I have a Z-Wave Serial Controller Eversping SA413 and two devices :
DWS01 Door and Window Sensor
Aeotec ZWA005 Motion, light, and temperature sensor
The two devices are correctly detected and installed on my setup. The DWS01 is working out of the box. I mean when I open or close the device, informations for open or close state appears instantly on paper UI.
I just configured the ZWA005 to get temperature every 1800sec, and poll device every 3600 from controler without success. When I check at Control tab and expect to get temperature information, or motion data, I just get -Nan informations.
I seriously think that I did a misconfiguration but, the fact is, I am currently a fuc***g noob. I tried to read logs, I tried to manually poll device with openhab-cli without success.
Anybody should have advice to trig data, check for specific log or anything else ?
Welcome to the OpenHAB community, great first post!
Do you use Habmin user interface? If not you may want to try it because it has some useful tools for zwave. First thing to try is setting the zwave logging to debug. Here is how
Once you get logging in debug mode try excluding and reincluding the device using Habmin while the log is in debug mode. Post log here (use code fences, don’t filter the log)
Sometimes the device may not be fully initialised. So, as @Andrew_Rowe suggested enable z wave logging, and then try to wake up the device. Easiest way would be to press the inclusion button and monitor the logs.
Once it is fully initialised, you can make changes and wake the devices so it can respond to the changes.
I just enabled logs and try with habmin to delete device and add again. Logs are very verbose, I prefered to paste them on pastebin.
Here are the exclude logs : https://pastebin.com/PWNQiGsi
Here are the include logs (more verbose) : https://pastebin.com/HqBfjHy4
Thanks for help !
[EDIT] 4 minutes after I added the device, I get these lines in debug log
You need to keep waking up that battery device until discovery is complete. Sometimes deleting (NOT exclude) & re-adding the Thing in HABmin helps. I usually find the HABmin device status is sometimes a good clue. I expect you are seeing it stuck in REQUEST_NIF which means the binding requested the device to send its details but they have not been fully received yet.
Despite that the doc talks about pushing the button for 2 seconds, it appears that the red led comes on but the binding does not receive any informations whereas that pushing one time (2 or 3 times) makes the device working as expected.
Maybe that this solution could be integrated in the kb for this device, it will avoid people to be stuck in my position in the future
