Well my previous “solution” was bad as it does not convert the brightness part to the correct values as @anon71759204 pointed out earlier
So here is what i came up with which now everything is working as expected: (Also most parts are c + p from other community members which i’m really glad that they share thier findings with us.)
openHAB channel config:
channels:
- id: LEDKochinselXY
channelTypeUID: mqtt:color
label: LEDKochinselXY
description: null
configuration:
commandTopic: zigbee2mqtt/LEDKochinsel/set
colorMode: XYY
transformationPatternOut: JS:zigbeeColorOUT.js
formatBeforePublish: "%"
stateTopic: zigbee2mqtt/LEDKochinsel
transformationPattern: JS:zigbeeColorIN.js
transformation scripts:
zigbeeColorOUT.js
(function(color){
// convert 100% to 254 Steps of brightness
var bright = Number(color.split(/[,:]/)[2]) * 2.54;
// example output to mqtt: {"brightness":239,"color":{"x":0.601297,"y":0.311017}}
return '{"brightness":' + bright.toFixed(0) + ',"color":{"x":' + color.split(/[,:]/)[0] + ',"y":' + color.split(/[,:]/)[1] + '}}';
})(input)
zigbeeColorIN.js
// example input: {"brightness":50,"color":{"hue":359,"saturation":100,"x":0.6942,"y":0.2963},"color_mode":"xy","color_temp":158}
(function(color){
// convert 254 Steps to 100% of brightness
var bright = Number(color.split(/[,:]/)[1]) / 2.54;
// example output to openHAB: x,y,brightness - f.e.: 0.6942,0.2963,50
return color.split(/[,:]/)[8] + "," + color.split(/[,:}]/)[10] + "," + bright.toFixed(0);
})(input)
