer : brightness "brightness" [ stateTopic = "zigbee2mqtt/light_tradfri/brightness", commandTopic = "zigbee2mqtt/light_tradfri/set/brightness", min = 0, max = 254 ]
Type dimmer : color_temp "color_temp" [ stateTopic = "zigbee2mqtt/light_tradfri/color_temp", commandTopic = "zigbee2mqtt/light_tradfri/set/color_temp", min = 250, max = 454 ]
Type string : effect "effect" [ stateTopic = "zigbee2mqtt/light_tradfri/effect" ]
Type string : power_on_behavior "power_on_behavior" [ stateTopic = "zigbee2mqtt/light_tradfri/power_on_behavior" ]
Type number : linkquality "linkquality" [ stateTopic = "zigbee2mqtt/light_tradfri/linkquality" ]
BTW, I’v made a groovy script to convert zigbee2mqtt-devices to Things. (see attachement)
mqtt2things.groovy (4.3 KB)
I switched from deconz to zigbee2mqtt today and i didn’t want to waste my time with copy/paste and repetetive typing ![]()
- rename it to mqtt2things.groovy
- pipe topic
zigbee2mqtt/bridge/devicesin to it. This generates above output.
mosquitto_sub -t zigbee2mqtt/bridge/devices -C 1 | groovy ./mqtt2things.groovy -n light_tradfri
Then -n parameter is optional. It restricts procession to the given device-name
