same issue for me.
I even re-included the item with different node ID, but can see still 2 channels only.
running with 2.5.10 zwave binding
any idea?
same issue for me.
any idea?
@fireplex and @alex_alexandroff22 did either of you get this working in the end? I am finding that sending a 0 or 1 to the notification_send
channel doesnât seem to have any effect. I started a new topic about that but was wondering if you had made it work for yourselves.
yes, works fine with OH 3.
Thing channel is a âswitch_binaryâ
Sitemap:
Switch item=Siren label="Siren"
Setpoint item=Siren2 minValue=1 maxValue=6 step=1
Thing config:
thingTypeUID: zwave:philio_pse02_00_000
configuration:
config_7_4: 4
config_31_4_0000000C: 6
group_1: []
config_29_4: 0
Rule excerpt:
if (Alarm.state == ON) {
sendCommand(Siren2, 5)
Thanks @alex_alexandroff22 I already use the switch_binary
channel and I can make the alarm sound, but I cannot make the doorbell sound. What channel did you bind your item Siren2
to? I have been trying to use the notification_send
channel but sending values 0 or 1 to it seems to have no effect on the alarm sound when switch_binary
is on, I only hear an alarm sound.
I notice youâre using the philio_pse02 and Iâve got a AB02Z_PSE02
siren so perhaps there are differences there. Looking further into that I see in the database your device uses COMMAND_CLASS_ALARM_V3
for the notification_send
channel, where mine has COMMAND_CLASS_ALARM_V0
