hello to all nerds
i’am running OH Version 2.5.5 (Build) on Debian 10 Buster as virtual machine on ESXi7 (intel NUC i3) and OH Version 2.5.8 (Build) native on Raspi4 with Kernel 5.4.51-v7.
as zwave controller I use Aeotec USB Stick Gen5 (on Debian Buster) and RaZberry2 (on Raspi4)
I use 5xPD03Z PIR Motion Sensor AND 1xAeotec MultiSensor 6 as PIR.
everything working fine exept the Multisensor6 Motion Detection.
I already upgraded the FW to 1.13 EU.
I already try different parameter but nothing helps to get “alarm_motion”.
I set the LogLevel to DEBUG to check the messages from my MS6, but nothing happened.
I did not get any message like “zwave_device_12345678_nodexx_alarm_motion changed from OFF to ON”
Also the LED on the MS6 did NOT flash when I wipe my hands in front of the sensor.
On the OH-Console I get this Info:
openhab> things show zwave:device:8592dfad:node25
Type: zwave:aeon_zw100_01_010
Label: Z-Wave Node 025: ZW100 Multisensor 6
Status: ONLINE
Bridge: zwave:serial_zstick:8592dfad
Properties:
zwave_class_basic : BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic : GENERIC_TYPE_SENSOR_MULTILEVEL
zwave_frequent : false
zwave_neighbours :
modelId : ZW100
zwave_version : 1.13
zwave_listening : true
zwave_plus_devicetype : NODE_TYPE_ZWAVEPLUS_NODE
manufacturerId : 0086
manufacturerRef : 0002:0064,0102:0064,0202:0064,1A02:0064
dbReference : 778
versionMin : 1.10
zwave_deviceid : 100
zwave_nodeid : 25
vendor : AEON Labs
defaultAssociations : 1
zwave_routing : true
zwave_plus_roletype : ROLE_TYPE_SLAVE_ALWAYS_ON
zwave_beaming : true
zwave_secure : false
zwave_class_specific : SPECIFIC_TYPE_ROUTING_SENSOR_MULTILEVEL
zwave_manufacturer : 134
zwave_devicetype : 2
Configuration parameters:
config_52_1 : 50
config_54_2 : 100
config_202_1 : 0
config_204_1 : 0
group_1 : [controller]
config_112_4 : 3600
config_39_1 : 20
config_9_2_00000100 : 0
config_56_1 : 4
config_58_1 : 5
config_201_2_000000FF : 1
config_43_2 : 100
config_64_1 : 1
config_252_1 : 0
config_60_1 : 2
config_81_1 : 0
config_41_4_0000FF00 : 1
wakeup_interval : 3600
config_50_4_7FFF0000_wo : 0
config_255_4_wo : 0
action_heal : false
config_102_4 : 0
config_9_2 : 2
config_3_2 : 10
config_45_1 : 2
config_5_1 : 1
config_41_4_wo : 20
config_55_1 : 8
binding_cmdrepollperiod : 1500
config_53_2 : 1000
config_51_1 : 60
config_100_1_wo : 0
config_201_2 : 1
config_203_2 : 0
config_50_4_wo : 0
action_reinit : false
config_201_2_0000FF00 : 0
wakeup_node : 1
config_113_4 : 3600
config_9_2_00000001 : 1
config_111_4 : 3600
config_49_4_wo : 0
config_59_1 : 10
config_49_4_7FFF0000_wo : 280
config_57_2 : 5121
config_42_1 : 10
config_41_4_00FF0000 : 0
config_44_1 : 10
config_50_4_0000FF00_wo : 1
config_61_1 : 0
config_40_1 : 1
config_49_4_0000FF00_wo : 1
action_failed : false
config_110_1_wo : 0
action_remove : false
binding_pollperiod : 86400
config_2_1 : 1
config_101_4 : 241
config_8_1 : 15
config_46_1 : 0
config_4_1 : 5
config_48_1 : 0
config_103_4 : 0
node_id : 25
Channels:
Label: Sensor (temperature)
Type: zwave:sensor_temperature
Description: Indicates the current temperature
Label: Sensor (ultraviolet)
Type: zwave:sensor_ultraviolet
Description: Indicates the current ultraviolet level
Label: Sensor (luminance)
Type: zwave:sensor_luminance
Description: Indicates the current light reading
Label: Sensor (relative humidity)
Type: zwave:sensor_relhumidity
Description: Indicates the current relative humidity
Label: Motion Alarm
Type: zwave:alarm_motion
Description: Indicates if a motion alarm is triggered
Label: Tamper Alarm
Type: zwave:alarm_tamper
Description: Indicates if the tamper alarm is triggered
Label: Batterieladung
Type: system:battery-level
The tamper works when i touch the case, but didn´t switch to OFF.
I also tried the MS6 on the Raspi4, but same result.
I set up InfluxDB as persistent storage, as I can see, the MS6 never send any “alarm_motion” OFF/ON/0/1/255/ALARM or anything else to the controller.
btw. the MS6 ist on USB-Power, and I resetted the MS6 many times to factory default before I included in the other network.
I bought that device with Firmware 1.12, but never works.
I also uploaded the openhab.log to https://opensmarthouse.org/utilities/logviewer/zwave/ to check, but no conclusion.
I also set the state of the Item in OpenHab with a HapPanel construction (zwave:device:8592dfad:node25:alarm_motion - Switch) for testing to “ON”, only to see if my logic is working, that works and i can see it in the logfile and in Grafana, BUT NOT from the sensor.
any thoughts?
best regards from germany
