Read the docs https://www.openhab.org/docs/ it recommended the 2gb but didn’t say the rest were untested and had issues, so got what my local retailer had left in stock.
Added zraminstall=disable into openhabian.conf but booting up seems to still try to install it.
There’s on the order of 500 different SBCs, let alone all the x86 variants. Needless to say they’re all untested when we do not mention them, isn’t it.
Again: read the other threads on this topic. Use clonebranch=master
with the 1.6 alpha image.
Today I tried installing the latest openHABian (1.6.1) on a new Raspberry Pi 4 with 4 GB RAM and a USB SSD. first-boot also fails at ZRAM installation/setup. I don’t really know why. I didn’t get any networking errors on the log.
I disabled it in openhabian.conf and openHABian setup went through.
Now I tried to setup ZRAM via openhabian-config, but I’m getting an error:
There was an error or interruption during the execution of: "30 | System Settings"
What to do? Do I even need ZRAM with a USB SSD?
In addition, I set up the debug maximum and tried again, this is what I got:
$ install -m 755 /opt/zram/openhabian-zram/zram-config /usr/local/sbin
+ install -m 755 /opt/zram/openhabian-zram/zram-config /usr/local/sbin
+ return 0
+ cond_redirect install -m 755 /opt/zram/openhabian-zram/zramsync /usr/local/sbin
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ install -m 755 /opt/zram/openhabian-zram/zramsync /usr/local/sbin \033[39;49;00m'
+ install -m 755 /opt/zram/openhabian-zram/zramsync /usr/local/sbin
install: cannot stat '/opt/zram/openhabian-zram/zramsync': No such file or directory
+ return 1
+ echo 'FAILED (zramsync)'
FAILED (zramsync)
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "30 | System Settings"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/master/docs/openhabian-DEBUG.md how to proceed.' 14 80
/opt/zram/openhabian-zram/zramsync in fact does not exist.
Booting from external mass storage (USB SSD or whatever) is not supported in openHABian.
No you wouldn’t need ZRAM in that case.
What does that mean for me? I have been using openHABian on an external SSD on a Raspberry Pi 3B+ for a few years now.
I am getting the same/similar errors (There was an error or interruption during the execution of: …) when installing other stuff (InfluxDB+Grafana) via openhabian-config as well.
Can I install it to a SD card and move everything to the USB SSD afterwards (“Move root to USB”)? But I guess that won’t move what’s need for booting to the SSD?
what is the content of the topper part of your debug output ?
The installation fails because the directory with source and compilation seems to miss.
Everything above is correct ?
Here is part of the log file.
+ echo -n '2020-12-10_20:27:36_CET [openHABian] Installing ZRAM code... '
2020-12-10_20:27:36_CET [openHABian] Installing ZRAM code... + cond_redirect mkdir -p /opt/zram
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ mkdir -p /opt/zram \033[39;49;00m'
+ mkdir -p /opt/zram
+ return 0
+ [[ -d /opt/zram/overlayfs-tools ]]
+ cond_redirect update_git_repo /opt/zram/overlayfs-tools master
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ update_git_repo /opt/zram/overlayfs-tools master \033[39;49;00m'
+ update_git_repo /opt/zram/overlayfs-tools master
+ local branch
+ local path
+ branch=master
+ path=/opt/zram/overlayfs-tools
++ timestamp
++ date +%F_%T_%Z
++ basename /opt/zram/overlayfs-tools
+ echo -n '2020-12-10_20:27:36_CET [openHABian] Updating overlayfs-tools, master branch from git... '
2020-12-10_20:27:36_CET [openHABian] Updating overlayfs-tools, master branch from git... + cond_redirect git -C /opt/zram/overlayfs-tools fetch origin
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/overlayfs-tools fetch origin \033[39;49;00m'
+ git -C /opt/zram/overlayfs-tools fetch origin
+ return 0
+ cond_redirect git -C /opt/zram/overlayfs-tools fetch --tags --force --prune
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/overlayfs-tools fetch --tags --force --prune \033[39;49;00m'
+ git -C /opt/zram/overlayfs-tools fetch --tags --force --prune
+ return 0
+ cond_redirect git -C /opt/zram/overlayfs-tools reset --hard origin/master
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/overlayfs-tools reset --hard origin/master \033[39;49;00m'
+ git -C /opt/zram/overlayfs-tools reset --hard origin/master
HEAD is now at 77bf3f7 Merge pull request #11 from amir73il/deref-cmd
+ return 0
+ cond_redirect git -C /opt/zram/overlayfs-tools clean --force -x -d
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/overlayfs-tools clean --force -x -d \033[39;49;00m'
+ git -C /opt/zram/overlayfs-tools clean --force -x -d
Removing logic.o
Removing main.o
Removing overlay
Removing sh.o
+ return 0
+ cond_redirect git -C /opt/zram/overlayfs-tools checkout master
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/overlayfs-tools checkout master \033[39;49;00m'
+ git -C /opt/zram/overlayfs-tools checkout master
Already on 'master'
Your branch is up to date with 'origin/master'.
