It looks like the device is sending the BASIC class in the log you show, and there is no endpoint set to basic in the database. It probably should be the sensor_binary that is set to BASIC - please feel free to update the database appropriately.
Please feel free to update the database to add this.[quote=“nokyyz, post:14, topic:13512”]
Comment #2: in OH1, the Fibaro FGFS-101 flood sensor has a Tamper property (Switch swFibFlood_Tamper “Water-Sensor: Tamper”
[/quote]
This would be the Alarm General
channel. The database doesn’t know that this is a tamper unless someone actually updates it. Again, please feel freee to update the database.
I doubt that this should have respond_to_basic. That would mean that the main function of this device is a tamper alarm . As above, it is more likely that the sensor_binary should be set to BASIC.
I don’t know how every device in the database works, so really it needs others to edit the devices to get them correct. If everyone puts in a little time to get their devices correct, it won’t take too much I think .
