I bought this Z-Wave alarm Zipato AB02Z_PSE02 recently which is described as multi-sound by the manufacturer.
In OpenHab (v2.40), I see oly two channels for this alarm - the battery percentage and a switch to on/off the alarm. The alarm works perfectly fine when the switch is set to ON. However, I am not sure how to use the multi-sound feature, for example as a doorbell.
The link to documentation of alarm is https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/907?layout=doc .
Would appreciate any help here in using the multi sound feature.
What more information do you want? You need to configure the Thing. From your link: (and more detail following)
Device Configuration
The following table provides a summary of the 6 configuration parameters available in the AB02Z_PSE02. Detailed information on each parameter can be found in the sections below.
Param
Name
Description
1
Alarm volume
configure alarm volume
2
alarm duration time
alarm duration time: 1=30sec., 2=1 min, 3=5min
3
Configuring doorbell music duration time
4
Configure doorbell music volume
Low, Middle, High
5
Configure alarm sound index
sound type
6
Configure doorbell music index
Sound Types
The manual does not state what the 10 music indices are.