+ return 0
+ echo OK
OK
+ return 0
+ [[ -d /opt/zram/openhabian-zram ]]
+ cond_redirect update_git_repo /opt/zram/openhabian-zram master
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ update_git_repo /opt/zram/openhabian-zram master \033[39;49;00m'
+ update_git_repo /opt/zram/openhabian-zram master
+ local branch
+ local path
+ branch=master
+ path=/opt/zram/openhabian-zram
++ timestamp
++ date +%F_%T_%Z
++ basename /opt/zram/openhabian-zram
+ echo -n '2020-12-10_20:27:38_CET [openHABian] Updating openhabian-zram, master branch from git... '
2020-12-10_20:27:38_CET [openHABian] Updating openhabian-zram, master branch from git... + cond_redirect git -C /opt/zram/openhabian-zram fetch origin
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/openhabian-zram fetch origin \033[39;49;00m'
+ git -C /opt/zram/openhabian-zram fetch origin
+ return 0
+ cond_redirect git -C /opt/zram/openhabian-zram fetch --tags --force --prune
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/openhabian-zram fetch --tags --force --prune \033[39;49;00m'
+ git -C /opt/zram/openhabian-zram fetch --tags --force --prune
+ return 0
+ cond_redirect git -C /opt/zram/openhabian-zram reset --hard origin/master
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/openhabian-zram reset --hard origin/master \033[39;49;00m'
+ git -C /opt/zram/openhabian-zram reset --hard origin/master
HEAD is now at 5f2ffc8 Remove zramsync service (#7)
+ return 0
+ cond_redirect git -C /opt/zram/openhabian-zram clean --force -x -d
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/openhabian-zram clean --force -x -d \033[39;49;00m'
+ git -C /opt/zram/openhabian-zram clean --force -x -d
+ return 0
+ cond_redirect git -C /opt/zram/openhabian-zram checkout master
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ git -C /opt/zram/openhabian-zram checkout master \033[39;49;00m'
+ git -C /opt/zram/openhabian-zram checkout master
Already on 'master'
+ return 0
+ echo OK
OK
+ return 0
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-10_20:27:39_CET [openHABian] Setting up OverlayFS... '
2020-12-10_20:27:39_CET [openHABian] Setting up OverlayFS... + cond_redirect make --always-make --directory=/opt/zram/overlayfs-tools
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ make --always-make --directory=/opt/zram/overlayfs-tools \033[39;49;00m'
+ make --always-make --directory=/opt/zram/overlayfs-tools
make: Entering directory '/opt/zram/overlayfs-tools'
gcc -Wall -std=c99 -c main.c
gcc -Wall -std=c99 -c logic.c
gcc -Wall -std=c99 -c sh.c
gcc -lm main.o logic.o sh.o -o overlay
make: Leaving directory '/opt/zram/overlayfs-tools'
+ return 0
+ cond_redirect mkdir -p /usr/local/lib/zram-config/
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ mkdir -p /usr/local/lib/zram-config/ \033[39;49;00m'
+ mkdir -p /usr/local/lib/zram-config/
+ return 0
+ cond_redirect install -m 755 /opt/zram/overlayfs-tools/overlay /usr/local/lib/zram-config/overlay
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ install -m 755 /opt/zram/overlayfs-tools/overlay /usr/local/lib/zram-config/overlay \033[39;49;00m'
+ install -m 755 /opt/zram/overlayfs-tools/overlay /usr/local/lib/zram-config/overlay
+ return 0
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-10_20:27:41_CET [openHABian] Setting up ZRAM... '
2020-12-10_20:27:41_CET [openHABian] Setting up ZRAM... + cond_redirect install -m 755 /opt/zram/openhabian-zram/zram-config /usr/local/sbin
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ install -m 755 /opt/zram/openhabian-zram/zram-config /usr/local/sbin \033[39;49;00m'
+ return 0
+ [[ -n '' ]]
+ return 1
FAILED (zramsync)
+ return 1
+ return 1
+ echo FAILED
FAILED
+ return 1
It means we didn’t test that so you have to find out yourself.
