In PaperUI i have :
Status: OFFLINE - COMMUNICATION_ERROR Error occurred (Check log)
But zm is reachable with the same credentials and URL with chrome
restarting OH2 did not solve the problem
In PaperUI i have :
OK. Have you tried the sugegstions in the Troubleshooting section on the Wiki page?
That might give some hint of where the problem is. Please let me know if it is understandable, or if you need some instructions, I plan to give this page an overhaulâŠ
Unfortunately nothing solve my problem.
Iâm using Java _101 but without HTTPS
Regarding telnet i can telnet on port 6802.
The curl command give me :
curl -d â=openhab&=openhab&action=login&view=consoleâ -c cookies.txt http://192.168.88.4/zm/index.php
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title>ZM - Connexion</title> <link rel="icon" type="image/ico" href="graphics/favicon.ico"/> <link rel="shortcut icon" href="graphics/favicon.ico"/> <link rel="stylesheet" href="css/reset.css" type="text/css"/> <link rel="stylesheet" href="css/overlay.css" type="text/css"/> <link rel="stylesheet" href="skins/classic/css/classic/skin.css" type="text/css" media="screen"/> <script type="text/javascript" src="tools/mootools/mootools-core.js"></script> <script type="text/javascript" src="tools/mootools/mootools-more.js"></script> <script type="text/javascript" src="js/logger.js"></script> <script type="text/javascript" src="js/overlay.js"></script> <script type="text/javascript"> //<![CDATA[ <!-- var AJAX_TIMEOUT = 10000;
var currentView = 'login'; var thisUrl = "/zm/index.php"; var skinPath = "skins/classic";
var canEditSystem = false; var canViewSystem = false;
var canEditGroups = false;
var refreshParent = false;
var focusWindow = false;
var imagePrefix = "events/"; //--> //]]> </script> <script type="text/javascript" src="skins/classic/js/classic.js"></script> <script type="text/javascript" src="skins/classic/js/skin.js"></script> <script type="text/javascript" src="skins/classic/views/js/login.js"></script> </head> <!-- PP: Add recaptcha script if enabled --> <body> <div id="page"> <div id="header"> <h1>ZoneMinder Connexion</h1> </div> <div id="content"> <form name="loginForm" id="loginForm" method="post" action="/zm/index.php"> <input type="hidden" name="action" value="login"/> <input type="hidden" name="view" value="postlogin"/> <input type="hidden" name="postLoginQuery" value=""> <table id="loginTable" class="minor" cellspacing="0"> <tbody> <tr> <td class="colLeft">Nom</td> <td class="colRight"><input type="text" name="username" value="" size="12"/></td> </tr> <tr> <td class="colLeft">Mot de passe</td> <td class="colRight"><input type="password" name="password" value="" size="12"/></td> </tr> </tbody> </table> <input type="submit" value="Connexion"/> <!-- PP: Added recaptcha widget if enabled --> </form> </div> </div> </body> </html> indent preformatted text by 4 spaces
Content of cookies.txt
Netscape HTTP Cookie File
http://curl.haxx.se/docs/http-cookies.html
This file was generated by libcurl! Edit at your own risk.
192.168.88.4 FALSE / FALSE 0 ZMSESSID onlsli4g5gq1nccrcvj4eel5l5
192.168.88.4 FALSE /zm/ FALSE 1798813438 zmSkin classic
192.168.88.4 FALSE /zm/ FALSE 1798813438 zmCSS classic
Thanks for your help
Thanks, I am 99,9% sure that I know what is the problem. It seems like you are using French as language in ZoneMinder? I have heard about similar problems with German, but I thought had solved those language related problems. I will have to check up when I come home.
I bet everything works if you switch to english in ZoneMinder. Off course French should also work
Oh Shame, i think this is the 0,01% .
I changed to en_US same issue
changed to en_GB same issue
even after restarted all service.
but i noticed this event when i just created the bridge
2017-02-22 16:44:35.727 [INFO ] [andler.ZoneMinderServerBridgeHandler] - [BRIDGE (414e8379)]: Starting ZoneMinder Server Bridge Handler (Bridge=ânullâ)
I agree, I have looked at the code and I see no reason that it should be a problem, unless you are using an old build - but then changing to en_GB should have fixed itâŠ
So we are obviously looking for something else. From your previous posting I can conclude:
Just to be 100% sure, could you login to openHAB karaf console and check that the ZoneMidner Binding is only installed once. From the karaf console you can write:
bundle:list | grep ZoneMinder
Verify that only one instance is returned and also verfy the version of it.
I will have to consult the code for better suggestions, I also might need a special build with more logging enabled.
dear,
here is the result :
____ ____ ___ ____ / / / / | / __ )
/ __ / __ / _ / __ / // / /| | / __ |
/ // / // / __/ / / / __ / ___ |/ // /
_/ ./_// /// /// |/_____/
/_/ 2.1.0-SNAPSHOT
Build #806
Hit ââ for a list of available commands
and â[cmd] --helpâ for help on a specific command.
Hit ââ or type âsystem:shutdownâ or âlogoutâ to shutdown openHAB.
openhab> bundle:list | grep ZoneMinder
225 | Active | 80 | 2.1.0.201702192000 | ZoneMinder Binding
openhab>
By the way, have you changed any of the text strings in ZoneMinder that you can change? Just to get an idea of where to search .-)
That is as expected and how it should be.
No i did not make any change on zoneminder given that is a nearly fresh install but iâm going to remove and reinstall to be sure !
Oh, donât do that, I just wanted to get some hints of where to look
Do you have at least one event in each monitor. There is an open issue regarding this
I have only one monitor and how can i see the event for this monitor in this case to ensure that itâs ok.
On the ZoneMinder dashboard, you have information about your monitor, One column says event, if it says 0 then there is zero events and you have found a potential reason.
Click on the name of the monitor and in the detailed screen, you should click âForce Alarmâ (remember to cancel again )
this happens sometimes; I can cure it by deleting the server Thing and then adding it again (I define it manually in a Things file to make this easier)
Ok i have 0 events i noticed but i was not thinking that can be a problem, i clicked on force alarm but it did nothing
It should come online then, else try to restart openHAB. I am debugging this right now, and I can see that an exception is thrown when there is 0 events. That obviously have to be fixed
I think youâre right but it seems i had a zoneminder issue in this case because i just added another monitor with a video stream and still at 0 events ,my zone is ok , btw when i click on force alarm it should be online shouldnât it?
edit : i find out , now i have events ,i give you answer as soon as the bridge come online !
unfortunately , i have the same problem even after restarting ZM and OH2 , sorry
I have identified a problem in the code, I think the problem that I have identified has âmany facesâ, I have verified that it specifically occurs when starting adding a monitor without any events. I have reason to believe that it also can occur in other situations. A precondition for the problem is that the monitor is OFFLINE in openHAB, there might be more. I believe that it could also solve the variant that you are looking at.
i just deleted my monitor and added one ,now the number of events is now 54. however I have the same error in the log, thanks again for all your quick answers.
