Hi recently I decided to update my old an manually set installation on my Wheezy Raspberry2 of OH2 using what was available on apt-get packages.
I followed the installation instructions here https://docs.openhab.org/installation/linux.html#installation and initaillay everything seemed to be fine, but after couple of minutes java process dissapeared. What I’ve observed was that after forking many threads all of a sudden java process exited with no error in the logs. I increased the log level but still nothing.
What one could see in the zwave logs was
2018-01-15 23:25:58.487 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:cd7e4f2d' changed from UNINITIALIZED to INITIALIZING
2018-01-15 23:25:58.526 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:cd7e4f2d' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
my zwave stick is on /dev/ttUSB0
[ 2.924737] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[ 3.041680] usb 1-1.5: New USB device found, idVendor=10c4, idProduct=ea60
[ 3.052544] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.061976] usb 1-1.5: Product: CP2102 USB to UART Bridge Controller
[ 3.061988] usb 1-1.5: Manufacturer: Silicon Labs
[ 3.062005] usb 1-1.5: SerialNumber: 0001
[ 3.370473] usbcore: registered new interface driver usbserial
[ 3.380702] usbcore: registered new interface driver usbserial_generic
[ 3.389593] usbserial: USB Serial support registered for generic
[ 3.401791] usbcore: registered new interface driver cp210x
[ 3.409959] usbserial: USB Serial support registered for cp210x
[ 3.428718] usb 1-1.5: cp210x converter now attached to ttyUSB0
I read that may be it could be a permissions problem, so I included openhab user in the corresponding groups , but this didn’t help
pi@raspberrypi ~ $ sudo ls -l /dev/ttyUSB0
crw-rw---T 1 root dialout 188, 0 Jan 1 1970 /dev/ttyUSB0
pi@raspberrypi ~ $ id openhab
uid=111(openhab) gid=115(openhab) groups=115(openhab),5(tty),20(dialout)
I’ve purged the packages and re-installed again. Until the moment of installing zwave plugin OH2 was working fine. After installing zwave plugin again the same problem. I’ve also removed any previously saved configurations that i had in /etc/openhab2 folder