Ok, I will. I’m kind of surprised that booting from external storage is not officially supported, but I think I’ve read in another post that you are not a fan of booting from SSD
It seems to be working now (after struggling with installation problems of InfluxDB via openhabian-config (it wasn’t able to add the admin user, I had to create it manually and then re-do the config with “pre-existing installation”).
Now on to trying upgrading to openHAB 3 M5
Official support means we need to test it beforehand which is a very time consuming thing - and there’s many many HW variations that all would need to be tested.
SSDs have a number of drawbacks (cost, space, power consumption) and you get nothing in return that is worth the effort of developing/testing.
Noone needs to use them to run openHAB now that there’s ZRAM to mitigate SD wearout.
So those few people that insist on using one can do but have to sort that out for themselves.
Yea, that makes sense.
When you say that SSDs aren’t necessary anymore… What about for example my InfluxDB and other things that sit on the SD card, don’t they contribute to SD wearout even when some part of the system uses ZRAM?
Or can I just move “everything” to ZRAM?
I might have to look deeper into it… Of course I’d like to get rid of the SSD as well if possible, but so far I was under the impression that it’s still better to use one.
if you have the RAM available, yes
There’s an open issue to sort that out. Feel encouraged to do and contribute back with a PR that installs InfluxDB data into /var/lib/openhab/persistence (which is on ZRAM).
Hello all,
i just tried to install OH3 on a fresh system (Raspberry Pi 4 (4GB), 16GB SD card, openhabian v1.6.1 via Rasperry Pi Imager, edited the openhabian.conf file with an other hostname, username, password and enabled maximum logging). After the initial openHAB 2.5 installation was finished, i jumped into openhabian-config and updated OH3 from menu 40. He tries to install OH3.0.0M5, did that (after a few confirmations) and finally he wants to install / start ZRAM. But this fails with
After the failure i tried to install ZRAM again from menu 30, but this failed at the very same level. After a reboot i gave it another try but still the same failure. Please find below my latest attempt log:
[10:55:11] ohadm@openHAB:~$ sudo openhabian-config
[sudo] password for ohadm:
2020-12-14_10:55:19_CET [openHABian] Checking for root privileges... OK
+ export UNATTENDED MIGRATION SILENT DEBUGMAX INTERACTIVE
+ for shfile in "${BASEDIR:-/opt/openhabian}"/functions/*.bash
+ source /opt/openhabian/functions/auth.bash
+ source /opt/openhabian/functions/backup.bash
+ source /opt/openhabian/functions/config.bash
+ source /opt/openhabian/functions/ext-storage.bash
+ source /opt/openhabian/functions/find.bash
+ source /opt/openhabian/functions/helpers.bash
++ ESC='\033['
++ COL_DEF='\033[39;49;00m'
++ COL_RED='\033[31;01m'
++ COL_GREEN='\033[32;01m'
++ COL_YELLOW='\033[33;01m'
++ COL_BLUE='\033[34;01m'
++ COL_MAGENTA='\033[35;01m'
++ COL_CYAN='\033[36;01m'
++ COL_LGRAY='\033[37;01m'
++ COL_DGRAY='\033[90;01m'
