I’m trying to get a heatit thermostat to properly work with my setup. I had it working a while ago but have since made changes by including new devices / upgrading the binding etc. and now it does not fully work.
I have 3 attached channels, and then reflect the current state of the thermostat if I change manually on the device.
What I cannot get to work is changing the setpoint. I have:
String Bathroom_Heating_Overview "Bathroom [%s]"
Number Bathroom_Heating_Current "Heating - Bathroom - Current [%.1f °C]" (gTemperatures, gFF_Bathroom) { channel="zwave:device:512:node6:sensor_temperature" }
Number Bathroom_Heating_Mode "Heating - Bathroom - Mode" (gTemperatures, gFF_Bathroom) { channel="zwave:device:512:node6:thermostat_mode" }
Number Bathroom_Heating_Target "Heating - Bathroom - Target [%.1f °C]" (gTemperatures, gFF_Bathroom) { channel="zwave:device:512:node6:thermostat_setpoint_heating" }
When using a sitemap to change Bathroom_Heating_Target
I get the following in the log:
10:02:58.297 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 6: Command received zwave:device:512:node6:thermostat_setpoint_heating --> 18
10:02:58.300 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 6: No converter set for command zwave:device:512:node6:thermostat_setpoint_heating type DecimalType
I am using the latest zwave 2.4.0 binding installed through PaperUI. openHAB is version 4.1.5
Would appreciate any help on getting this resolved
Cheers, Adam
