ZRAM messed up?
I have a rasbian running on a SD card. Sinse a while it is running unstable, auto reboots and log gaps. It looks like it’s creating more ram and zram disks then it should.
[08:24:33] root@openhabian:/home/openhabian# fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xbbfcfbef
Device         Boot  Start      End  Sectors  Size Id Type
/dev/mmcblk0p1        8192   532479   524288  256M  c W95 FAT32 (LBA)
/dev/mmcblk0p2      532480 60661759 60129280 28.7G 83 Linux
Disk /dev/zram0: 600 MiB, 629145600 bytes, 153600 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 900 MiB, 943718400 bytes, 230400 sectors
Disk /dev/zram2: 600 MiB, 629145600 bytes, 153600 sectors
This is the zram config:
# swap  alg             mem_limit       disk_size       swap_priority   page-cluster    swappiness
swap    lzo-rle         200M            600M            75              0               80
# dir   alg             mem_limit       disk_size       target_dir                      bind_dir
dir     zstd            300M            900M            /var/lib/openhab/persistence    /persistence.bind
# log   alg             mem_limit       disk_size       target_dir              bind_dir                oldlog_dir
log     zstd            200M            600M            /var/log                /log.bind
Any ideas what I could do? Is the SD card faulty?
Regards,
Bastiaan
Which type of software do you use?
zram is used be part of openHABian setup, but there are no devices /dev/ramxx in openHABian, so maybe you did setup some additional software which messed up with zram.
Did you already reboot the system?
AFAIK
openhabian@openhabian:~ $ dmesg | grep brd
[    1.412405] brd: module loaded
is responsible for /dev/ram*, cf. How can I change the amount and size of Linux ramdisks (/dev/ram0 - /dev/ram15)? - Super User.
This doesn’t answer the interesting question whether the /dev/ram* are needed.
openHABian Configuration Tool — [openHAB3]{2022-12-18T22:39:53+01:00}(2633096) openHAB 3.4.2 - Release Build
Yes multiple times.
[08:44:18] root@openhabian:/home/openhabian# dmesg | grep brd
[08:44:33] root@openhabian:/home/openhabian#
Any idea’s how to fix this? Perhaps disabling and re-enable ZRAM in OpenHabian?