++ export COL_DEF COL_RED COL_GREEN COL_YELLOW COL_BLUE COL_MAGENTA COL_CYAN COL_LGRAY COL_DGRAY
+ source /opt/openhabian/functions/influxdb+grafana.bash
+ source /opt/openhabian/functions/java-jre.bash
+ source /opt/openhabian/functions/menu.bash
+ source /opt/openhabian/functions/nodejs-apps.bash
+ source /opt/openhabian/functions/openhab.bash
+ source /opt/openhabian/functions/openhabian.bash
+ source /opt/openhabian/functions/packages.bash
+ source /opt/openhabian/functions/system.bash
+ source /opt/openhabian/functions/vpn.bash
+ source /opt/openhabian/functions/wifi.bash
+ source /opt/openhabian/functions/zram.bash
++ pwd
+ OLDWD=/home/ohadm
+ cd /opt
+ config_ipv6
+ local aptConf=/etc/apt/apt.conf/S90force-ipv4
+ local sysctlConf=/etc/sysctl.d/99-sysctl.conf
+ [[ enable == \d\i\s\a\b\l\e ]]
+ [[ enable == \e\n\a\b\l\e ]]
+ grep -qs '^[[:space:]]*# Disable all IPv6 functionality' /etc/sysctl.d/99-sysctl.conf
+ [[ -n '' ]]
+ apt_update
+ PID_APT=1714
+ whiptail_check
+ apt-get update
++ command -v whiptail
+ [[ -x /usr/bin/whiptail ]]
+ load_create_config
+ local 'questionText=\nWelcome to openHABian!\n\nPlease provide the name of your Linux user i.e. the account you normally log in with.\n\nTypical user names are '\''pi'\'' or '\''ubuntu'\''.'
+ local input
+ [[ -f /etc/openhabian.conf ]]
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:20_CET [openHABian] Loading configuration file '\''/etc/openhabian.conf'\''... '
2020-12-14_10:55:20_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... ++ getent group ohadm
+ [[ ! -n ohadm:x:1000:ohadm,frontail ]]
+ id -u ohadm
+ source /etc/openhabian.conf
++ hostname=openHAB
++ username=ohadm
++ timezone=Europe/Berlin
++ locales='en_US.UTF-8 de_DE.UTF-8'
++ system_default_locale=en_US.UTF-8
++ wifi_ssid=
++ wifi_psk=
++ wifi_country=
++ ipv6=enable
++ repositoryurl=https://github.com/openhab/openhabian
++ clonebranch=stable
++ debugmode=maximum
++ cached_java_opt=Zulu11-32
++ java_opt=Zulu11-32
++ zraminstall=enable
++ hotspot=enable
+ echo OK
OK
+ openhabian_console_check
+ [[ -z 1 ]]
++ tput cols
+ [[ 195 -ge 120 ]]
+ return 0
+ openhabian_update_check
+ [[ -z 1 ]]
+ local branch
+ local introText
+ local unsupportedHWText
+ local unsupportedOSText
+ branch=stable
+ introText='Additions, improvements or fixes were added to the openHABian configuration tool. Would you like to update now and benefit from them? The update will not automatically apply changes to your system.\n\nUpdating is recommended.'
+ unsupportedHWText='You are running on old hardware that is no longer officially supported.\nopenHABian may still work with this or not.\nWe recommend that you replace your hardware with a current SBC such as a RPi4/2GB.\nDo you really want to continue using openHABian on this system?'
+ unsupportedOSText='You are running an old Linux release that is no longer officially supported.\nWe recommend upgrading to the most current stable release of your distribution (or current Long Term Support version for distributions that offer LTS).\nDo you really want to continue using openHABian on this system?'
