Java Runtime Environment: which java platform is used and what version
openHAB version:2.5
Issue of the topic: ZW098 Bulb I cannot control color from rules. I can turn on.off, dim the ligths to a percentage, even change white temperature. However I cannot change to another color. If I use basic UI or Paper UI then is ok. I am new to open hab, I think my item definition is wrong but not sure how to do. please help
Please post configurations (if applicable):
Items configuration related to the issue
Dimmer KitchenDiningLightSwitchDimmer "Kitchen Dining Light [%s %%]" <light> (GF_Kitchen) {channel="zwave:device:0b2ecca1:node54:switch_dimmer"}
Color KitchenDiningLightColorColor "Kitchen Color control" (GF_Kitchen) {channel="zwave:device:0b2ecca1:node54:color_color"}
Dimmer KitchenDiningLightColorTemperature "Kitchen Color temperature" (GF_Kitchen) {channel="zwave:device:0b2ecca1:node54:color_temperature"}
Sitemap configuration related to the issue
Rules code related to the issue
if (FamilyRoomLightControlSceneNumber.state == 3.0)
FamilyRoomLightSwitchDimmer.sendCommand(15)
KitchenDiningLightSwitchDimmer.sendCommand(15)
if (FamilyRoomLightControlSceneNumber.state == 4.0)
FamilyRoomLightSwitchDimmer.sendCommand(OFF)
KitchenDiningLightColorColor.sendCommand(258, 80, 100)
Services configuration related to the issue
If logs where generated please post these here using code fences:
2020-02-16 21:05:56.718 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert '258' to a command type which item 'KitchenDiningLightColorColor' accepts: [HSBType, PercentType, OnOffType, IncreaseDecreaseType, RefreshType].
