I´m trying to configure the PSE02 siren with latest zwave binding (1.9.x snapshot).
Unfortunately there are no configuration parameters visible in Habmin (just “Configuration parameters” without any possibility to edit), although the item database on Chris´ page contains some parameters like 7 or 29.
The “PSE02”.xml inside the binding is empty. any idea why?
As you already found, there are no configuration parameters in the OH1 database. If all the parameters are in the online database now, then I can export an updated database - I assumed that maybe all the parameters weren’t in the database though since it seems to be a random collection of numbers, but if that’s all of them then no problem.
They say the siren is using the “NOTIFICATION” command class instead of “SWITCH_MULTILEVEL” for setting different alert types.(although mentioned in the manual)
I´ve also read the OH wiki about different command classes, there is no single word about “NOTIFICATION”, but on GitHub there are several topics where you manage the update of this command class. Notification
Firstly, ALARM is the same as NOTIFICATION - it’s just that Sigma renamed the command class when they changed the versions.
Currently it’s not possible to send alerts though - the binding only receives notifications. There is an issue open on this for exactly this purpose, but I’ve not implemented it yet.
I’ve added code, and a new channel to support this. Please let me know if it works - I have a suspicion that the device might not report that it supports the ALARM/NOTIFICATION class and this might require a further addition somewhere.
To use, you should be able to send a number from 1 to 6.
Awesome @chris! And thank you for mentioning me here
Is there a little code snippet you could share? E.g. how to send a number via recipe or script?
I checked the commit message and also tried to understand the diff on GitHub, but without any luck.
You should be able to able to set the item to a number between 1 and 6 to start the different sounds. I guess this can be done through a rule or a sitemap with a selection widget.
Ok, so the should be a new channel for my siren, isn’t it?
I updated to the latest snapshot, but can’t see any new channel. There is only the binary_switch which simply turns on the siren on/off.
Like you’ve expected, it seems that there is more work needed to make it work.
Sitemap snippet:
Selection item=zwave_device_a831d790_node25_notification_send mappings=[1=SMOKE, 2=ACCESS_CONTROL, 3=BURGLAR, 4=EMERGENCY_1, 5=EMERGENCY_2, 6=EMERGENCY_3]```
You can find the logs at: https://www.myqnapcloud.com/smartshare/69237gkn4l6p7008uv2z1x3c_6YpmqT1
under logs/NotificationTest. At around 20:52 (18:52 in the logs?) I set notification_send from 1 to 6 two times.
Regards :)
I’m pretty sure it’s what I thought would happen. Since this device doesn’t advertise the command class, it’s not found during initialisation, and therefore it can’t be used. I’ll add an update to the database to force the command class.
Thanks! At the moment I’m fighting again with my updated snapshot.
I can’t install the Basic UI and seeing a lot of ERRORs in the logs. Trying build #518 now instead of #519.
Know this is offtopic, but I get a lot of these messages here:
2016-10-08 09:48:52.464 [ERROR] [ore.internal.events.OSGiEventManager] - Dispatching/filtering event for subscriber 'org.eclipse.smarthome.core.events.EventSubscriber' failed: java.lang.NoClassDefFoundError: org/openhab/core/compat1x/internal/TypeMapper
java.util.concurrent.ExecutionException: java.lang.NoClassDefFoundError: org/openhab/core/compat1x/internal/TypeMapper
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_65]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_65]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[98:org.eclipse.smarthome.core:0.9.0.201610071316]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[98:org.eclipse.smarthome.core:0.9.0.201610071316]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[98:org.eclipse.smarthome.core:0.9.0.201610071316]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager.dispatchESHEvent(OSGiEventManager.java:188)[98:org.eclipse.smarthome.core:0.9.0.201610071316]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager.handleEvent(OSGiEventManager.java:163)[98:org.eclipse.smarthome.core:0.9.0.201610071316]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager.handleEvent(OSGiEventManager.java:146)[98:org.eclipse.smarthome.core:0.9.0.201610071316]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415)[3:org.apache.karaf.services.eventadmin:4.0.4]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.run(HandlerTask.java:90)[3:org.apache.karaf.services.eventadmin:4.0.4]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Caused by: java.lang.NoClassDefFoundError: org/openhab/core/compat1x/internal/TypeMapper
at org.openhab.core.events.internal.EventBridge.constructProperties(EventBridge.java:101)
at org.openhab.core.events.internal.EventBridge.receive(EventBridge.java:135)
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:192)
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:1)
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
... 4 more
Is that problem known? Is there a quick solution, eg. removing orphaned files?