++ timestamp
++ date +%F_%T_%Z
++ get_git_revision
++ local branch
++ local latestTag
++ local revCount
++ local shorthash
+++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
++ branch=stable
+++ git -C /opt/openhabian describe --tags --abbrev=0
++ latestTag=v1.6.1
+++ git -C /opt/openhabian log --oneline
+++ wc -l
++ revCount=963
+++ git -C /opt/openhabian log --pretty=format:%h -n 1
++ shorthash=1fa8959
++ echo '[stable]v1.6.1-963(1fa8959)'
+ echo '2020-12-14_10:55:20_CET [openHABian] openHABian configuration tool version: [stable]v1.6.1-963(1fa8959)'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:20_CET [openHABian] Checking for changes in origin branch stable... '
2020-12-14_10:55:20_CET [openHABian] Checking for changes in origin branch stable... + is_pine64
++ uname -r
+ [[ 5.4.79-v7l+ =~ pine64-longsleep ]]
+ return 1
+ is_jessie
+ [[ '' == \j\e\s\s\i\e ]]
++ cat /etc/os-release
+ [[ PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" =~ jessie ]]
+ return 1
+ is_xenial
+ [[ '' == \x\e\n\i\a\l ]]
VERSION_ID="10"
ID=raspbian
ID_LIKE=debian
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" =~ xenial ]]
+ return 1
+ git -C /opt/openhabian config user.email openhabian@openHABian
+ git -C /opt/openhabian config user.name openhabian
+ git -C /opt/openhabian fetch --quiet origin
++ git -C /opt/openhabian rev-parse stable
++ git -C /opt/openhabian rev-parse '@{u}'
+ [[ 1fa89598a0d636b78270484530512ef60c81acdf == 1fa89598a0d636b78270484530512ef60c81acdf ]]
+ echo OK
OK
+ openhabian_announcements
+ [[ -z 1 ]]
+ local newsFile
+ local readNews
+ newsFile=/opt/openhabian/NEWS.md
+ readNews=/opt/openhabian/docs/LASTNEWS.md
+ cmp --silent /opt/openhabian/NEWS.md /opt/openhabian/docs/LASTNEWS.md
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:22_CET [openHABian] Switching to branch stable... '
2020-12-14_10:55:22_CET [openHABian] Switching to branch stable... + git -C /opt/openhabian checkout --quiet stable
+ echo OK
OK
+ [[ -n '' ]]
+ show_main_menu
+ local choice
+ local version
+++ get_git_revision
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=stable
++++ git -C /opt/openhabian describe --tags --abbrev=0
+++ latestTag=v1.6.1
++++ git -C /opt/openhabian log --oneline
++++ wc -l
+++ revCount=963
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=1fa8959
+++ echo '[stable]v1.6.1-963(1fa8959)'
++ whiptail --title 'Welcome to the openHABian Configuration Tool [stable]v1.6.1-963(1fa8959)' --menu 'Setup Options' 18 116 11 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian project and this tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' 'Upgrade all installed software packages (incl. openHAB) to their latest version' '03 | openHAB Stable' 'Install or upgrade to the latest stable release of openHAB 2' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basic openHABian setup ►' '20 | Optional Components' 'Choose from a set of optional software components ►' '30 | System Settings' 'A range of system and hardware related configuration steps ►' '40 | openHAB related' 'Switch the installed openHAB version or apply tweaks ►' '50 | Backup/Restore' 'Manage backups and restore your system ►'
+ choice='30 | System Settings'
+ RET=0
+ '[' 0 -eq 1 ']'
+ '[' 0 -eq 255 ']'
+ [[ 30 | System Settings == '' ]]
+ [[ 30 | System Settings == \0\0* ]]
+ [[ 30 | System Settings == \0\1* ]]
+ [[ 30 | System Settings == \0\2* ]]
+ [[ 30 | System Settings == \0\3* ]]
+ [[ 30 | System Settings == \1\0* ]]
+ [[ 30 | System Settings == \2\0* ]]
+ [[ 30 | System Settings == \3\0* ]]
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
+++ branch=stable
++++ wc -l
+++ revCount=963
+++ hostname
+++ env
+++ grep '^[[:space:]]*LANG='
+++ sed 's|LANG=||g'
+++ date +%H:%M
