Can anyone please expand on the the use of the dimmer channels on the ZEN31 device? I have one hooked up to a single color LED strip to one of the RGBW outputs. I have sliders to control channels dimmer and dimmer1-5. I wrongly assumed that there would be a 1 to 1 correlation between a dimmer channel and the RGBW outputs.
Through trial and error I can control the LED strip, but I don’t want to guess at what I am doing. Also I see interaction between the sliders that I don’t understand. Can someone please advise?
Yes, my site map was based on a posting from @5iver. This device is a really cool thing. Several years ago I designed a LED controller using an XBee and Arduino. It controls lighting on a my stair rail, but it started acting up. I saw the ZEN31 and thought it might be a good fit to replace my design and simplify my HA.
Thank you for pointing this out. Basically, just use the Channels from endpoint 1. I will make an update to get the other Channels cleaned up to avoid confusion.
After some testing, I just updated the device in the database to remove the extra Channels. These changes will take about a week to make their way into the binding. Here is how I have defined my Items…
Color DS_PoolTable_LED_Color "Pool Table Color [%s]" <colorpicker> (gLED,gDS_RecreationRoom,gDS_FamilyRoom_Action) ["ColorLighting"] {channel="zwave:device:07cb40a2:node151:color_color1", alexa="BrightnessController.brightness,ColorController.color" [category="OTHER"]}
Dimmer DS_PoolTable_LED_ColorTemperature "Pool Table Color Temperature [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:color_temperature1"}
Dimmer DS_PoolTable_LED1 "Pool Table: Brightness [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:switch_dimmer1"}
Dimmer DS_PoolTable_LED2 "Pool Table: Red [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:switch_dimmer2"}
Dimmer DS_PoolTable_LED3 "Pool Table: Green [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:switch_dimmer3"}
Dimmer DS_PoolTable_LED4 "Pool Table: Blue [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:switch_dimmer4"}
Dimmer DS_PoolTable_LED5 "Pool Table: White [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:switch_dimmer5"}
Number:Energy DS_PoolTable_LED_Energy "Pool Table: Energy [%.0f kWh]" <energy> (gLED,gDS_RecreationRoom,gElectrical) {channel="zwave:device:07cb40a2:node151:meter_kwh1"}
Number:Power DS_PoolTable_LED_Power "Pool Table: Power [%.0f W]" <energy> (gLED,gDS_RecreationRoom,gElectrical) {channel="zwave:device:07cb40a2:node151:meter_watts1"}
Number DS_PoolTable_LED_Scene "Pool Table: Scene [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:scene_number1"}
Number DS_PoolTable_LED_Program "Pool Table: Program [%d]" <none> (gLED,gDS_RecreationRoom) {channel="zwave:device:07cb40a2:node151:config_decimal_param157"}
I see this device is still waiting for approval in Chris’ database. I wonder if has been over looked, or maybe folks that do the approval are just busy?
Hmmm… that is strange. I usually publish things myself, but remember leaving this one for @chris to look at before the next export. It is now published. Sorry for the delay!
