I’m new here and hope anyone can help me.
Openhab-version: 3.2.0
Binding: zwave
I have a new device aërQ Temperature & Humidity (ZW039). I can integrate in my network, I get data in items. Looks good so far. But. if I try to configure it in Things. I get always “Please review the configuration and correct validation errors” see screenshot.
As per manual the 0 is correct, because its the default value.
Note from Manual:
Parameter 255: Reset Parameter
This parameter helps reset configuration parameters and the device to factory defaults.
Size: 4 Byte, Default Value: 0
Setting
Description
1 – 4294967294
Reset all Parameter settings to their default settings.
4294967295 Completely factory reset sensor and send device reset locally notification.
I found an jar file: /tmp/mvn/org/openhab/addons/bundles/org.openhab.binding.zwave/3.2.0/org.openhab.binding.zwave-3.2.0.jar
it looks like this is the zwave binding, this contains a file “OH-INF/thing/aeotec/zwa039_2_0.xml” which looks like the parameter file. in there:
<parameter name="config_255_4" type="integer" groupName="configuration"
min="1" max="4294967294">
<label>255: Reset Parameter</label>
<description><![CDATA[
This parameter helps reset configuration parameters and the device to factory defaults.<br /> <h1>Overview</h1><p>This parameter helps reset configuration parameters and the device to factory defaults. Setting 1 – 4294967294 = Reset all Parameter settings to their default settings, Setting 4294967295 = Completely factory reset sensor and send device reset locally notification.<br /></p>
]]></description>
<default>0</default>
<limitToOptions>false</limitToOptions>
</parameter>
Looks strange to me because default = 0, but min = 1.
Same problem on parameter config_5_2; config_7_1; config_8_1
I tried to change this min value in this file, but this does not help.
Is it possible to disable the plausibility check? How can I Update the database or only this file? https://www.opensmarthouse.org/ is linking to this forum.
Hope You can understand my problem.
Many Thanks in advance.