++ whiptail --title 'Welcome to the openHABian Configuration Tool [stable]v1.6.1-963(1fa8959)' --menu 'Setup Options' 24 118 17 --cancel-button Back --ok-button Execute '31 | Change hostname' 'Change the name of this system, currently '\''openHAB'\''' '32 | Set system locale' 'Change system language, currently '\''en_GB.UTF-8'\''' '33 | Set system timezone' 'Change the your timezone, execute if it'\''s not '\''10:55'\'' now' ' | Enable NTP' 'Enable time synchronization via systemd-timesyncd to NTP servers' ' | Disable NTP' 'Disable time synchronization via systemd-timesyncd to NTP servers' '34 | Change passwords' 'Change passwords for Samba, openHAB Console or the system user' '35 | Serial port' 'Prepare serial ports for peripherals like Razberry, SCC, Pine64 ZWave, ...' '36 | WiFi setup' 'Configure wireless network connection' ' | Disable WiFi' 'Disable wireless network connection' '37 | Move root to USB' 'Move the system root from the SD card to a USB device (SSD or stick)' '38 | Use ZRAM' 'Use compressed RAM/disk sync for active directories to avoid SD card corruption' ' | Uninstall ZRAM' 'Don'\''t use compressed memory (back to standard Raspberry Pi OS filesystem layout)' '39 | Setup Exim Mail Relay' 'Install Exim4 to relay mails via public email provider' '3A | Setup tailscale VPN' 'Establish or join a WireGuard based VPN using the tailscale service (BETA)' ' | Remove tailscale VPN' 'Remove the tailscale service' ' | Install WireGuard' 'Setup WireGuard to enable secure remote access to this openHABian system (BETA)' ' | Remove WireGuard VPN' 'Remove WireGuard VPN from this system'
+ choice2='38 | Use ZRAM'
+ '[' 0 -eq 1 ']'
+ '[' 1 -eq 255 ']'
+ wait_for_apt_to_finish_update
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:29_CET [openHABian] Updating Linux package information... '
2020-12-14_10:55:29_CET [openHABian] Updating Linux package information... + [[ -z 1714 ]]
+ tail --pid=1714 -f /dev/null
+ echo OK
OK
+ case "$choice2" in
+ init_zram_mounts install
+ is_arm
+ is_armv6l
+ [[ '' == \a\r\m\v\6\l ]]
+ case "$(uname -m)" in
++ uname -m
+ return 1
+ is_armv7l
+ [[ '' == \a\r\m\v\7\l ]]
++ uname -m
+ return 0
+ return 0
+ local disklistFileAWS=/etc/amanda/openhab-aws/disklist
+ local disklistFileDir=/etc/amanda/openhab-dir/disklist
+ local 'introText=You are about to activate the ZRAM feature.\nBe aware you do this at your own risk of data loss.\nPlease check out the "ZRAM status" thread at https://community.openhab.org/t/zram-status/80996 before proceeding.'
+ local 'lowMemText=Your system has less than 1 GB of RAM. It is definitely NOT recommended to run ZRAM (AND openHAB) on your box. If you proceed now you will do so at your own risk!'
+ local zramInstallLocation=/opt/zram
+ local storageDir=/storage
+ [[ install == \i\n\s\t\a\l\l ]]
+ [[ -f /etc/ztab ]]
+ [[ -n 1 ]]
+ whiptail --title 'Install ZRAM, Continue?' --yes-button Continue --no-button Cancel --yesno 'You are about to activate the ZRAM feature.\nBe aware you do this at your own risk of data loss.\nPlease check out the "ZRAM status" thread at https://community.openhab.org/t/zram-status/80996 before proceeding.' 10 80
+ has_lowmem
+ local totalMemory
++ awk '/MemTotal/ {print $2}' /proc/meminfo
+ totalMemory=3970372
+ [[ -z 3970372 ]]
+ [[ 3970372 -lt 900000 ]]
+ return 1
+ dpkg -s make libattr1-dev
+ install_zram_code /opt/zram
+ local overlayfsGit=https://github.com/kmxz/overlayfs-tools
+ local zramGit=https://github.com/mstormi/openhabian-zram
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:35_CET [openHABian] Installing ZRAM code... '
2020-12-14_10:55:35_CET [openHABian] Installing ZRAM code... + cond_redirect mkdir -p /opt/zram
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ local branch
+ local path
+ branch=master
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:35_CET [openHABian] Updating overlayfs-tools, master branch from git... '
2020-12-14_10:55:35_CET [openHABian] Updating overlayfs-tools, master branch from git... + cond_redirect git -C /opt/zram/overlayfs-tools fetch origin
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
Removing logic.o
