hi
for my fibaro smoke sensor version 002
the incoming fire alarm is not translated to the switch to go on.
as well the incoming multilevel report for temp does not update the item.
here is a log:
09:55:04.709 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 40: Transaction not completed: node address inconsistent. lastSent=40, incoming=255
09:55:12.701 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 10 28 06 31 05 01 22 01 00 DF
09:55:12.708 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
09:55:12.709 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 10 28 06 31 05 01 22 01 00 DF
09:55:12.711 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 10 28 06 31 05 01 22 01 00 DF
09:55:12.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=10 28 06 31 05 01 22 01 00
09:55:12.713 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 40: Application Command Request (ALIVE:DONE)
09:55:12.714 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 40: Incoming command class SENSOR_MULTILEVEL
09:55:12.715 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 40: Received Sensor Multi Level Request V5
09:55:12.716 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 40: Sensor Multi Level REPORT received
09:55:12.717 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 40: Sensor Type = Temperature(1), Scale = 0
09:55:12.718 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 40: Sensor Value = 25.6
09:55:12.719 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
09:55:12.720 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=40, callback=35, payload=28 02 84 08
09:55:12.722 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=10 28 06 31 05 01 22 01 00
09:55:12.723 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=35, expected=SendData, cancelled=false MISMATCH
09:55:17.047 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 10 28 0A 71 05 00 00 00 FF 01 00 01 03 51
09:55:17.050 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
09:55:17.052 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 10 28 0A 71 05 00 00 00 FF 01 00 01 03 51
09:55:17.054 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 10 28 0A 71 05 00 00 00 FF 01 00 01 03 51
09:55:17.056 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=10 28 0A 71 05 00 00 00 FF 01 00 01 03
09:55:17.056 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 40: Application Command Request (ALIVE:DONE)
09:55:17.057 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 40: Incoming command class ALARM
09:55:17.058 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 40: Received Alarm Request V3
09:55:17.059 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 40: Process Alarm Report, V3, length 13
09:55:17.060 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 40: Alarm report - 1 = 0, sensor=0, event=0, status=255
09:55:17.061 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 40: Alarm Type = Smoke (1)
09:55:17.061 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
09:55:17.062 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=40, callback=35, payload=28 02 84 08
09:55:17.081 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=10 28 0A 71 05 00 00 00 FF 01 00 01 03
09:55:17.082 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=35, expected=SendData, cancelled=false MISMATCH
