Hi Chris. I just updated as a test to version 2.4 (instead of stable 2.3) and this is what my log file shows:
2018-05-31 21:35:44.778 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 016A:0203:006F::1.0
2018-05-31 21:36:23.777 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 016A:0203:006F::1.0
I just realised that this device has a totally different manufacturer and that’s why it’s not detected. If will need a new entry to be added to the database - if you can create an account I’ll give you access to do this.
Hi Chris, just registered. This nano dimmer is exactly the same as Aeotec, just re-branded. This is all fairly new to me, but I’m guessing 016A is the manufacturer/vendor ? I saw 0003 as being Aeotec somewhere…
Yes - the 16A is (I think Oomi. 0086 is Aeotec from memory.
Here’s what to do… Once I update your access, you will be able to create a new device using the upload XML option. The XML you need to load is in the {userdata}/zwave folder - it’s named with the node number.
This will create a basic database entry with all the channels populated (hopefully there will be no manual change needed). It would be good if you could upload the manual, and an image, and possibly populate information such as the overview/inclusion/exclusion fields (this is used to create OH documentation - it should just be a case to cut and paste from the manufacturers manual).
From here, we can copy all the configuration data from the Aeotec device - there’s a menu option to do this in the tools menu in the top right of the database page. I can also do this for you if needed.
Done. Have completed XML upload and added required photos and manual.
I also have a ZW140 (Dual Nano Switch) which I need to wire in over the weekend rebranded FT140 (Fantech).
It will more than likely appear as an unknown device so will Add to device list too. There will be others but I haven’t yet got them from Fantech, unless it is safe to do a bulk duplication of anything with ZW > FT and update Manufacturer ID accordingly because everything appears identical to me.
I don’t think there’s any way to do this, and I don’t know if it would be wise anyway. Aeon have a lot of devices and I don’t just want to create new devices that might never exist. Once you have the devices, then we can add them…
It’s possible, but not so easy. You can (in theory) edit the JAR file, find the XML file, and change the manufacturer ID. Alternatively, you can compile a JAR yourself and export the file from the database, but again, this is not so simple.
Thanks. I try and do an update of the database once or twice a week - depending on changes. I know everyone wants their updates added quickly, and I understand that when you get a new toy but I think this is still reasonably responsive compared to other systems.
Forgive me if I am misunderstanding but the Manufacturer ID’s are both the same (362) and the Device ID’s are the same (111), it is just the Type that is different (515 as opposed to 3)
