Installed Openhab 2.5
I have a Fibaro Flood Sensor FGFS-101 zw5
I don’t think this is in the database; how does one get it added and updated so i can include this device?
The community maintained database is here and the user guide is here.
I think you need to open a ticket to get write access to the database.
There appear to be 3 versions of the FGFS101 in the database, depending on firmware version.
What version of openHAB are you running? The latest one of the 3 is only available in the snapshot binding.
Openhab 2.5
That is closer… there is 2.5.0 through 2.5.10 and there are 2.5.11 snapshots. the newer versions have newer bindings and, sometimes, additional bindings.
The latest change I saw was in the 2.5.11 snapshot. If you are running .2.5.1 or later you can manually install the snapshot binding if you so not wish to upgrade all the bindings.
Not in a snapshot; running the stable, released build.
2.5.10 is the full version
Thanks Bruce.
An engineer friend of mine found the new binding and hooked it up for me; that’s for your time; appreciate it.
