- Platform information:
- Hardware: Raspberry PI 4, 8GB
- OS: Linux openhabian 5.10.17-v7l+ #1403
- Java Runtime Environment: OpenJDK Runtime Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
- openHAB version: openHAB 3.0.1
I have a Aeotec ZW175 switch (operating my subwoofer) connected to Openhab via a Aeon Labs USB Z-Wave Plus Controller.
My .things file is:
Bridge zwave:serial_zstick:32208706ae “Z-Wave Serial Controller” @ “B39BMK” [ port="/dev/ttyACM0", controller_softreset=“false”, controller_master=“true”, heal_enable=“true”, security_networkkey=“XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX”, security_inclusionmode=0, controller_sisnode=1, controller_sync=“false”, inclusion_mode=2, controller_wakeupperiod=3600, heal_time=2, controller_exclude=“false”, controller_inclusiontimeout=30, controller_hardreset=“false” ]
aeotec_zw175_00_000 subwoofer “Z-Wave Node 017: ZW175 Smart Switch 7 Subwoofer” @ “B39BJO” [ node_id=17 ]
My .items file is made from the Openhab channel interface (I removed the irrelevant points):
Group Subwoofer “Subwoofer Group” (B39BJO) [“Equipment”]
// Points:
Switch ZWaveNode017ZW175SmartSwitch7Subwoofer_Switch “Subwoofer” (Subwoofer) [“Point”] { channel=“zwave:aeotec_zw175_00_000:32208706ae:subwoofer:switch_binary”, homekit=“Switchable” , ga=“Switch”}
Number ZWaveNode017ZW175SmartSwitch7Subwoofer_Electricmeteramps “Electric meter (amps)” (Subwoofer) [“Point”] { channel=“zwave:aeotec_zw175_00_000:32208706ae:subwoofer:meter_current” }
Number ZWaveNode017ZW175SmartSwitch7Subwoofer_ElectricmeterkWh “Subwoofer Energy meter (kWh)” (Subwoofer) [“Point”] { channel=“zwave:aeotec_zw175_00_000:32208706ae:subwoofer:meter_kwh” }
Number ZWaveNode017ZW175SmartSwitch7Subwoofer_Electricmeterwatts “Subwoofer Power meter (watts)” (Subwoofer) [“Point”] { channel=“zwave:aeotec_zw175_00_000:32208706ae:subwoofer:meter_watts” }
Number ZWaveNode017ZW175SmartSwitch7Subwoofer_Electricmetervolts “Electric meter (volts)” (Subwoofer) [“Point”] { channel=“zwave:aeotec_zw175_00_000:32208706ae:subwoofer:meter_voltage” }
When I look at the data that comes out of the items it seems like the data for the energy measurement is mixed up with the voltage (local voltage ~230V). and the voltage and current are empty.
Does this issue sound familiar, anyone else experience a similar issue (the energy- and voltage reading of this switch mix up)?
I have 2nd identical switch and a Aeotec nano switch ZW116 with the exact same issue.