Removing main.o
Removing overlay
Removing sh.o
+ return 0
+ [[ -n '' ]]
Already on 'master'
+ return 0
+ echo OK
OK
+ return 0
+ [[ -n '' ]]
+ local branch
+ local path
+ branch=master
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:37_CET [openHABian] Updating openhabian-zram, master branch from git... '
2020-12-14_10:55:37_CET [openHABian] Updating openhabian-zram, master branch from git... + cond_redirect git -C /opt/zram/openhabian-zram fetch origin
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
Already on 'master'
+ return 0
+ echo OK
OK
+ return 0
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:41_CET [openHABian] Setting up OverlayFS... '
2020-12-14_10:55:41_CET [openHABian] Setting up OverlayFS... + cond_redirect make --always-make --directory=/opt/zram/overlayfs-tools
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 0
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:43_CET [openHABian] Setting up ZRAM... '
2020-12-14_10:55:43_CET [openHABian] Setting up ZRAM... + cond_redirect install -m 755 /opt/zram/openhabian-zram/zram-config /usr/local/sbin
+ [[ -n '' ]]
+ return 0
+ [[ -n '' ]]
+ return 1
FAILED (zramsync)
+ return 1
+ '[' 1 -ne 0 ']'
+ return 0
+ true
+ show_main_menu
+ local choice
+ local version
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
+++ branch=stable
++++ wc -l
+++ revCount=963
+ choice=
+ RET=1
+ '[' 1 -eq 1 ']'
+ return 255
+ system_check_default_password
+ is_pi
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ local algo
+ local defaultPassword
+ local defaultUser
+ local generatedPassword
+ local introText
+ local originalPassword
+ local salt
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ id -u pi
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ defaultUser=ohadm
+ defaultPassword=openhabian
++ grep -w ohadm /etc/shadow
++ cut -d: -f2
+ originalPassword='$6$abcdefgh.'
++ echo '$6$abcdefgh.'
++ cut '-d$' -f2
+ algo=6
+ introText='The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd ohadm'\''!'
++ echo '$6$abcdefg.'
++ cut '-d$' -f3
+ salt=Xzabcdefgh.qhje
+ export algo defaultPassword salt
++ perl -le 'print crypt("$ENV{defaultPassword}","\$$ENV{algo}\$$ENV{salt}\$")'
+ generatedPassword='$abcdefg.QTR.'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2020-12-14_10:55:54_CET [openHABian] Checking for default openHABian username:password combination... '
2020-12-14_10:55:54_CET [openHABian] Checking for default openHABian username:password combination... ++ id -u ohadm
+ [[ -n 1000 ]]
+ [[ $6$abcdefghQTR. == \$\6\$\a\b\c\d\e\f\g\g. ]]
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -e '2020-12-14_10:55:54_CET [openHABian] We hope you got what you came for! See you again soon ;)'
As this is a brand new fresh install on a new RPi4 with new SD card and latest images i do not know, how to tackle this issue or how i can resolve it. Has anyone a hint how to digg in?
Thanks in advance
Patrick
I am getting similar error with a fresh openhab3 install on rasbian. I noticed job-stop command times out / fails every time I restart and I get a system error 30 when I try to enable / system locks if I try to remove from openhabian-config. This was a new 3.0 download and no options set.
That post is more confusing than helpful.
What did you install where: InfluxDB ? ZRAM ? OH3 ? On pure Raspbian, which version ? on top of openHABian image ? Using which install instructions ?
for me i simply flashed the openhab 3.0 rpi image from the website. Upon a subsequent reboot while I had the device hooked to a monitor I noticed that the “zram-config” service fails to stop - it times out at 5 minutes and 10 seconds. If there is a specific log I can bring up and post the output that would be helpful I can do that. I have not done anything to this system other than the welcome setup within OH - changing hostname and default password for the openhabian system user (done via openhabian-config)
