I see problem with persistence when I switch OH to ZRAM. I saw that other had similar issues but it was mentioned about ZRAM. Below you can se data from console and from zramctl.
I’m not a expert but space seems be ok. I have problem with all all historical data
15:51:22.585 [ERROR] [rd4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file ‘/var/lib/openhab/persistence/rrd4j/Systeminfo_CPUTemperature.rrd’: /var/lib/openhab/persistence/rrd4j/Systeminfo_CPUTemperature.rrd (Read-only file system)
You have a weird long list of zram filesystems. Did you reboot recently ? If not please do. Eventually stop openhab and zram-config.service first and remove unneeded files.
You also seem to have (too) large defaults for your rrd4j files (600M is a LOT).
Sort of, if I had to guess based of the information given you are using an older version of ram. @Xfiles80 have you tried uninstalling zram rebooting and then reinstalling it? It looks like you are observing a bug from older versions of zram that would cause a similar problem.
I belive that reason of no space is dd. I tried to do image of disk and there was problem with target disk. After this I dont have space and cant extend system to full card capacity(64GB)
