Thank you for your answer
Yes. They are. Besides one which works properly. Besides its battery state.
I noticed that too and changed them accordingly.
No. You can use HABmin to add items and link them to thte channels using the channels menu/config-options of a thing. And without the simple mode in PaperUI you have another menu entry items. With those two options you even don’t have to use any items-file. But sometimes for OH1 users it’s easier to use them.
Yes you’re right. I read the docs and those for migration too. I tried several things. Migration with old item-files and changing the channel-linking. Setting up everything from zero on without any config file. This is now my status. Most things work really nice. But some things went better with OH1. But I like the way which OH2 takes to get more people to use it. Especially less technical experienced people.
Yes. You are absolutely right. Regarding to this How do I turn on debug mode in openhab2? - #2 by Kai I found that post: Logging under OH2 / Karaf - #9 by chris
This helped me and now I have set up the DEBUG mode. Thanks.[quote=“jaydee73, post:2, topic:15425”]
Concerning the battery status: When did you include the devices? For battery devices it could take some time (hours, even days), before the battery status gets updated. Do you see the battery status in HABmin?
[/quote]
I know. The devices worked properly before. So why not now. I just switched to OH2. I didn’t change anything. I know that the battery values take some time to be transmitted to OH or its corresponding binding, because of the wakeup interval.
I want to use and try the new way. I backed up everything and I can switch back at any time. But with OH2 there are new ways to achieve things. So I think it’s the way to go and to try. And perhaps to help to test it as it still in beta status. In some time OH1 will be EOL so why not trying the new way. And if I am right there are some discussions here which suggest to use the way without the config files, because they are relicts from OH1. Not saying that they aren’t be used anymore ![]()
Best regards,
André
