I’m trying to get an Aeotec USB serial stick to be recognized. It always says “Status: OFFLINE - COMMUNICATION_ERROR zwave.thingstate.serial_notfound”. I know I the serial port is com3, and to prove it I wrote a short program that opens the stick and does an interrogate over the serial port. That works. But the Z-Wave Serial Controller is never recognized. I haven’t paired the controller with any zwave light switches yet, but it should see the controller, right?
Here is the console:
17:21:28.554 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port 'com3’
17:21:28.559 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:serial_zstick:52da4562’ has been updated.
17:21:28.560 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:52da4562’ changed from OFFLINE (COMMUNICATION_ERROR): zwave.thingstate.serial_notfound to OFFLINE (BRIDGE_OFFLINE): Controller is offline
17:21:28.771 [INFO ] [me.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:52da4562’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): zwave.thingstate.serial_notfound
Have you checked the permissions on the serial device? I’m running openhab on linux and I’m using a Aeostick. I had the exact same problem. I solved it by setting permission on the usb device so that anyone can access it.
