I have a zooZ motion sensor with the Alarm(Motion) channel linked to a switch, but the switch never gets updated. I have other motion sensors that work fine with this configuration. I can see it gets triggered in the log:
17:29:18.773 [DEBUG] [essage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
17:29:18.786 [DEBUG] [ialization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
17:29:18.800 [DEBUG] [ave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@534b3e44 already registered
17:29:18.824 [DEBUG] [essage.ApplicationCommandMessageClass] - NODE 5: Incoming command class BASIC
17:29:18.836 [DEBUG] [l.commandclass.ZWaveBasicCommandClass] - NODE 5: Received Basic Request
17:29:18.849 [DEBUG] [l.commandclass.ZWaveBasicCommandClass] - NODE 5: Basic Set sent to the controller will be processed as Basic Report
17:29:18.865 [DEBUG] [l.commandclass.ZWaveBasicCommandClass] - NODE 5: Basic report, value = 0xFF
17:29:18.878 [DEBUG] [ave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
17:29:18.894 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
17:29:18.912 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
17:29:18.934 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:656b4c09:node5:sensor_binary to ON [OnOffType]
17:29:18.967 [DEBUG] [l.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Message has Ack Pending: Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=5, callback=101, payload=05 02 20 02
17:29:18.994 [DEBUG] [ave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
17:29:19.004 [DEBUG] [zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 05 0A 71 05 07 FF 00 FF 07 08 00 00 98
17:29:19.020 [DEBUG] [ave.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 05 0A 71 05 07 FF 00 FF 07 08 00 00 98
17:29:19.035 [DEBUG] [ave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0A 71 05 07 FF 00 FF 07 08 00 00
17:29:19.058 [DEBUG] [essage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
17:29:19.072 [DEBUG] [ialization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
17:29:19.086 [DEBUG] [ave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@534b3e44 already registered
17:29:19.109 [DEBUG] [essage.ApplicationCommandMessageClass] - NODE 5: Incoming command class ALARM
17:29:19.122 [DEBUG] [l.commandclass.ZWaveAlarmCommandClass] - NODE 5: Received ALARM command V4
17:29:19.135 [DEBUG] [l.commandclass.ZWaveAlarmCommandClass] - NODE 5: Process NOTIFICATION_REPORT V4
17:29:19.148 [DEBUG] [l.commandclass.ZWaveAlarmCommandClass] - NODE 5: NOTIFICATION report - 7 = 255, event=8, status=255
17:29:19.164 [DEBUG] [l.commandclass.ZWaveAlarmCommandClass] - NODE 5: Alarm Type = BURGLAR (7)
17:29:19.177 [DEBUG] [ave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
17:29:19.191 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveAlarmValueEvent
17:29:19.208 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
17:29:19.239 [DEBUG] [nternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
17:29:19.255 [DEBUG] [nternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 8, type OnOffType
17:29:19.273 [DEBUG] [nternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
17:29:19.288 [DEBUG] [nternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 8, type OnOffType
17:29:19.306 [DEBUG] [l.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Message has Ack Pending: Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=5, callback=101, payload=05 02 20 02
Thanks for the help.
